Question about Ricoh Office Equipment & Supplies
RICOH AP-4510 printer
I want to reset /clear the counter and make it zero in RICOH AP-4510
  • Joseph Micallef May 11, 2010
    Which counter do you want to reset?
    Is it displaying any errors or messages?
  • 15 Answers
I don't believe you can. it's kind of like a car. you can't change the odometer.
Posted on Mar 01, 2009
Ricoh CL2000, How do I enter service mode, and reset (CMY page counters)?
What are you trying to do? Some counters do not reset. Only those for consumable items can be reset.
Jan 17, 2015 | Ricoh Aficio Office Equipment & Supplies
How to reset counter ricoh aficio 2045
Reset what counter? What is the issue? If you mean reset the number of copies? That can only be done with a memory clear which is not a good idea. It clears all internal settings and will not operate properly without a number of settings being re-entered.
Dec 04, 2014 | Ricoh Aficio Office Equipment & Supplies
Reset counter ricoh 7804
usually the counter cannot be reset
Sep 20, 2013 | Ricoh Aficio 1035 Copier
How to reset pcu . Explaim this problem Clearly .mpc 2030
It's a RICOH MPC2030? Why do you need to reset the pcu counter? Or the maintenance counter? I repair ricoh from 10 years so i think i can help you, can you explain me better the problem what you have?
Feb 06, 2013 | Office Equipment & Supplies
I need to reset the NVram to clear the digital page counter what is the fix
Which model and brand u're using. if you used Ricoh machine and the series of model Aficio that hs possible to reset ur digital counter.
1- put out the NVRAM.
2- rotate the direction
3-turn the on machine for ( 5sec)
4-Turn off machine.
5- put again nvram
6- fix on default direction.
7- turn on machine
and see the counter. after done this work going sp mode and used memory all clear.
Best Regards
Syed Babar Ali
Cell : +971556272142
Sep 07, 2011 | Ricoh Aficio MP 2000 Black and White...
I have several of these ricoh 1515 copiers all working fine and then posting a need photocunductor error. Is this some preset error that comes after so many copies like HP got sued for or is the...
Hi, the "Replace Photoconductor" message does come up after a preset number of copies, typically about 60,000. The photoconductor will still continue to work fine, and even with the message displayed the copier should run like normal. The message will keep flashing until you replace the photoconductor, and then it will automatically detect the new unit and the message will disappear.
Jan 21, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
I have an SC_542 error displayed on my RICOH AP 1400 laser printer. How do you clear that error?
fuser error temperature over /under
ull need service engineer to reset it
or new lamp,thermistor or thermostat
Nov 06, 2010 | Ricoh Aficio 2015 Copier
How to restore to factory default settings ricoh
enter service mode then execute these service programs I would do an sp print
5990- 2 out first just in case
5801 Memory Clear
Resets software counters and returns modes and settings to their defaults.
All clear: Clears all data
Engine clear: Clears the printer engine settings
SCS: Clears the systems settings
PRT: Clears user mode system settings
NCS: Network control systems - Clears the items listed in the “Host Interface”
section of the Configuration page.
DCS: Delivery control system (e-mail settings)
MIRS: E-mail addresses
5801 1 Memory all clear
5801 2 Engine memory clear
Resets the following user tool settings:
Maintenance menu: Main scan registration, sub scan registration, image
density, curl control
Resets the settings of the following SPs: 1003, 1104, 1105, 1902, 1910, 2001,
2112, 2113, 2201, 2213, 2301, 2910, 3921, 3922, 3923, 3924, 5930
5801 3 SCS memory clear
Paper Input menu: Paper type, paper size, tray lock,
System menu: Energy saver timer
Resets the settings of the following SPs: 5009, 5812
Also resets the user code counters.
Nov 10, 2009 | Ricoh Aficio SP C410DN Laser Printer
Resetting the photoconductor unit
After replacing the PCU, you can clear the counter by going to Clear mode, 107, push and hold Clear/stop. Screen should change. Push Copier, 7804 should clear drum counter.
Jun 28, 2009 | Ricoh Aficio 450 Copier
Can't select 'Bypass Tray' as a print option.
That's strange. I just downloaded it to see what might need to be done, and the bypass tray was available, and it's a standard feature, so it doesn't have to be manually added or anything. I, however, used the Ricoh driver which is identical, because Ricoh owns Gestetner (in case you didn't know) so you may try installing that one. maybe it's a glitch in the Gestetner driver package. The comparable model is Ricoh AP 4510, and you can get it here. I hope this helps:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/p4510/p4510en.htm
Please rate me :)
May 27, 2009 | Toshiba Estudio 200L Copier
347 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
