Question about HP L1706 17" LCD Monitor
HP L1706- screen is blank when I switch on
I cannot get my HP L1706 monitor to switch on. The screen remains blank though the computer seems to be working and I can hear the welcome sound on windows. The power button of the monitor will also not stay on, but wll light up green only when I press it. Earlier it would blink for a long time and then the screen would light up. Now it's not even blinking and absolutely nothing in showing on the screen. Help!
  • 1 more comment
  • mowjowjowjow Feb 20, 2009
    I also have the same problem. I already check by using another monitor and the computer works perfectly. I also tried to remove the memory and installed again, but the LCD still won't turn on.
  • Pegay Feb 24, 2009
    i also have the same problem. I already tried to connect the monitor to another working CPU but it still doesn't wok. it also out of warranty that's why I'm trying to figure it out if there is an alternate solution to resolve this problem.
  • chiasw09 Apr 12, 2009
    I have a similar problem. The indicator light blink for a long time before the screen comes out. I have tried the solutions given but it doesnt help. Any other solutions ? Thanks
    President:
  • 1,902 Answers
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Posted on Feb 06, 2009
Help My HP L1706 17" LCD Monitor seems to have a Yellowish/Greenish tint on the screen, How do i sort this problem so that my screen is back to normal setting?
With the price of monitors these days, you can pick up a 19" new for less than 100. Or you can find them used for 50. I would replace it, but if you want to keep it, the go to HP web site and get an user manuel and try to adjust the settings.
Aug 12, 2014 | HP L1706 17" LCD Monitor
Monitor is changing color when power on:- red, green, yellow, violet, white, blue etc......repeating continuously ...... more tha ten times switch off monitor but the problem remain the same... VGA...
1706,
the monitor is bad if OSD , menu shows bad colors
try the reset in the OSD menus,,
google, HP L1706 manual, read it.?
some newer hp monitors even have test pattern in the OSD pages. (on screen display) try that.
Oct 04, 2017 | HP L1706 17" LCD Monitor
Hi, My LCD montitor does not power up. The screen is blank even though the power goes through. There is no sign of power even on the switch. how do I fixx this problem?
If it is plugged in, and you have turned on the on/off switch, look for a reset swtch on back. If none, then possible blown fuse inside case. Make sure the power supply is turned on, if you have one.
Apr 21, 2010 | HP L1706 17" LCD Monitor
My hp l1706 wont stay on it goes blank after a few sec when turn on please help me out how can i stop this
huntpercell, You won't !! The unit's "switch-mode-power-supply" is in what is known as "SHUTDOWN" mode because it has detected a FAULT with itself or the "cold-cathode-fluorescent-lamp's" electronic ballast circuit which is called the INVERTER circuit which changes 12-15volts DC to 800-1200volts AC to light-up it's CCFL's to produce WHITE LIGHT so you can see all the pretty colors on the LCD panel!!! Do this test!! With KNOWN GOOD pc fully booted to WIN-desktop, reconnect l1706 to pc and wall outlet. Then and only then turn on the l1706. Make note of how long it takes to go to BLACK or BLANK screen. After screen shuts down then hold a bright flashlight 1" from the screen at different angles, looking very closely to see if the desktop is still being displayed very faintly even though the screen appears to be BLACK! Tell me what you see or don't see! If you don't see the desktop then SMPS is in total shutdown. If you see the desktop the SMPS is in partial shutdown but is still able to source +5 or +3.3v dc to the VGA/LCD interface board to send information to the LCD panel. You have just performed THE FLASHLIGHT TEST that every owner of a CCFL backlit LCD display should know how to do! Now here are your options as a CONSUMER / USER of a LCD display whoose screen is now dark and lifeless. 1. Trade it in for a NEW one. $$$$ 2. Swap-out unit for manufacturer refurbished unit. Cash +old unit. $$$ 3. Repair/refurb unit locally at TV/monitor shop. $$$ 4. Effect a repair on your own with info acquired via web. $ or poss $$ If 4 is of interest then get back to me. I will tell you of some good sites to visit. If you found this information helpful, please rate this on fixya. I'm louie12fix on fixya or lmistyrel@aol.com Bye.
Oct 12, 2009 | HP L1706 17" LCD Monitor
Blank screen, but has power
It is most likely a backlight that has burnt out or something else of the sort. You will want to call HP Support and explain to them of your troubles.
Aug 17, 2008 | HP L1706 17" LCD Monitor
Screen is now a weird color
Your video cable has a broken pin inside. Check the cable at the videocard end (bend it in different directions) and do the same at the monitor end. It should become normal, then it's just a case of keeping it in the right position or replacing the video cable.
Hope it helps =)
Jan 06, 2008 | HP L1706 17" LCD Monitor
HP L1706 monitor
your monitor is getting ready to kick the bucket.
Oct 31, 2007 | HP L1706 17" LCD Monitor
HP L1706 17" LCD Monitor Logo
1,070 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
