Question about Sony Handycam DCR-DVD108 DVD Camcorder
Format Error Sony DCR-DVD108 C:1302
I purchased DVD+RW exact same as last time and this time I am unable to format it. While formatting it stays stuck in the last 1 second, then comes up with a message that is has unsupported format. It then flashes a C:13:02 error messages.
I don't understand since I have purchased these discs before and they worked fine.
What should I do to correct this problem?
Thank you kindly!
  • Bryanshaw Mar 06, 2009
    I have the same issue, but I have tried 7 different disks, all Memorex. I even pulled out old disks that are finalized and have data on them and those wont pull up now either...The camera seems to be running very very slowly also
  • 423 Answers
Hi Lisa,
What you have there is a bad disk. Sometimes that happens. Disks are made in mass and sometimes the company can make entire batches that are "bad". I recommend that you buy a known brand like memorex, although sometimes, they can mess up too. Just try another disk. Thanks for coming to FixYa, and feel free to rate my solution. Thanks again.
Rob
Posted on Feb 25, 2009
How do i set my sony dcr dvd 101 handycam to record on dvd-rw disc
Before using a DVD-RW you must first format the disc.
Here is a link to your manual:
http://www.docs.sony.com/release/DCRDVD101.pdf
Go to page 26 and following for instructions on formatting yor disc.
Thanks for using Fixya.
Mar 05, 2011 | Sony Handycam DCR-DVD101 DVD Camcorder
Format error when i finalise the disk
If a FORMAT ERROR message is displayed, then the inserted disc is not formatted or it is recorded in a different format not useable by the camcorder. If using a DVD-RW or DVD+RW, format the disc prior to use. Otherwise, use a different disc.
Mar 21, 2010 | Sony Handycam DCR-DVD201 DVD Camcorder
Unable to format dvd+rw or-rw
Also I had the same problem. I have solved it by computer.
(1) make image file from finalized DVD (PowerISO)
(2) burn this image to dvd
(3) use camcoder to format that DVD
And next time I didn't get that error.
It worked for me.
Igor
Macedonia
Dec 31, 2009 | Sony Video Cameras
I am unable to figure out how to delete movies from the disc?
You can delete files on DVD-RW disc only if it is not finalized.
If DVD-RW is finalized you need to format it through format option in menu.
DVD-RW ( DVD Re-Writable)
Thanks.
Sep 06, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
C 13:02 dvd-rw mini disc errors
It's not recommended to format a disc in the Computer and use it in the Camcorder.
It seems that there is an issue with the disc.
The disc should be formatted within the Camcorder itself.
I will forward a link to a page where you can get the information regarding the error message appearing on the LCD screen of the Camcorder.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C79466
May 15, 2009 | Sony Cameras
Problem formatting mini dvd+rw disc
The full user manual is available at:
http://pdf.crse.com/manuals/2587623111.pdf
If the procedure fails, the disk may be corrupt but you might try formatting the disk on your pc.
Hope this helps. Please rate reply if it does thanks.
Feb 24, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
I have a HANDYCAM SONY DCR-DVD 106, and I keep getting the following message error - "Disc error. Unsupported format - 13:023, with regard to a mini MEMOREX DVD-R.
Disc error. Unsupported format means that ur camera does not support the format of this disc it might not support DVD-R or DVD-RW and supports the DVD+R and +RW try the other format disc and let me know if it resolved , check the manual it is stated on the box or manual which format it supports, if it does not solve ur problem try some other brand instead of MEMOREX try sony,hp,fuji,philips and see actually these sony cameras they are sometimes locked by the manufacturer to only use the original discs for monopoly sony acts like that in every product
pls do rate me if i fixya problem
regards
Zohail
Feb 23, 2009 | Sony Handycam DCR-DVD205 DVD Camcorder
Sony DCR DVD101 Format Error
I had the same problem, but I didn't have any valueable data on the DVD-RW (which was a Sony brand disc, go figure...). So, I backed up all the videos on the disc, tried to format the disc to get it ready to be able to be used again, and got the whole "Access Error" when I was formatting the disc. I tried both the VR and Video format options, the Video option came back with teh "Access Error" while the VR option came back with "Format Error". I put the disc into my DVD burner in my computer and was going to try and format it manually. But, as the disc popped up in My Computer and I right-clicked on the disc icon, there were no options to format the disc, which is unusual. I tried it in a laptop that's about a year old (versus the other computer which was about 4 years old), and as I right-clicked on the disc, an option was entitled "Erase this CD-RW". Obviously this was not a CD-RW, but I tried it anyways, and bam, after about half a minute, the mini DVD-RW was formatted! After that, I put it in the Handycam DCR DVD101 drive, formatted it using the Video setting (my preference), and now it works.
So, moral of the story is...try and format the disc manually on a DVD burning enabled computer. If it doesn't work, try a newer computer. But that's all I have, hope this helps!
Jul 10, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
DVD RW Format Problem
If you are using dvd-rw, try dvd+rw disks
Jun 06, 2008 | Computers & Internet
Format Error
First option would be to attempt to read the disk in another DVD player, for example on a PC. If that succeeds then transferring the data can be done via the PC. Another thing to try is to reset your Camcorder - refer to the manual to locate the switch and then try again. If neither works then re-formatting is probably the only answer. Always format the disks in the camcorder - not elsewhere.Good luck.
Jun 19, 2007 | Sony Handycam DCR-DVD403 DVD Camcorder
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
737 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
