Question about Maytag Atlantis MAV6000 Top Load Washer
My Washer will work at all. It acts dead
The unit was running a finish spin cycle when the load became unbalanced. we opened the lid, adjusted the for balance and closed the lid. Nothing. we checked the control dial and even reset to spin again, closed the lid, Nothing. I checked power, the power plug. we check the lid switch when closed. I removed back plate and tested for power, i was getting power to ground. We tried to start over by resetting the control dial to run a new load and tried with all temp settings, Nothing. No water flow. it acts dead. Could the unbalanced load cause this? Is this a lid switch problem? Is the control dial bad?
Please Help. Thanks in advance.
  • jmbfab4 Feb 06, 2009
    Hi Joyce,
    The washer was running in spin mode. I noticed it was spinning off balance. I simply opened the lid to stop the cycle and rearrange the load so it would finish in balanced spin. I closed the lid and the unit wouldn't turn back on. I then checked to see that the control dial was pull out in run mode, it was. I checked to see that the control dial was set with run time. it was. Nothing would work after that. I then checked other possibility as I described in my previous email.
    Thanks
    John
  • JOYCE BROOKS May 11, 2010
    this is joyce
    If you would please give a little more information on this problem all the info did not show up on screen. you said the machine was in the middle of the spin cycle when teh load became unbalanced and you opened the lid and then what?
    thanks
    joyce
A small run of these actually had an out of balance switch and fuse assembly that cut power to the machine if it went way out of balance ,check and see if yours has one and replace the fuse at first but you may have to replace the entire assembly
Posted on Feb 08, 2009
Unbalanced load
it could be your pump blocked and not discharging the water it will become unbalanced not spin
Nov 22, 2011 | Whirlpool WTW6400SW Top Load Washer
Wtw6600 washer has UL code and has trouble agitating and spinning.
The UL code means Unbalanced Load. Open the lid and move your clothes around so they are distributed evenly. Your spin cycle will then work normally.
Apr 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How do I get my machine to just spin a load? It became unbalanced and I adjusted it and now just want to spin the water out?
Turn power on. Without selecting a cycle, push the spin speed button to select the spin speed you desire. (if you had an unbalanced load, I'd suggest a low spin speed. You can repeat after with the next higher speed if desired) Push start.
This will give about a 12 to 14 minute pump and spin only cycle.
Mar 21, 2011 | LG WM-2277HW Front Load Washer
Error code UL with 12 minutes remaing on each load
hi,
This error code indicates that an unbalanced load is detected.
if the load is unbalanced, the washer will display this code while attempting to balance the load at the end of the wash cycle and before the final spin. If the code remains and the wash cycle dial is flashing after the recovery routine has stopped, open lid and redistribute the load. Close lid and press Start/Pause.
If the washer is not level, the washer may be more sensitive to unbalanced loads. The washer must be level from side to side and from front to back. The front and rear feet must be in firm contact with the floor. Make sure the locknuts are tightened.
If Power/Cancel or Pause/Cancel does not work
Unplug the washer or disconnect the power for one minute.
Plug in the washer or reconnect the power.
Re-select the cycle and press Start/Pause.
Sep 06, 2010 | Maytag Bravos MTW6600T Top Load Washer
Im getting a uL message on my spin cycle and I dont know why.
The "uL" message stands for "unbalanced load." Open the lid to the washer and redistribute the load if the "uL" display appears on the appliance.Redistributing the load should correct any imbalances in the washer and allow the washer to turn freely. Close the lid and press "Start" to restart the washer.
Jul 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My new Whirlpool Cabrio stops repeatedly with the UL flashing it never finishes a wash load, do you have a step by step CD explaining the use of this washer? I am about to return it to the store and get a...
I believe this model has a defective control board under the control panel. The new control board has longer times between the drain and the spin. Eliminating the unbalance when it tries to spin with water still left in it. Also check for slow drain this will enhance the problem. The control board is a warrany repair if covered.
Mar 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My machine will not run the spin cycles, and makes a very loud noise during the spin cycles, sounds like a bad motor or bearing?
I'm not a repair professional. I am just a 78 year man who has done his own washer repair for about 50 years. You might have a bad lid switch that keeps the washer from spinning. You might have an unbalanced load in the machine which makes the noise. The unbalanced load might also be the cause of not spinning.
Nov 23, 2009 | Hotpoint VBXR1090B Top Load Washer
My MLE2000 washer will start to spin and then
more likely an itntermitent lid switch problem as the washer strats it's spin cycle the motion is causuning the lid switch to open making the washer think some one has opened the lid and it shuts down to be safe check the switch make sure it hasn't come loose and check the actuator on the lid sometimes a plastic piece near the front of the lid that goes into sort of a key hole Good Luck
Oct 16, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
Maytag MAT12CSDAW
Leep, open the hatch that the timer sits under. You will see the timer and actuator that the coin tray pushes to start the wash cycle. You can rotate this cam clockwise until it gets to it's home position, ususally right around the 12:00 position. Good luck
Jun 20, 2006 | Maytag MAT12CS Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
195 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
