Question about Garmin iQue M5 GPS Receiver
Garmin iQUE M5 antenna broke off
Windshield mount came loose and dropped unit, breaking antenna off. Garmin says they don't support it anymore. Their answer - buy another unit. Does anyone know of a repair shop in U.S?
  • Anonymous Feb 06, 2009
    YOU CAN BUY THE EXTERNAL ANTENNA FOR ITY FOR 30 DOLLORS OR SO THAT IS WHAT I DID. BUY IT FROM THEMPART  #010-10702-00 FROM THEM DIRECT
BUY A EXTERNAL ANTENA PART #010-10702-00 FROM GARMIN IT PLUGS INTO THE UBIT ON THE TOP WHERE THERE IS A RUBBER CAP
Posted on Feb 06, 2009
I have a Garmin 3600. When I want to use the GPS feature, and I open the antenna, all I get is Acquiring Satellites, but nothing happens (the little indicatior on the bottom shows activity). I thinkthere...
If you can obtain an external antenna from another IQ3600 user it
will plug into the connecter on the top of the unit and bypass the fold out antenna. I had to buy one because the windshield in my Pont Montanna would block the satalite signals. When I plug in the external antenna I do not have to fold out the antenna on the unit.
That will check to see if the unit is recieving and /or if the fold out
wire is broken. The external antenna is not Garmin specific but the
plug on the end is so another gps antenna with the same end plug works.
Aug 16, 2010 | Garmin iQue 3600 GPS Receiver
Garmin iQue M5, Not aquiring satellites
Two possibilities - Antenna (in power cable) or electronics related to antenna. First, do a hard reset. Place the pen top into the RESET hole for 3 seconds...
Next, when the unit is powered, page over to the screen showing satellite signal strength....
If NONE appear within 1 minute (and you are outside and NOT under trees), you have an antenna or antenna interface issue.
Garmin WILL repair the unit for 3 to 4 times its value... A 265WT GPS is cheaper, faster and more accurate. The IQUE is no longer worth repairing....
-Jim
Apr 07, 2009 | Garmin iQue M5 GPS Receiver
IQUE M5 Antenna broke off
BUY PART NUKMBER 010-10702-00 FROM GARMIN IT IS A EXTERNAL ANTENA THAT PLUGS RIGHT INTO THE UNIT.
Feb 06, 2009 | Garmin iQue M5 GPS Receiver
I would like to get routable map of Thailand that could be used on my Garmin iQue M5 PDA.
I only needed a simple answer to the question of whether the iQue M5 would take a Thailand Map. Actually, I waited for twenty minutes on the special Garmin line for this discontinued product and gave up, deciding that it probably wouldn't work.
Sep 19, 2008 | Garmin GPS
Garmin iQue M5
I had mine fixed by a GPS Repair Service, they also have a gps repair guide if you want to try a self-repair.
Aug 14, 2008 | Garmin iQue M5 GPS Receiver
Garmin IQue M5
Make a sprite backup to an SD card before changing battery. If you lose data just restore it from the backup.
May 31, 2008 | Garmin iQue M5 GPS Receiver
Garmin ique m5
eBay should have some, though they may be used.
May 24, 2008 | Garmin iQue M5 GPS Receiver
Internal antenna
mine does the same thing....i even have the external add on antenna, mine turns on fine but as soon as you flip the antenna up on the back, the screen starts flashing and the system keeps rebooting over and over again...
May 11, 2008 | Garmin iQue 3600 GPS Receiver
Cant get it to work
If this is an IQue 3600 then you will need to install the Palm Desktop from your original IQue disk in order to sync with your new laptop. The Microsoft active-sync is for a PDA using Windows (Garmin M3 and M5 are windows based PDA w/GPS).
May 09, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue M5 GPS Receiver Logo
112 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
