Question about Marshall 82 WTS LITHIUM BATTERY, 3 LED POWER INDICATOR => Model IDX-E80S Car Audio Amplifier
A Marshall 100w amp that lacks heater voltage on all tubes
This amp is a 1969. It has worked flawlessly until the other day; now it is dead. I have voltage on power caps but the tubes are not glowing. Has the power transformer failed? I am not sure if the 6.3v supply is present off of the transformer. I discharged a power cap with my body and have not invetigated much further since this rather ugly episode.
    Problem Solver:
  • 6 Answers
It would be worth just checking a little further before doing anything too radical (and expensive). First remove all the valves carefully and then with the chassis out of the case and upside down plug in the amp and switch on the power but not the standby. This should put the bias and heater voltages to the amp but not the HT. Now with a volt meter set on 10v AC range check pins 4 to 9 on one of the ECC83 valve bases. If you get nothing then the transformer is most likely damaged but if you get 6.3v it may just be a valve with a short holding the heater voltage down. Admittedly its a bit of a long shot but I have seen this happen once and its better to check than to go spending on an unnecessary replacement transformer.
The other thing to consider is if its only the 6.3V supply that has failed you could get the amp running for less than the price of a replacement transformer if you were to put in a simple mains to 6.3V auxilliary heater supply transformer to run alongside the existing mains transformer which could supply the HT and bias voltages. The 1969 required 8A at 6.3V for its heaters if you decide to look at this option
Posted on Jul 18, 2009
  • 1,902 Answers
Yes, it is the power transformer that has failed. If you are comfortable with replacing it then do so just be careful. If you could though I would be careful and check to see what power you are getting at the transformer just to make sure
Posted on Feb 06, 2009
Marshall Repair
If you can see the socket, get a crochet needle that fits inside the socket and pull it back up through the hole. Good luck!
Nov 07, 2013 | Marshall Amplification Marshall MA100C MA...
The socket that the guitar cable plugs into has become unscrewed and fallen into the body of the amp. Is there a simple way of retrieving it from inside easily?
Yes, it should be as straight forward as gaining access inside the amp, locating the jack and putting it back, however make sure it is unplugged from the mains! If you are unsure if you are up to the task you should take it to your local technician as this will be an inexpensive fix
My Marshall 4502E Amp switches on fine. However when you flick the STANDBY switch on it blows the 1.3A Fuse every time. Any solutions, baring in mind I have checked all the diodes, resisitors, rectifiers...
I would first check the filter electrolytic caps for shorts...
This is the WAY you work on this problem. Replace the fuse and put a 60 or 100 Watt incandescent lamp in series with the HOT power wire. This acts as a current limiter/automatic resetting fuse and you can search out where the current is going. Old trick we have used for more than 50 years. Also using a Variac to control the voltage can be useful, but the lamp should get you through the problem...
Feb 10, 2011 | Marshall Amplification Marshall MG250DFX...
I have a Marshall TSL 601. I recently re-tubed my the amp with new Tung Sol tubes and biased per factory specs. With the new tubes installed in both the preamp (12AX7/ECC83's in V1, V2, V3, and V4) and...
First thing is that if you bought MATCHED pairs of the EL34's a COMMON mistake is to install the pairs wrong. Correctely install a pair as the OUTSIDE tubes of the line and then the remaining pair as the middle two tubes of the line of tubes before biasing.
Funny thing, I just ran across this problem you have with a Bedrock brand amp that uses the same configuration as your V3 tube does. This is really a stupid configuration engineering wise as they tie a plate at high voltage to the grid of the second stage in the tube as a cathode follower, This means that the second section has the cathode at a reasonably high voltage relative to the heater with wide audio swings on it as well... Tubes are NOT designed to work that way and result in noisy behavior, One would have to select tubes that have very low heater to cathode leakage in the second section of the tube... What you are seeing is the result of very poor engineering practice. Marshall is probably testing tubes for the leakage and branding them as such...
I think that designers of this circuit have NOT had experience with tubes and have applied transistor type designing to this use... it is plain stupid and myself I would re-engineer the circuit if it was mine or build a tube tester capable of measuring the heater cathode properties to select a suitable tube to use.
Jan 29, 2011 | Music
Greetings. My MG 250 DFX Marshall 100W amp behaves strangely... I had some problems with it lately. I've been using it for a few years in my flat, so it has not been used extensively in terms of power...
I believe the design of this results in what you are seeing... Check each speaker INDIVIDUALLY plugged into the MAIN output as plugging into the second jack shifts the tap of the output transformer to the 4 ohm tap which results in a 6 Db drop but now you have two speakers... the apparent level change will be almost unnoticeable.. Do comparision of the speakers individually using the MAIN jack. This is just the characteristics of the beast...
Jan 11, 2011 | Marshall Amplification Marshall MG250DFX...
Marshall DSL 401 runs fine for about 10 minutes from cold then starts to crackle and sound disappears The amp is fairly new with not a lot of use
if this a tube amp then your tubes might be going bad. but if it is a solid state amp then im not to sure whats going on.
Mar 01, 2010 | Marshall Amplification Marshall MG250DFX...
Marshall DSL 100 - volume fades away and gradually comes back on
IF this is a vacuum tube unit, these symptoms are that of a tube that the heater is intermittent, that is it cools off due to a break and then liights again.
Open the back and observe the heaters in the tubes. DO NOT be fooled by some that have TWO heaters in them. (use a mirror if necessary) A single one that comes and goes can cause the problem and the voiration can make it come and go. This behavior in a tube is NOT somthing readily spotted in a tube checker. The delay in fading and coming back would be the delay in warm up following a heater going out and cooling.
Feb 14, 2010 | Marshall Amplification Marshall MG250DFX...
Left input for loudspeaker is dead? speakers both work out the left but neither on the right. can I fix it myself? marshall mg250dfx thanks
It sounds like the speaker output jack is broken or it has come unsoldered from the circuit board. You can fix this if you have enough electronics experience but you have to be very careful as components in an amp can carry a lethal charge even after being unplugged. You can partially discharge the capacitors by unplugging your amp from the power source with the speaker plugged into the working jack and set at a low volume while turned on ( not on standby ). If you feel at all uncomfortable attempting the repair yourself you are far better off taking it to a repair shop preferably one with experience with Marshalls. The same is true for other brands as well. Please let me know if this helps.
Nov 18, 2009 | Marshall Amplification Marshall MG250DFX...
If the tubes are not lighting, either the fuse has blown or the power transformer might have an issue.
Be vvery careful as there are lethal voltages present in these.
If the fuse blew, replace it and try just once as there could be other problems and more damage could be done.
Sep 29, 2009 | Marshall Music
Car Audio & Video Logo
179 people viewed this question
Top Marshall Car Audio & Video Experts
xxxxxx xxx
Are you a Marshall Car Audio and Video Expert? Answer questions, earn points and help others
