ON my C424 xerox machine is red light flashing and is not working
After pressing ? is written error39 012,40:4175What should I do, please?
  • 1,602 Answers
Call techincail support or go on line and type the following information:
xerox c424 error code 39 012
"" "" 40:4175
enter for each one
follow the instruction to the letter
rod
Posted on Feb 06, 2009
    President:
  • 1,257 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Follow this article to fix the issue..
http://www.windowsguru.org/solutions.html
Posted on Jun 27, 2009
Xerox Phaser 8200 goes through post then hangs.
Sounds like a RAM problem. Go to the back of the machine, You will see  2 large, thumb Screws, Twist them about half a turn and remove the main board. Remove and reinsert the memory stick. If that does not fix it the main board or the electronics module has probably failed.
Mar 03, 2010 | Xerox Phaser 8200 Laser Printer
There are 3 lights on the xerox 1020 first one
you replaced the drum too soon, replace old drum until red light flashes then install new drum.
Jan 22, 2010 | Xerox Office Equipment & Supplies
Xc 1040 xerox Red light is flashing and the copier will not
On a XC 1040 machine either there is a jam on the fuser, the fuser switch fell out of place, or the sensor swich arm fell off the registration sensor.
Since we cannot see the machine we might understand what is taking place.
If the machine is turned off and back on and there is no red light, then the machine must be able to attempt to make a copy. If a copy does not come out, then there is problely some worn feed rolls.
If when the machine is turned on and there is a red light then th There can be some bad paper feed cluthes as well.There might be a paper stuck at either fuser assemly or paper feed roller areas.
Provide more description about the visuals on the machine.
Good luck.
Jul 15, 2009 | Xerox WorkCentre 4118 Network Kit...
Xerox FaxCentre F110, both red and green light on
Did you ever figure this one out? I'm having the same issue
Feb 23, 2009 | Xerox FaxCentre F110 Plain Paper Laser
Won't copy
You have either dirty or worn out feed tires. Try taking a cleaner like fantastic, formula 409 etc and clean them well.
If you need , google a business called " the parts drop". Give them a call and talk to Britt or Joe. They will have those at a fair price.
I don't work there, but have not found a better Xerox parts dealer anywhere.
Jan 13, 2009 | Xerox WorkCentre XD120F Laser Printer
Xerox xc830
it does sound like the toner cartridge is empty or bad.
Apr 18, 2008 | Xerox 8830 Copier
Xerox Phaser 6110 - what does continuous red light mean ?
Lemmor, without being rude it sounds like you know nothing about this machine at all.
The printer version of this machine has 5 lights in total. 4 of them refer to the toner carts (flashing means toner low, on solid means run out) the other light (the status light) can mean many things. The most common problem people overlook with red status light is that the waste toner bottle is full and needs replacing. It can mean lots of other things depending what colour it is and whether it is flashing or not. These can all be found in the user manual, or if the status monitor has been installed (usb connection) it should show on the PC screen. With a network install, you can browse to the machine using it's IP address to see the error message.
Feb 02, 2008 | Xerox Phaser 6110 Laser Printer
Paper feed problem
please check if the rubber roller that pulls the paper inside the machine check if it is clean because after long use this roller becomes so smooth ddue to dust and doesnt take in the paper , first clean it ,wipe with wet towel  try again
Oct 27, 2007 | Xerox 5305 Copier
77 people viewed this question
jasbo
jasbo
