Question about Brother HL 5170DN Laser Printer
The ststus light is stuck on RED
The printer shows no signs of life except for the lights on the control panel.
  • Anonymous Mar 28, 2009
    The red light stays red. I have tried reconnecting the cable in different ports and that doesn't work.
    New Friend:
  • 114 Answers
Check your your default print settings. If not solved check/change your usb/parallel cable.
Posted on Feb 06, 2009
There is a red flash light on a control panel. What to do?
The toner is nearing the end of its life. You will notice printing may become faded. Replace the toner cartridge and the red light should go away.
Mar 02, 2011 | Dell 1130 Laser Printer
Its not my printer, Im at a friends house and her printer, samsung clp 300 series has a red light status once i turn the pc on. it printed fine on the last job she did and showed no signs that it was...
the PC is not connected to the printer. Look at the control panel, click printer icon and make sure it is accessed, if not, you need to re-activate it as the default printer.... just click on the printer shown and tell it to make it your default printer. Please let me know if I can help any further, glad to help. Guy :)
Sep 23, 2010 | Samsung CLP 300 Laser Printer
Has power but will not turn on. red/blue light is
replace power supply,if no sign of life replace power supply,thanks.
Apr 16, 2010 | LG 42LC2D 42 in. LCD HDTV
After turning on the printer both red lights blink and the paper and ink seem ok
Take the scrap paper with the pads on to your sink, turn on the hot tap and hold .... And the printer is not Ready and the two red lights are blinking Please Give ... C46an isn't off but both green and red lights are flashing (new ink was put in .... Nothing seems to happen, except for the printer going through its ...
www.hm2k.com/.../parts-inside-your-printer-are-at-the-end-of-their-service-life
Dec 03, 2009 | Office Equipment & Supplies
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
GE PRofile Spacemaker 2.0 - power off
I would suspect the magnetron thermostat or the oven thermostat. In some models, they are called TCOs or thermal cutouts.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 15, 2008 | GE Profile Spacemaker Over-the-Range...
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Brother HL 5170DN Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
