Question about Kodak EasyShare DX6490 Digital Camera
Camera will not turn on. As I rotate the selector switch the light flashes at each position. Even when I switch it to off the off light flashes on and off. The screen stays on but it is blank.
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello, Did you try pressing the little silver button marked "EVP/LCD" it is located at the left of the view finder,This turns the screen on and off.
Hope this takes care of problem.
Best Regards, Russell
Posted on Jan 23, 2013
3 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: When I rotate the selector
I am Sorry to hear regarding the Problem.This is a ' Lens Problem ' which is Quite Common on these Models.
It is not worth to get it Repaired, as the Cost of repair would be quite high as compared to the cost of the new camera.
There are a number of things you can try:
1. Ensure batteries are fully charged
2. Look carefully between the lens and the camera body for any sand or other dirt etc
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 2 minutes and refit
If no luck then we have to try some things that could possibly result in damaging your camera so should only be tried if happy to take that risk...
5. Try thumping the camera into your other hand, by thumping into your hand you are trying to jar the mechanism loose, by using your hand you will hopefully not do it too hard or it will hurt. You may need to do this a dozen or so times in different places to work. I have found the flat of the camera bottom into the flat of your hand best..
6. If the lens is stuck in the out position then remove the batteries and try twisting the lens first one way then the other, do not apply excessive force when doing this or you can break gears, you are trying to reposition not force... Likewise if the lens looks like it is crooked you can try pushing it back into position. This has a higher chance of doing more harm than the thump so please be careful...
7. Dismantle the camera, not for the faint hearted, you need to dismantle the lens assembly into the main body of the camera
If no luck then only other option is a serviceman I'm afraid, be sure to get a quotes as camera repairs can be uneconomical
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 27, 2010
SOURCE: ON / OFF Rotary selector is jaming
I sprayed the stem of the switch with big bath iso contact cleaner and rotated the switch through all positions repeating the sprying and rotating and it helped.
Posted on Oct 23, 2007
How do I turn flash on and off?
The multi selector is the round control on the rear of the camera with the OK button in its center.
The flash mode button is the top button on the selector, it has a lightning flash icon.
Press the flash mode button on the multi selector.
Highlight the desired mode and press the center of the multi selector.
The flash modes are:
AUTO; Flash fires automatically when lighting is poor.
AUTO WITH RED-EYE REDUCTION; Reduces "red eye" in portraits.
OFF; Flash will not fire even when lighting is poor.
FILL FLASH; Flash fires whenever picture is taken. Use to "fill-in" (illuminate) shadows and back-lit subjects.
SLOW SYNC; Flash illuminates mainsubject; slow shutter speeds are used to capture background at night or under dim light
The selected flash mode icon appears at the top of the monitor.
Oct 22, 2014 | Nikon COOLPIX L3 Digital Camera
Err code displayed and fails start
Turn the programme selector dial to the required programme.
The selector dial can be turned either clockwise
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
If you turn the programme selector dial to another programme
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
No 4x4 when turning selector switch to 4x4 position(any position)
What year is the truck ? Probably has DTC'S - diagnostic trouble code or codes stored in the transfer case shift control module. These would point to the problem .
Sep 07, 2017 | Ford Expedition Cars & Trucks
We have installed GM40 time. which control shaft on / off cycle i.e 4 hours on / 2 off. i checked selector switch postion, i.e continuous on (upper position) and continuous off (lower position) in this...
I have GM40 timer sitting in front of me.
I cannot understand your question because I do not know what the 'control shaft' is.
If you mean the black-colored FM1 clock dial with captive trippers, then this dial is supposed to rotate continually as long as timer has power.
http://waterheatertimer.org/images/FM-1-Grasslin-Intermatic-20.jpg
Grasslin/Intermatic GM40 page
http://www.intermatic.com/products/grasslin/electromechanical%20time%20switches/multi-voltage%20time%20switches.aspx
The manual says quote:
With the manual switch in the middle position, the GM40 is in automatic mode and will switch at the programmed times. In the upper position "I", the load is permanently ON. In the lower position, "O", the load is permanently OFF. End quote.
In any switch position, the FM1 clock dial will continually rotate.
If your Load does not turn on-and-off according to the trippers set on FM1 clock dial, then 1) wiring is suspect or 2) if dip switches are not correctly set before applying voltage, and timer could be damaged.
The timer arrives with dip switches pre-set for 277Volts.
You can also manually rotate clock dial clockwise to observe when the load turns on-off.
Add a comment and give more information.
I would like to know what the 'control shaft' is, and what voltage you are using, and what dips switch setting you have, and which wires are connected to each terminal.
Apr 13, 2011 | Intermatic GM40 - 24 Hour/7-Day Dial...
Flash card error appears on the screen and stops the camera from shooting
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory card
Jan 28, 2011 | Olympus EVOLT E-410 Digital Camera
Lamp lights without command no longer open in the minidv box black screen does not play, not record one more thing to do?
Jan 26, 2011 | Samsung SC-D103 Mini DV Digital Camcorder
580ex off camera shuts down after a minute or so of standby
No and no, the flash is by default programed to shut off after 1 minute .If you were using the flash on-camera, the flash would automatically power itself on when camera activity is detected but when the flash is detached, it doesn't wake back up.
To change this you have to turn off the auto shut off in the flash menu:
1. Power the flash on
2. Hold down the back light /C.Fn button until "Fn 00 0" appears on the screen
3. Rotate the selector wheel until you see "Fn 01 0"
4. Press your selector button down so that the 0 begins flashing
5. Rotate your selector wheel to change the 0 to a 1
6. Rotate the selector to the "Fn 14 0" position and set it to 1
7. Press your selector button to save this parameter
8. Press your Mode button to return to the main screen
Now your flash stays on as long as the flash switch is turned on ON, and as long as you have juice in the batteries.
Do not forget to turn off the flash after you are done.You can reverse it anytime, but you have to read the manual for that..
Same setup can be found in the manual
May 07, 2010 | Canon SPEEDLITE 580EX TTL Flash
Canon power shot s3is, picture quality is not good, we have use flash every time. otherwise images are very blurred and dull. what change i have to made to my camera. any suggestions will help full for me
If you can are turning the flash off and on, you are no longer in the "Auto" mode. Rotate the top selector dial to select the green "Auto" position. This will enable the camera to automatically select the best aperture and shutter speed based on the available lighting. It will also decide whether it needs flash or not.
As you gain confidence in your abilities, experiment with the other settings on the dial. May I suggest first trying the "P" program setting. This is similar to auto, but will enable you to turn off the flash during low-light level shots. Still the camera will select the best aperture and shutter speed based on the lighting. But in very low lighting, you may have to keep the camera extra steady (such as with a tripod) to minimize camera shake as the picture is taken.
Sep 27, 2009 | Canon PowerShot S3 IS Digital Camera
Feb 03, 2007 | Kodak EasyShare DX6490 Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
50 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
