Question about Epson Stylus Photo R260 InkJet Printer
I can't remove jammed paper the size of #10 envelope
  • lynn1955 Apr 04, 2009
    My Espon R260 says I have a paper jam, I have removed paper,bits and pcs. turned off the printer and computer, unplugged it, still the lights flash.
  • 1,602 Answers
You will have take the machine total apart and clean the machine, clean the rollers, reset the machine
rod
Posted on Feb 06, 2009
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
When I print a document the paper gets pulled to the right hand side and jams. I tried about ten sheets and it does the same thing...
Take a look in sheet feeder for something who blocks the paper.In case you don't see anything printer must be dissasembled because in most case object who blocking the paper is under the rollers.
Oct 21, 2009 | Epson Stylus Photo R260 InkJet Printer
Epson R260. Brand new. Green light blinks, red stays on.
https://www.manualslib.com/manual/357821/Epson-Stylus-Photo-R260.html?page=55#manual says Epson's manual thinks Red
paper out light ) is on and green P power light flashes means
If you're printing on paper, your paper ran out or multiple
pages have fed at once. Make sure you push the tray lever
up to set the front tray to the paper (lower) position. Then,
load more paper and press the ) paper button to resume printing.
If you're printing on a CD or DVD, the CD/DVD tray is not
inserted. Follow the instructions beginning on page 27 to
insert the tray, then press the ) paper button.
Nov 06, 2017 | Epson Stylus Photo R260 InkJet Printer
Can the Epson Stylus Photo R1800 print on envelopes?
yes all sizes of envelopes using Microsoft word i have printed on 100mm square paper but only documents
Feb 20, 2009 | Epson Stylus Photo R1800 InkJet Printer
PAPER JAM HP PHPTO SMART 2710
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer........ Still have the Same Problem.... Check for any foreign objects stuck inside the Printer............If Not...... Call HP at: 800-588-3554 And get the Printer Replaced
Jan 28, 2009 | Epson Stylus C46 InkJet Printer
Epson Stylus Photo R260 doesn't complete prints
Make sure that you have the correct paper size set in your printer settings. Incorrect size would cause the problem you describe.
Sep 17, 2008 | Epson Stylus Photo R260 InkJet Printer
Printer will not print
Firstky u need to make sure that the printer drivers are nt corrupted, i wuld suggest u reinstall them, make sure u do nt have any paper jam, check 4 small paper pieces inside, listen if the printer tries to pull the paper in.
Feb 22, 2008 | Epson Stylus Photo R260 InkJet Printer
Printing an envelope in cs3 on an epson stylus photo r1800
You can try using Microsoft word in printing on envelopes, it is easier. On my MS word>tools>letters and mailings>envelopes and labels>click on feed and use the fourth from the left option.
Load the envelope at the right side of the printer> the envelope flap should be on the left facing the printer.
Jan 25, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R260 InkJet Printer Logo
151 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
