Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Remote/homelink and touchpad problem
Hi. I have the Chamberlin openers (2 of them). I also have remotes, and a keypad mounted outside. Finally, I have homelink in every one of (3 of them) my cars.Here's the problem I have. I can either get the keypad to work, or my remote transmitters to work, but not both of them. It seems that when I program the touch pad, my remote stops working, but the touchpad works fine. If I program the remote (and subsequently the homelink in the cars), then the remotes and homelink transmitters work, but not the touch pad. Please help!!!
  • AmyJoMac Mar 25, 2009
    I have a Lift Master garage door openner and a Clicker brand wireless keypad mounted outside the garage door. I can either have the keypad work, or the HomeLink function in my car work but not both. What gives?
  • clarkco2002 May 11, 2010
    what model opener is this on?
    let me know
    clarkco
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
Your keypad is not the same "generation" as your remotes. You operator will work with your security plus remotes or your old keypad but not both. Yor cheapest solution is to replace your keypad.
Posted on Feb 07, 2009
  • David Warner
    David Warner Nov 21, 2012
    Thanks for your information Joseph.
How do I program a 2004 Ford Explorer (Eddie Bauer edition) automatic garage door opener?
Download the owners manual in PDF, and search for homelink. The instructions are somewhat long, so this would be an easier route.
URL for Ford's PDF version of owners manuals :
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
The outline is train a remote to the visor ( so the homelink gets the base code ) and then train the button on the homelink to the opener ( the visor has a different shared code, so it is a 2 step process ).
Takes about 5 min to do. Also make sure you do not have more than 6 remotes on the door you are programming, else it will push the 1st one off ( usually the case with Chamberlin, your mfgr could be more or less )
Oct 25, 2010 | 2004 Ford F150
How to program in the 3 pre sets for garage door openers We have a 2001 dodge grand caravan es
Hope this a Homelink. Put new batt in garage door remote. Park outside garage. #(1) Press & hold 2 outer buttons on Homelink. Release ONLY after light starts to flash. Don't hold for longer than 30 sec. Don't repeat to program the other 2. #(2) Hold the remote 3 inches from Homelink. #(3) Press & hold the Homelink buttom & the remote button at the same time. #(4)The Homelink will begin to flash slowly then rapidly. After the Homelink flashes rapidly release the buttoms. #(5) Press the just trained Homelink button if the light stays on constantly, programming is complete..... To program the other 2 links DO NOT REPEAT #1
Jan 10, 2010 | 2001 Dodge Grand Caravan
Craftsman 1/2hp garage opener Homelink must be under unit to work
Have you tired reprogramming the remotes to the opener?
The opener receiver board may have failed, which happens. You can order a new one from Sears or other places on the Internet, and they are fairly easy to replace.
Once replaced, you will need to program the receiver to you remotes again.
Dec 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
We have Craftsman 139.53684 gargage door opener with 2 remotes. Both remotes programmed and respond. Issue is after programming the 2 remotes, the homelink in the vehicles no longer respond. Can you not...
You must have an older vehicle or the homelink has reverted to an earlier technology and you will have exactly the situation you describe. You will just have to use the remotes that came with the opener.
Nov 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can i program homelink with out a remote
The only way to program Homelink without a garage door opener remote is if you have a keypad that allows access to your garage. I tried EVERYTHING and then realized I had the keypad which is wireless; I simply unscrewed the battery operated keypad from its location and held it 1"-3" from the Homelink buttons in my car. I then punched in my code and held the enter button on the keypad at the same time as the Homelink button I wished to program. It worked flawlessly. Good Luck!!!!
Jul 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
HomeLink works in vehicle... unable to program hand held or remot
When did your remote and keypad quit working? Was it when you programmed the Homelink? It sure sounds like you have a bad logic board.
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
I can not hook up Honda odissy 2007 Homelink system with LiftMast
Yes. But you need a remote transmitter that is programmed to open the Lift Master. Then you just follow the instructions in your home link and it should work.
Press the homelink outside 2 button at the same time and hold till fast blinking (all erased). Then press homelink button1 and hold while aiming the transmitter (2 inches away) and pressing appropriate button on the remote. Continue to hold both till fast flashing seed on the homelink. Release both. Then hold the next button on the homelink you want to program, aiming the remote again, and pressing and holding the appropriate button on the remote, until fast flashing, and then releasing again, ......
Feb 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
973 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
