Question about Toro Lawn Mower With Toro Power Tools
Toro snowblower not starting
My toro 421 snow thrower doesn't stay running, throttle at high makes it stall. it did run for 15 min when i changed primer line.
  • 37 Answers
SOURCE: toro 421 snowblower won't start
check to see if in line fuel shut off valve is open.If so,sounds like carb is gummed up.
Posted on Jan 28, 2009
wireguy212
  • 1627 Answers
SOURCE: I was able to start my 5HP Toro but it is running
Try taking off the fuel bowl and check for debris or ice in it.If there is hardly any fuel in it you may have a plugged or pinched fuel line,try blowing back through it[might get a littl gas in your mouth],turn off the fuel and remove the line at the carb and the tank.If niether of these pick up a new spark plug and try that.
Posted on Dec 07, 2009
  • 44 Answers
SOURCE: Toro Max 1028LXE Snow Thrower will not travel.
thank you for the reply. with the belt drive take a ruler and push the belt down you can use your finger as a referance point if you can push it past the half inch mark the belt needs to be tightend you can do that by adjusting the belt tensioner thats done by losening the bolt that holds it in place then moving it so there is no more then half an inch of play in the belt and retightning the bolt. and if the tensioner is at its stops then the belt needs replacement.
Posted on Dec 21, 2009
kel1guy2002
  • 3740 Answers
SOURCE: how to instal primer plunger on Toro Snow blower 1000E
The new primer bulb should have come with a plastic retaining ring. If you have the new ring then pull the old ring and primer bulb out with long nose pliers.
Then you insert the new rubber bulb until the outer part of the bulb face mates with the carb face. Then install the ring press both pieces into place until it is just below flush.
(If the new bulb did not come with a new plastic ring... you are going to have to ever so gently coax the old ring out with your fingers crossed hoping it does not break.) I have personally broken more than 50% of the old rings... trying to get them out.
Thanks for using FixYa.
Kelly
Posted on Apr 22, 2010
rycgl
  • 1545 Answers
SOURCE: when i tip my toro
The primer bulb is replaceable (it is held in place with a ring with small tabs around it, behind the bulb). The carburetor's bowl may be loose and the bowl nut need to be tightened or the bowl nut (called that, but it is actually a small brass bolt) has an exterior washer that needs to be replaced. Another thing that may be causing your problem is the carburetor bowl-to-body gasket may be leaking and finally, the needle valve may not be completely shutting off the fuel going into the carburetor bowl. All of these parts are replaceable and the carburetor can be fixed to where it will not leak. The key is to determine exactly what carburetor the machine has. The manufacturer and model of the the engine and the year made are key here.
Posted on Dec 13, 2010
Have toro 418 snow thrower prime it and starts but immediately stalls can only keep running if I keep pushing the primer button what's wrong
The fuel pickup tube in the carburetor is probably clogged. I don't know how handy you are, but you have to remove the carb, disassemble it and blow out all the orfices with compressed air and possibly run thin wires into the tubes and holes. Good Luck! the last time I had to do this was in the middle of a snowstorm!
Jan 28, 2015 | Toro Power Clear 418 ZE - Single Stage...
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
My toro snowblower keeps stalling. It starts up fine, but won't run continuously.
If you haven't already, dump out gas and put fresh in it and try this, if it doesn't work you will have to clean the carb, take it apart and clean all jets ports etc and put back together and you should be Good to Blow Snow, pretty common problem with Small Engines that set half the season.
Dec 04, 2011 | Garden
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
Will not throw snow
I have a toro 421 snowblower won't start after had it fixed from shop and how to operator to starter?
Jan 15, 2009 | Toro Lawn Mower With Toro Power Tools
Toro powerlite snowblower sputters out after 10-15 minutes
I would change the spark plug and be sure to gap it as per your owner's manual. I would also clean or change the air filter. I would also use only high test gas and the oil recommended by the manufacturer. good luck.
Jan 14, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Jan 11, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Toro Lawn Mower With Toro Power Tools Logo
414 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
