Question about Whirlpool Washing Machines
Cant find the filter
The hot water on my whirlpool is just a trickle the cold flows fine. iwas going to check the filter but cant find it.
  • 130 Answers
Check your hoses first. they have sediment filters in them, then check your water inlet valve, that is where the hoses hook to you machine.
Posted on Feb 06, 2009
  • Chad Light Feb 06, 2009
    check your hoses first. they have sediment filters in them, then check your water inlet valve, that is where the hoses hook to you machine.
When the water is set to cold it trickles out but when set to hot it flows normal, I have checked both water lines and they are fine going into the washer
When you had the water lines off the unit did you check the filter screens where the hoses screw on? .Their are screens in the washer inlets to keep crud out the washer.These screens can be carefully removed cleaned and reinstalled .The cold side is always the one to cause the problem because the hot side most of the crud has settled in the hot water heater If for some reason that did not fix your problem you will need to replace the inlet valve solenoid assy. Hope this Helps GOOD LUCK
Sep 04, 2010 | Washing Machines
The cold water trickles. There is a "good" flow of water (hot&cold) to the machine yet, the cold water trickles out on any cold setting. The hot water has great flow. What could be the answer?
Sounds to me like your inlet valve is gunked up. You will need to replace your inlet valve. I would also check your hoses first to make sure the cold water hose does not have a screen on it that is full of calcium deposits. Hope this helps _MJ_
Aug 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Cold water trickles into the tub while it is being filled up
The hot and cold water supply hoses that connect the washer from the water supply faucets on the wall to the water connections on the back of the clothes washer usually have filter / sediment screens within there connection fittings at the end of the hoses, these will collect dirt,sand, calcium deposits, etc.,when they trap enough of these materials they will plug up and restrict the flow of water into the clothes washer. Turn off the water faucets at the wall, and you should do this for both hot and cold hoses, disconnect the hoses from the washer and the water faucets, look into the hose ends and pull out the screens and clean them out by running water and what ever you can use to clean them completely!!!!!
Now look inside the water connections on the back of the clothes washer,where you screw the hoses on the washer, and check to see if there are filter screens in there, if there is, remove them and clean out completely also, then reverse the removal process and reconnect the hoses, makeing sure to connect the hot and cold hoses to the right connection on the back of the clothes washer!!
Try filling the washer with water to see if you have corrected the problem.
Make sure hot and cold hoses are correct on the back of the washer!!!!
GOOD LUCK !!!!!!
Aug 03, 2010 | Whirlpool Washing Machines
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
The cold water fill just trickles, I removed filter it was not clogged, hot water runs fine. I checked water flow at faucet, I checked for kinked hose. Did not find any obvious problem. Is there a check...
Good day,
The washer has a dual valve, Hot and cold. The cold side has failed. Valve needs to be replaced. Very common problem.
Before changing, turn off cold water supply, remove cold water hose at the machines valve, and turn on to check for proper pressure.
Dec 04, 2009 | KitchenAid KAWS850L Top Load Washer
Slow cold water flow won't go back to full flow
I think the water inlet valve is nearly stopped up with sediment in the screen filter where the supply hose screws to the valve.Cut the water off at the hose and disconnect and look for the screen. The hot water usually doensn't do this because the water has time to settle everything out while it's in the hot water heater.
Aug 15, 2009 | Washing Machines
Cold water just trickles in. Water flow up to the
Hello, this is going to be a problem with your inlet valve, First thing to do is remove the inlet hoses from the valve and check the filter screen on both the hot and cold for debris blocking the water coming into the machine. If this is clear then your going to have a blockage inside the valve. Since these valves are factory sealed your not going to be able to clear the blockage, you should replace the valve. Hope this helps...Thanks for using fixya!!! Good Luck!! Mike
Aug 02, 2009 | Kenmore Washing Machines
Cold water will only trickle into washing machine
Check your water pressure if thats good check the screens on your hoses, if thst good go to the water inlet valves that allow water into your tub
Jun 09, 2009 | Washing Machines
Washing Machines Logo
153 people viewed this question
Dan Webster
Dan Webster
Sal De
