Question about DEC (SNKZPCAAX) SCSI Controller
Two disks appear with multiple addresses on DEC 3000-900
I have two 9.1-GB disks installed on a DEC 3000-900.
They are set for DKA200 and DKA300. Originally, they were set using the jumpers on the Disks as DKA0 and DKA100.
The CD-ROM isconfigured as DKA400.
Despite reconfiguring the jumpers, the show dev command lists the following BOOTDEVs and Addresses. Nothing lists for the CD-ROM.
BOOTDEV ADDRS DEVTYPE
DKA0 A/0/0 DISK
DKA100 A/1/0 DISK
DKA200 A/2/0 DISK
DKA300 A/3/0 DISK
A/4/0 (No Boot Dev or Type listed)
(This is the CD-ROM)
DKA500 A/5/0 DISK
DKA600 A/6/0 DISK
The system will not boot successfully from either the CD-ROM or Disk 200.
Are the mulitple addresses for the two disks confusing the system?
How do I get rid of the multiple addresses?
  • 15,935 Answers
The initial Boot Partition is corrupted.
You must change the boot order.
-in the bios of the Workstation check if you have a "boot device"option, (different than the boot priority) several chipset have this option, you can chose between added controller or integrated one.
-Check in the documentation the priority of each slots, you may have inserted the array controller on a slot with higher priority then the internal controller, changing slot will change priority.
-try to perform a clear cmos, some times, old information can prevent the machine to boot from some devices.
Thank you for using FixYa!
Posted on Feb 07, 2009
  • blueextc3221
    blueextc3221 Feb 07, 2009
    CLICK HERE for your owner's guide.
    CLICK HERE for your service information guide.
    If your system has been asking for the time recently on boot-up please check the CMOS battery!!
  • 679 Answers
It sounds like he has twin scuzzy raid drives, they are just either run in raid array. They must be set up to run in a raid setup, where tehy both run identical data for 2 reasons, the speed and the ability to be redundant, in case one goes that has mission critical data, it won't get lost. The drives may run at 10,000 rpms if he has the running of a scuzzy card,I just googled it, they were quite the rage n their day, back when 5400rpm drives were considered fast at 10,000
Posted on Feb 06, 2009
  • 679 Answers
Each IDE/ATA channel can support either one or two devices. IDE/ATA devices of course each contain their own integrated controllers, and so in order to maintain order on the channel, it is necessary to have some way of differentiating between the two devices. This is done by giving each device a designation as either master or slave, and then having the controller address commands and data to either one or the other. The drive that is the target of the command responds to it, and the other one ignores the command, remaining silent.
please add some comment and give more information.
Thanks
  • 4,234 Answers
Check for the ID number for the controller. You have an ID conflict. How many devices are on the bus?
I can check my machine at home later today if you can't find the conflict.
Dan
  • 1 more comment
  • ABRsvcs Feb 06, 2009
    OK. The default address for the controller in those machines is 6. Check the removable plastic numbers to be sure that none of the fingers have broken off. This was a common fault when changing the bus IDs.
    More to come.
    Dan
  • ABRsvcs Feb 07, 2009
    Can you post the boot log. In other words show here what you see on the screen. I think that R5 may not be set properly in the boot sequence.
    Dan
  • ABRsvcs Feb 09, 2009
    My error. I had DSSI on the brain. The problem is esentially the same though. The default bus ID for the controller is 6. The showing of multiple devices indicates either multiple devices responding to the same ID or an unterminated SCSI bus. Check for the correct terminator.
    Dan
  • 19,396 Answers
Check scsi cable and connectors.
If you cannot fix the problem by changing jumper settings, try replacing scsi cable to CD. Or swapping cables.
The disk not booting can be a different system problem.
Try changing jumper settings and using SCSI configuration utility first.
    Master:
  • 848 Answers
Looks like it can't find the right disks/partitions to boot from.
The order may be being re-arranged when you attach them all at once.
Could be an issue with identification, are you using device paths
what's your boot setup? Where is the boot manager
installed ....
My memory shows full when the disk is empty
you should try to reformat it and see if it resets. On windows go to start, computer, format, and set it to default formatting.
Apr 21, 2012 | LaCie WhizKey USB flash drive - 16 GB...
Whizkey wont connect
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it or it might automatically find the drivers and install them
hope it helps
Jul 21, 2011 | LaCie WhizKey USB flash drive - 16 GB...
I have an Intek DG45ID motherboard, installed a Fasttrak TX4650 RAID card in the PCI-X x1 slot. The motherboard does not get past the BIOS post in the boot process, just after showing the boot options a...
It seems that the card might be faulty. If there were incompatibility problems, they would normally show up under the operating system (Windows, Linux, etc), not during the booting process.
From your description, I suspect that the card's BIOS is corrupt. Try getting a replacement under warranty and see if the new card works normally (it should).
Mar 13, 2011 | Promise FastTrak TX4650 4 Port SAS RAID...
I am trying to install win xp with sp2 on my laptop. i was using vista on it before . it show this error message; A problem has been detected and windows has been shut down to prevent damage to your...
If you want both OS you need to do a partition on the HD to proceed.IThat what i can figure from your quest.But if you just want XP just do a clean installation of it.
Perform a clean install of Windows XPA clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base:313348  (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk by using Windows XP Setup programTo perform a clean installation of Windows XP, follow these steps:
  1. Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
  2. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  3. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  4. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  5. Read the Microsoft Software License Terms, and then press F8.
  6. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  7. Follow the instructions on the screen to complete the Windows XP Setup.
If you have successfully installed Windows XP, you are finished. If these steps did not help you install Windows XP, go to the "Next Steps" section.
Oct 06, 2010 | Promise SATA300 TX2plus...
Pci ide controller for third hard disk i have connected a third hard disk160 gb in my desktop via pci ide controller card in windows xp. hard disk is not being...
first u shud check if the BIOS is detecting ur new HDD.
if its not u can activate the new port through bios in the advanced peripherals options sectin :)
Jan 30, 2009 | Sabrent SBT-RDIT PCI IDE Silicon Image...
Disk full???
If Windows (you didn't say), try using Disk Cleanup from Accessories > System Tools. There could also be hidden files on it. In Control Panel > Folder Options > View click the box for "Show hidden files"
Hope that helps...
Geno
Apr 03, 2008 | PNY USB SmartMedia Reader PC (SFRUSBWB)
RocketRaid 133 Installation
Hwrd69
To be able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
Feb 11, 2008 | Highpoint Technologies RocketRAID 133...
SCSI and IDE HDs, can they work together?
This next solution is viable in win 98, and I don?t see any reason why it shouldn?t work for you too. If you know of anything I?m missing you should consult someone else. The solution is slightly complex, so I hope I can explain it properly: 1. Create a startup disk so you can format and install windows. 2. Set the new HD as master and connect it to Primary IDE. 3. Disconnect the SCSI and remove it. 4. Restart the computer with the disk you created (with the new HD connected). 5. Go to the Bios settings in order to make sure that the computer does recognize the new HD as the primary drive in the first IDE. 6. Now, FDisk the new HD, set the partitions, restart and format it. Install the OS and make sure it is working properly. 7. Insert the SCSI and restart again. 8. At this stage the computer would reboot into the IDE and see the SCSI/ You may have to change something in the OS settings for that, but I don?t know where. Good luck.
Feb 22, 2006 | Adaptec SCSI 29160 POWERDOMAIN MAC KIT...
DEC (SNKZPCAAX) SCSI Controller Logo
392 people viewed this question
Top DEC Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a DEC Computer and Internet Expert? Answer questions, earn points and help others
