Question about Dell OptiPlex GX270 PC Desktop
Yellow light on motherboard after installing new power supply?
Just installed a new power supply and the motherboard gave me a yellow light. what is the problem?
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Did you install like for like power supply or did you up grade your power supply? Also is anything else upgraded?
  • 1,602 Answers
Yellow light not a good sign it must be green to operate at proper performance and standard operational, yellow light may indicate unproper power to motherboard i would go on line or call techincail support or go on line and type in
manufacture name, make and model of baord yellow light error
enter
see if anyothers had that message also
rod
Posted on Feb 06, 2009
I have installed a new motherboard in an acer case. The power cable from the switch on the front of the case will not connect to the board. Can anyone help? Thank you
You should read the motherboard manual, for cabling:
1. Power SW
2. Reset SW
3. HDD led
4. Power led - and power led +
5. Speaker
Cabling scheme, also written on the motherboard.
If the Power SW not installed the switch on does not work.
If the Reset SW not installed the switch reset does not work
If the HDD led
not installed the hard drive light (red) is not lit
If the Power led (+/-) not installed the power light (yellow) is not lit
If the Speakers are not installed, when the computer is on the beep sound is not heard.
I hope this information helps.
Oct 15, 2011 | Computers & Internet
Installed a new msi 88ogm - e43 motherboard with a amd phenom 2 processer and get no boot/post message of any kid
Go ahead and remove everything but the processor, heat sink, PSU, and the power connectors to the board and attempt to boot up like that. If you still are unable to boot up check to see if you have any yellow lights on your board, if so either your board or power supply are damaged.
Mar 30, 2011 | MSI 880GME41 AM3 AMD 880G HDMI Micro ATX...
Dell Insp 4600C blinking yellow power light
the issue could be woth the power supply unit or internal wirings ..
Jul 19, 2009 | Dell Dimension 4600C PC Desktop
I have a dimension 4600c. installed a new power
The power supplies have extra connectors which are not used.
Try doing a system restore to an earlier date when your computer was working ok.
Restart your computer and hit F8 while it is booting. When the menu comes up, select "Last Known Configuration"
This will bring it back to a time when it was working.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 11, 2009 | Dell Dimension 4600C PC Desktop
My gateway 700 xl doesnt boot
Unplug the power from you 700xl and from you monitor. Try removing the cmos battery and reinstalling it. Then, plug everything back in and try restarting. If it continues to give you the yellow light, you may need to replace the CMOS battery, especially if it is more than two years old.
Another thing to consider is if your power supply is underpowered for the number of external devices you have plugged into it (i.e., cd, dvd, external hard drives, printers, pci cards, etc). Gateway installed very low powered power supplies in their 700xl desktop computers. Usually only around 250 watts maximum.
If you are replacing the power supply with another 250 watt maximum power supply, and you have a lot of external devices plugged in, you may need at least a 350 watt power supply....if your CMOS battery is not the problem.
Nov 06, 2008 | Gateway 700 XL PC Desktop
Emachine flashing yellow lights, fans power up when P8 is unplugged
Did some research and found this site which will tell you which pins to test. It is possible also that its not powerful enough for the devices you have. I would try again only giving power to the motherboard pins, of coarse and the hard drive. If works then plug one device at a time.
Good luck
http://articles.techrepublic.com.com/5100-10878_11-1046822.html
Jul 05, 2008 | E-Machines eMachines Desktop PC
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computer dead
Sounds more like a power supply problem. Easy fix just install a new power supply or try it with a known good supply.
Dec 18, 2007 | OEM Systems 24 Pin Pentium 4 775 Ready...
Nothing happened when installed new computer - Please help
since the components are new,it must be other problem...I think that the problem is at the motherboard's jumpers...the power button, the restart button have wires that connect them with the motherboard so, u must not mess up the jumpers...i suggest u should download your motherboard manual and see exactly how the new components should be installed...
HERE, HOPE IT HELPS...
http://users.iafrica.com/g/gl/glynhall/hohweb/manuals.htm
Nov 26, 2007 | MSI K8D Master -FT For AMD Dual Opteron...
No power to motherboard
Hi, Make sure you plug in a 4 pin power connector to the motherboard for the processor or nothing will fire up. It's usually yellow and black.
Jun 12, 2007 | EliteGroup P4M800PRO-M Motherboard
Dell OptiPlex GX270 PC Desktop Logo
708 people viewed this question
Alun Cox
