Question about Norcent Technologies LT-2722 27 in. LCD Television
No display/picture. Sound and power work perfectly.
The title basically says it all. One day, out of the blue, I turned on the TV set and the picture would not load. I had perfect sound, could change channels, could switch inputs. The TV looks as though it is going to work fine at first but the screen cuts out just before the picture should appear.
I found three potential solutions.
1) There is someone on Craigslist who I was in contact with via e-mail. He said he could fix the problem for $100-$200 if I ship him the TV set. He is based in Canada somewhere.
2) There is a guy on E-bay who claims to be an expert. He auctions 20 minutes of time on the phone with you and his auction starts at a few dollars plus a $16 "shipping fee" that he says must be paid before he will talk to you. His auction even lists the exact Norcent problem, although the auction ended already. In his product description he says he knows how to fix "some frequent issues such as Norcent: TV on but no display."
3) I found a shop called All Electronics in Raleight, NC that claims to have worked on Norcent's before.
So, I decided to bring my TV to Raleigh. They took it last week and charged me $20 and told me they'd call me as soon as they had a chance to diagnose it. I decided not to spend $50 to ship it to Canada or $20 to talk to some stranger. I will update this when I hear back from All Electronics.
  • danhertz Feb 18, 2009
    Update...
    I called All Electronics yesterday, I hadn't heard from them since dropping off my TV and they said for $130 they can fix the TV. The solution above was correct. It was an inverter board (I did not get a chance to use the flashlight method b/c I had already dropped off my tv) I told them yesterday around 4:30 to go ahead with the work, they called me at 10:15 today and said the TV was ready.
    So, if you're in a similar situation I would advise you finding a decent electronics repair shop, telling them its the inverter board, and saying that the work should be done for around $150. I guess you could try to fix it yourself, however, I don't know where/how to get a new inverter board or how to install one. I wouldn't send the TV to canada under any circumstances, nor would I call the "expert" on ebay.
    Good Luck!
  • 718 Answers
Based on your problem listing I believe you have an LCD tv.
You can check your tv by turning it on to a station that normally
shows a good picture. Shine a bright flashlight and place it against the screen. Look around the edge of the flashlight for an image moving around. If you see it, your problem is with the inverter/CCFL..
Posted on Feb 06, 2009
How to set perfect color on samsung 48" led smart tv
To achieve true life like colors, the primary colors need to be balanced to produce a perfect black and white picture. Turn the color level on the tv to 0 and tint to middle then look at the picture - does it have a reddish or other "coloration" to it? Then set the individual color levels (if your TV has these settings) of red, blue and green to balance out and get a true black and white picture. After that, bring the color level up slowly until the facial levels are natural - not over driven as seen in most store displays. You may need to use tint control slightly.....
One other way - There is a dvd from Disney called "Wow" that aids in getting your set to optimum display.
Jul 27, 2014 | Televison & Video
I have 60inch plasma tv. the power is on an the blue light,but no sound an no menu or picture.can you help me pls?
Please cycle the unit through the various inputs to make sure it is on one with something hooked up to it.
Either that or a defective cable someplace--double check the hookup and start with just a DVD or something connected to a single input to see for yourself if any input is working.
The inputs are of course different from the cable fitting and it is possible for the tuner in the set not to work but the rear audio/video inputs to work.
Let me know what you find.
Mar 14, 2012 | NEC Televison & Video
Sound no picture
I think you hit the wrong button before....
To restore the settings please try to restore factory setting and see what happen..
Nov 22, 2011 | Samsung LN22A450 22 in. LCD HDTV
Sharp,Aquos, LC-37D64U,Power & Sound, No picture?
try replaced main board
Manufacturer Sharp Part Number DUNTKE373FM03S Description P.W.B.UNIT
Jun 03, 2010 | Sharp LC37D64U 37 in. LCD HDTV
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
I have a GE TV model: 27GT271 and no sound
Possible cause of the problrm is bad/poor solder on the grounds for the tuner circuit shield an the bottom (solder side) of the circuit board. Grounds need a wire jumper from point to point. This was a common problem for those sets and ocassionally it would take out the eeprom chip with it. (Various other problems were shrinking picture/fuzzy picture and intermitt. power)
May 14, 2009 | GE 27GT271 TV
The Yamaha RX-V463 AV does not playsound from the blue ray player
"I am also having difficulties in try to display the yamaha set up menu on the tv."
According to the manual the display menu for TV will not work with HDMI hook up.
I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
Apr 07, 2009 | Yamaha RX-V463 Receiver
JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first
Jan 28, 2009 | JVC LT-42X579 42 in. LCD TV
30" ASTAR LCD
Please call me 323-767-6030 and I will go through with you.
Oct 01, 2008 | Astar LTV-3001 Television
TV Comes On But No Picture
check for bad solder connections on the pc board and a posible leaky cap
Dec 06, 2006 | Philips Magnavox 20MS233S 20" TV
Norcent Technologies LT-2722 27 in. LCD Television Logo
622 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
