Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Light in color and won't copy dark. It come out light purple
Pictures have tiny squares on it and is light in color and purple. When I copy it comes out light purple and can't hardly see it.
  • 191 Answers
You may try
1) color ink cartridge--- no enough ink or the cartridge ink channel dryer and constipated, refill ink and put down the cartridge bottom surface to water a little for 1 hr, then set back. or change a new cartridge if not fixed go next
2) print head--- the ink channel dryer and constipated, take out print head clean it's ink channel using cleaner or steep in water (do not touch circuit pin area with water) 20 minutes or longer. then set back and test (you can do more times), still not fixed, your print head have to change.
Posted on Feb 07, 2009
  • Frank Zhang
    Frank Zhang Feb 08, 2009
    you may try this comment if solution #1 tough
    1) do clean nozzle cycle (do more times) until print normal
    2) clean the color ink cartridge wicks using soft paper, still not fixed go next
    3) clean print head nozzle area, power on and open top cover,the cartridge moving away the parking lot and then pull out power lead, and put a soft paper with a little solvent (making it quite damp, but not totally soaked)
    on the parking lot (see the pump cap area with spongy pad covered in ink and match the lot size same), manually moving the carriage (slow and very careful) to the parking lot ( the paper will raise upto print head) to stay 10 minutes then gentlely
    moving away the parking lot, you may look what color down to the paper, do same thing untill to see three color and black appear on the damped paper.
  • Frank Zhang
    Frank Zhang Feb 10, 2009
    any help for you please send a feedback thanks
My paint is too light want to change from light purple to dark purple
You can go to your local store that sell s paint and buy a darker tint for just a few $$$
Aug 18, 2014 | Valspar Corporation Valspar Signature...
All pictures come out dark, no matter the light
What model K-M camera? What exposure mode(s) are you using?
Dec 04, 2013 | Konica Minolta Cameras
My Nikon D70 is producing pictures in purple, both on the camera and when printed. What is the problem?
Hi there:
Some symptoms of a defective CCD (Charge Coupled Device) include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value.
I suggest you phone Photo Local support and tell them the problem and that you suspect the CCD.Ask for a repair quote for a CCD replacement.If the product is under warranty.
Click on or copy and paste the link into your browser... CCD Sensor Problems
In this link, other owners with this problem obtain certain commets:support/canon_fs100_fully
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 21, 2012 | Nikon D70 Digital Camera with 19-35mm Lens
My Olympus x-42 doesn't take a picture. View from monitor is perfect but when I take a picture, all there is is a white screen
Hope this helps.
Aug 15, 2012 | Olympus X-42 Digital Camera
When taking pictures there is a color displacement of some sort. Leaves like bright purples and pinks shadowing images.It is worse in lighted areas, the more sunlight/bulb light the worse the coloring...
The term for an out-of-focus purple "ghost" image on a photograph is "Purple Fringing."
This is fairly common in Digital Photography.
In order to minimize instances of purple fringing you may incorporate the following:
Avoid shooting with big aperture (Small /f number) in high contrast compositions.
Avoid overexposing highlights (e.g. bright sky behind dark objects).
Shoot with a UV/Skylight Filter or a Circular Polarizing Filter. These protect the lens and also help to Get bluer skies and cut glare off reflective objects.
You could also use Post-processing to remove purple fringing by scaling the fringed color channel. This can be done in an image editor like Photoshop.
These suggestions will help in minimizing the instances of color displacement for you.
I will look forward to your feedback and positive rating.
Sep 11, 2010 | Sony Mavica MVC-CD500 Digital Camera
Pictures turning out dark, LCD not adjusting
CCD sensor problems usually present themselves as either a blank image, purple cast, or lines through the image. Incorrect exposures are usually a result of the lens shutter failing to open and close correctly. Typically, the lens is not servicable and they need to be replaced.
Apr 13, 2009 | Canon PowerShot A95 Digital Camera
Old pink and purple bathroom needs help.
The consensus here is a medium to pale/light blue - black or dark blue would blend better, but it would be one darn dark bathroom. You want something that blends, not accentuates the purple.
Hope this helps :)
Mar 10, 2009 | Samsung HCN653W 65" Rear Projection...
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Purple lcd display
Hello tonyj111, If your old pictures look fine on the display, then the problem is related to the ccd sensor itself. The purple color is displayed because of a problem in the signal transmision from the ccd sensor to the camera's main processor. This is done using 3 channels one for each primary color (RGB red green blue). If the connector to the sensor is broken, or got out of place (loose) because some mechanic shock or symilar, the data processing woun't come out right. It is purple because your camera's processor mess up blue and red signals therefore resulting same purple instead of blue or red colours. In order to fix this you will need to either send the camera to a service center to have those connections checked (if your camera is still in warranty you will want to do this) or ask me for further instructions if you wish to try to dissasemble the camera yourself. In either way the problem is fixable and in most probabilities a cheap fix will work. Good luck
Jun 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
104 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
