Question about Microsoft Windows XP Home Edition
Can not update windows.
I did a system recovery (not restore, recovery). Now want to update XP and windows update will not run.
Automatic updates will not run.
  • DYZAN59 Feb 10, 2009
    can you help me with the same problem everytime i open my computer an alert in a tray say like this your auto update is disable click the baloon to fix this problem so upon clicking it will go to the security center to click on the auto updates but the problem is it doesn't work because most of the time my P.C. hang ...thanks if you can me about this aprreciate your support
  • Ron
    Ron May 11, 2010
    Did windows updates work at first and then stopped working after some updates were installed?
  • 73 Answers
Try Dial-a-fix. Best solution to Windows Update problems I've found.
The interface is a little cryptic, but if you read the Wiki you can be up and running pretty quick. Works great.
http://wiki.lunarsoft.net/wiki/Dial-a-fix#Mirrors.2Fdownload_locations.2C_and_articles
Posted on Feb 06, 2009
My computer will sometimes get stuck on MicrosoftUpdates-show
Updates immediately take over if you boot in safe mode?
Try turning the machine off in the middle by just hitting the power button to see if it will go to the Startup Repair screen so you can get to the Recovery Console. Let the startup repair run, then if it says it couldn't fix it, get to the Recovery Screen and see if you can run a System Restore and select a Restore Point (date and time) before the update was downloaded. System Restore does not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the restore point you selected). System Recovery on the other hand Deletes Everything and sets your system back to when you first purchased it.
Try running the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
If after the check disk utility you are still having problems then you might have to reinstall your operating system.
May 16, 2012 | Dell Inspiron 530 -Intel® Pentium®...
How do i restore my Dell Latitude D430 laptop
YOU WILL NEED TO INSTALL WINDOWS FIRST OR USE IT IN AN EXISTING INSTALL. This CD DVD contains every driver you need for your Dell Latitude D430 XP Laptop.
You are buying an automatic system that installs every driver onto your system with minimal user knowledge and interaction.
This recovery disk includes much of the original factory software and utilities.
aND
#1
Depending on the age of your system, we have also included our own emergency driver re-detect software. This will remove and unplug all devices from your system and re-detected every driver automatically removing old and duplicates. This will in effect clean out the side of your registry that deals with hardware. No other restore disk has this software and can claim to clear your system hardware drivers.
#2
Some of our restore disks have an automatic system driver update included!
There are many applications that allow you to automatically update your drivers. These applications scan your system and the automatically download and update your drivers.
We are rolling this feature out in all our recovery cds over the next few months
Apr 11, 2010 | Dell Latitude D430 Notebook
How to remove genuine advantage validation tool
format....thats the only way for me...
you already updated your computer...
there is no tool that you can downgrade your pc if you have already updated it.. except you have deep freeze...
Feb 06, 2010 | Microsoft Windows XP Professional
May ask...how to install the new updates windows cause every time i try to install it...it didn't install properly???
1. Stop the Automatic Updates service:
Start > Right-click on Run and select Run as Administrator > (type) services.msc > [OK]
Double-click Automatic Updates > Click on Stop
(Stopping the service will take a moment)
2. Delete the contents of the Download folder:
(type or copy/paste) %windir%\SoftwareDistribution > [OK]
Open the Download folder and delete its contents
Close the window.
3. Start >> Control Panel >> System And Maintenance (If you are using Classic View, skip this step) >> Windows Update >> Select updates to install: Right-click on Update for Windows >> Click Hide Update >> Confirm the UAC (User Account Control) prompt, if appropriate, & OK your way out.
4. Start the Automatic Updates service:
Double-click Automatic Updates > Click on Start
To restore/unhide updates in Windows: Start >> Control Panel >> System And Maintenance (If you are using Classic View, skip this step) >> Windows Update >> Restore Hidden Updates | >>Find and select the update you wish to install >> click on Restore. You can now reselect it and install through the normal process.
Jan 31, 2010 | Computers & Internet
This computer did not pass genuine windows validation test.
It really is a nuisance for users with genuine products. This has also occurred to many people with MS Office 2003. It could however be caused by someone installing XP or Office that used a Corporate License that will require updating in a different way and not via the MS Auto Update procedure.
You can simply uninstall the MS update check that does the validation or return you machine to a known good state via the system, restore function. Look at your system history to see which update you need to uninstall and avoid reinstalling next time you get the option. So turn off auto updates and then make sure you control which updates are applied.
Also call the store where you bought the system if they are still in business.
Sep 12, 2009 | Microsoft Windows XP Professional
No audio from external speakers
To find out if it's the windows update that did it, you could to a system restore. Press the start menu -> Programs -> Accessories -> System Tools -> System Restore. Then you choose Restore computer to an earlier time. This will give you a small calendar, which have some numbers in bold font. Choose the latest restore point.
Jul 21, 2009 | Dell Computers & Internet
AVG will no install error 0x800736b1 also retrirve my desktop
Hi there. My name is Alex and Im here to help solve your problem
First of all, AVG has always had a problem installing when windows updates are enabled and download and install automatically. I would recommend uninstalling all updates that have been installed to your computer and disable automatic updates which I will explain to you below
To uninstall the updates.
Click start, settings and click control panel.
On the icon add and remove programs, please double click
You will now see all the programs and updates installed on your computer. The microsoft updates are located near to the bottom of the list and there may be a lot of them installed. You can only uninstall one update at a time. You may be prompted that uninstalling a windows update may cause a program not to work properly, this is normal so you can continue uninstalling them. When you have uninstalled these updates please restart your computer.
To disable the automatic updates
Right click on your icon My computer or My pc which is located on the desktop or on the start menu (if you are running windows xp) and select properties
You will then see a sub menu called 'Automatic updates' and inside this menu you will have the choice to disable the updates
If you are using windows xp and you have system restore enabled on your computer, then you will be able to take the computer back to an earlier time when it was working correctly. Please save all documents first to insure that nothing will be lost if you decide to do a 'system restore'. There is a very friendly wizard to help you restore your computer. You can get to the system restore by clicking start, programs, accesories, system tools and selecting system restore.
Regarding your problem about your desktop disappearing, to restore your icons on the desktop, right click anywhere on the desktop and select organise icons and be sure that the heading 'show desktop icons' is ticked. This will restore your desktop items
Last of all try installing AVG, if you still experience problems with this issue, then please let me know. Im happy to help
Oct 10, 2008 | Computers & Internet
Updating...
Sounds like the automatic updater has glitched. Start by trying a system restore from the system tools in the accessories section of the start menu. Go back to a point about a month or so back. However, since this is integrated into the operating system you may need to run a system repair with your recovery or operating system disc, if the restore doesn't clear up the problem.
Jul 29, 2008 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Windows update not working and system restore cannot be enable
Download Dialafix and select Fix Windows Updates.
Jun 02, 2008 | Computers & Internet
Not Installing XP SP3 Updates Given By Microsoft KB 936929.
if you don't want to install those updates you should have switch off your automatic updates. the problem is the your computer might not be compaitble with the update which was sent to you.XP SP3 have a higher system and hardware requirements than xp sp2. in order to resolve your problem you need to run your xp sp2 and press repair instead of format in this way it can return to your original system. you can also try the system restore press the start, all programs look for the system tools then system restore check what date you installed this sp3 then select the day before you installed this in order for you to return to your original operating system. hoping that this will help you, expecting your positive response.
Dec 14, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Home Edition Logo
64 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
