Question about Ulead Videostudio 8 for PC
XBOX 360 NTSC only Black and White
Hi, I am trying to capture video from my XBOX 360 via the EasyCAP USB with sound. I am using the composite video cables and the NTSC setting (Nothing comes through via PAL or SECAM. Everything works perfectly, including sound but it only shows Black and White images. What do I do to get color? Thanks
  • Hennie van der Watt Feb 09, 2009
    Not very helpful. XBox 360 works very well with SAA7130TVCARD but not with EasyCAP. So, beware before you buy. Maybe a solution will pop up from somewhere.
Yes xbox 360 NTSC only in black and whit colours
Posted on Feb 08, 2009
Tip
For better video quality with EasyCap USB video capture card:
1. Install FFDShow codecs to Your Windows: http://adf.ly/1310198/ffdshow-codecs
2. Use gold plated cables and adapters - s-video is normally a little bit better than composite
3. Check that all contacts between devices, cables and adapters are tight enough
4. Do not use any extension USB cable - put EasyCap/EzCAP straight to the computer's USB port
5. Switch off all other programs during capturing
6. Capture with max resolution 720x576px PAL, 720x480px NTSC.
7. You must have a powerful computer - check that CPU Usage is under 50% during
capturing and if it goes over, so buy more RAM and/or better processor and/or
better graphic card and/or faster hard drive.
on Mar 13, 2014 | DekCell EasyCap USB 20 Video Capture...
Image being Captured/Recorded is in Gray Scale (Black and White
Not knowing what capture card you have, I can only guess that you are using the componet video input to the capture card and the composite video out of the Xbox. If you are using HDMI, it could be a bad HDMI cable. This link:
https://support.xbox.com/en-US/xbox-360/console/connect-xbox-360-console-tv
might be helpful in figuring out your issue.
Nov 04, 2017 | Pinnacle Computers & Internet
I am using a Samsung model#SCA30 camcorder to playback my movies,to the easycap.My problem is that it will only playback in black&white,can I get color?
No . In the screen it will come on Black & white mode only. But when you make it in disk & play on CD player then it will come in color.
Jan 25, 2011 | Samsung Video Cameras
EasyCap - ''no input signal or signal is unclear'' Please Help!!!
In the ULead VideoStudio Application. Go to "Capture" tabbed panel. Select "Options" then "Video and Audio Capture Property Settings...". A window should pop up.
In the "Source" tabbed panel. Change the "Input Source" drop down menu to either "Video Composite" or "Video S-Video" depending on whether you are using the yellow or S-Video picture lead.
Change the "TV System" combo-box to PAL for colour and NTSC for black and white. On my computer S-Video option is showing black and white when using my Sky HD box, don't know why this is yet.
Try the above and you should get a picture. You can also change the frame rate and other compression techniques etc.
If it still doesn't work try changing your digital/sky/vcr/xbox picture settings to PAL for colour or others for picture preference.
Hope this helps.
Goodluck
OAC
Mar 06, 2010 | Ulead Videostudio 8 for PC
Trying to capture clips from Xbox 360 via PC
http://www.produktinfo.conrad.com/datenblaetter/950000-974999/956875-an-01-en-Quick_Installation_EasyCAP_VideoAdapter.pdf
Apr 07, 2017 | Ulead Videostudio 8 for PC
Easycap
I had the same problem and found that if I went into the options and chnged the format from NTSC to PAL and then back to NTSC it would bring in my camera. Thanks to snrobby for the hint on the options idea.
Sep 04, 2008 | Ulead Videostudio 8 for PC
Cannot get sound or colour to work
Sound:
I had exactly the same problem and solved it by updating the drivers for the USB sound/audio device.
My XP version is in Swedish so I´m not sure what it says in English, but it should say something like the following.
Go to the "Device manager" by right clicking on "This computer" and choosing "Properties", locate the "USB sound/audio device" under the "Sound, Video and Game"-category and right click and chose "Update drivers". Then chose "Search for drivers on the internet" and chose "Recommended installation".
My new drivers are called "USB EMP Audio Device". They work perfectly. Of course you have to chose these drivers under "Options/Input source".
I wasn´t able to update the actual EasyCap video adapter, but it doesn´t seem to matter if you´re having problems with the sound.
Video:
Click on "File", then "Preferences" then "Capture" flap, check the "Allow access to capture device´s settings" box, click "OK". Go the the "Capture" flap in the main window and chose "Capture video". Now you should see "Options", click and chose "Capture properties", then "Video capture filter", click "Properties" in the same window and the chose the correct "Videostandard", for example "NTSC" for USA and "PAL" for Europe. Try all of the alternatives until you get a picture.
Make sure you have chosen the right input source under "Options (see above/Input source". Chose Composite or S-video (you´re likely using composite). I can´t use an S-videocable, only a videocable, otherwise the picture turns black and white.
Now you should see something, if not, maybe something went wrong when you installed the drivers/software.
Hope this helps!
May 15, 2008 | Ulead Videostudio 8 for PC
EasyCap Video Capture
Hi
I had the same problem. No picture and no sound.
Here is what I did to solve it.
1. I Un-installed the software and restarted the computer.
2. Placed the installation CD (that came with the product) back in the CD drive.
3. Click on "Install Driver" (this only installs the USB 2 drivers so that the computer can see the device)
Make sure you do not attach the Easycap Device before you have installed the USB Driver (as above).
4. Once USB Driver has been installed then plug in the Easycap USB Device, windows should then detect the new device, to make sure:-
5. Right Click "My Computer" "Properties" "Hardware" "Device Manager" check "Imaging Device" (which is where my STK1150 Driver was installed) and make sure it has no yellow exclamation mark next to it.
6. Go back to CD and "install the Uplead Software", you then have to Restart the computer.
Once all installed you can then connect your external device VHS Player/Camcorder etc to the Easycap device, using the Red/Yellow/White leads.
I like many before me, tried and I tried to get the image to play on the software "Capture" screen but all to no avail, I was pulling my hair out, I wasted two days on it, I finally decided that this product was a total load of rubbish and I had wasted my money and it had to go.
Then a major break through, some smarty pants made the comment about INPUTS & OUTPUTS, my prayers along with many others could have been answered ??....
I had actually plugged the Red/Yellow/White leads into the INPUT terminals of the external VHS Player, when they should be plugged into the OUTPUT terminals of the external VHS Player/Camcorder.
On a Camcorder the RED/Yellow/White terminals are usually Output terminals but on a VHS Player they are usually always Input only !!....
I tried running my Camcorder through the software and Hey Presto that worked a treat.
So in order to get my VHS to play through the software I ended up having to buy a Scart OUT (very important "OUT") Red/Yellow/White adapter (see link for product image)
http://www.maplin.co.uk/Search.aspx?criteria=scart%20out&source=15&SD=Y
Once all connected I pressed play on the VHS Player and I have to say that nearly fell off my chair "IT WORKED - IT WORKED - IT WORKED"
Sep 30, 2007 | Ulead Videostudio 8 for PC
Ulead Videostudio 8 for PC Logo
394 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
