Question about Neff 23 in. T1252 Electric Cooktop
Cleaning glass cooktop
Neff electric cooktop - less than 2 years old - how can I get the glass as clean as new again without damaging the surface.
  • Anonymous Mar 30, 2014
    I have a strange stain in the middle of the centre burner of my cooktop. Is more of a dicolouration in the glass of the cooktop.
    My cooktop is just under six month old.
    I also wanted to check if I am meant to hear when the cooktop is on and operating. There is not much of a sound but more of a little whistle.
    Thank you
    Cathy
  • 257 Answers
Hi, Any good glass/ceramic cooktop cleaner will do the job. Any grease spots or burned food spots can be scraped off with a razor scraper ( just keep it flat ) Use a couple of paper towels and put a dime sized drop of the cleaner on each burner and with a circular motion buff the top like you would wax a car, when cleaned up, flip the towels over and buff to a shine. I don't endorse any products but there are some that contain everything you need, cleaner , scraper, cloth like Ceramabrite. They can be found at most grocery, diy and some hardware stores. Good Luck!
Posted on Feb 06, 2009
I have used sodftscrub or cooktop cleaner and a razor blade. What you should do is put the cleaner on the stove first rub it all around then use the razor blade to genhtly scrap the burnt on crud off works great
Posted on Jul 13, 2009
    Genius:
  • 2,920 Answers
Buy one of the magic erases they advertize on tv.they sell them at walmart and arent very expensive and really work wonders...i have a glasstop too and thats how i keep mine clean
How do i clean my cooktop on a whirlpool 465
Light Cleaning
  • Clean your CERAN cooktop after every use. To remove simple spills, wait for the surface to cool before beginning the cleaning process. Pour a small amount of cleaning cream on a damp paper towel and wipe the cooktop surface until the soil and cream are no longer visible. The cleaning cream will leave a protective finish, which will preclude scratches and other types of damage.
  • Heavy Cleaning
  • Wear a heavy oven mitt to remove burnt foods or liquids while the cooktop is still warm. Use the metal razor scraper to remove the substances that are stuck to the cooktop surface. Once the cooktop has cooled, use a damp paper towel to spread a small amount of cleaning cream over the entire cooktop surface and wipe it thoroughly until the cream is no longer visible. Rinse the cooktop with water and dry with a clean paper towel.
  • Cleaning Melted Substances
  • Remove melted plastic, foil or other kitchen products immediately using the metal razor scraper. Spills containing sugar, such as ketchup, tomato sauce, syrup or pudding, must also be removed with the metal scraper at once. It is best to remove these substances while the burner is still hot. Once the melted substance has been removed and the cooktop has cooled, use a damp paper towel and cleaning cream to complete the cleaning process. To protect your hands, remember to wear a thick oven mitt when cleaning the hot cooktop.
  • Tips
  • Scratch marks resulting from daily use will not interfere with the performance of your cooktop. Pots and pans with flat bottoms and those that cover the entire burner surface are recommended for use on your CERAN cooktop.
  • Warnings
  • Spills containing sugar may permanently damage your cooktop unless the substance is removed immediately. Use only the recommended cleaning products on your CERAN cooktop to protect it from damage. Do not use scouring pads, plastic coated sponges or abrasive products of any type. Do not use oven spray or any other type of cleaner containing ammonia or chlorine. Clean all spills thoroughly before using your cooktop again.
  • Nov 07, 2010 | Whirlpool Cooktops
    When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
    I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
    Jul 28, 2010 | Neff Cooktops
    How to clean glass cooktop maytag electric Model
    Hello. Maytag has a special cleaning cream just for their glass cooktop. You can get it whereever the stoves are sold or at this link http://www.buzzillions.com/reviews/maytag-cooktop-cleaning-creme-smooth-top-ranges-reviews
    Joe
    May 07, 2010 | Maytag MEC7536WS Cooktop
    Scratched cooktop
    as far as i know its normal to have an scratched in glass ceramic hob defend how long to use or many times of use.do u think is same usage? its normal defend on usage.
    Jun 20, 2009 | GE 30 in. Profile JP350 Electric Cooktop
    Burnt on stains on the inside glass door of my kitchenaid oven
    DeBruce Polish should remove those types of problems and also render the surface more "Cleanable". This stuff really works on glass anomalies.
    Check out debrucepolish.com.
    DEBRUCE METHOD on You Tube
    Apr 11, 2009 | KitchenAid 32 in. KECC508 Electric Cooktop
    Viking Designer Series gas cooktop not cleaning well
    I'm sorry to say that there is not a wonder solution for this. You try laying a damp cloth on the aluminum part to try and allow the moisture to soak in the clean it off.
    Don't use anything abrasive as the aluminum will scratch.
    Feb 16, 2009 | Viking 31 in. DGCU105 Gas Cooktop
    Discoloration of cooking surface (darkened) on Bosch stove
    I'm Bruce of DeBruce Polish, our new polish is non-toxic and odorless and non abrasive, should take care of your problem. We designed it for stainless steel, and have faboulous results on ceramic stove tops, and chrome and many other uses. Even removes permanent magic marker. web site will be up soon debrucepolish.com. Phone 612-220-2236.
    Jan 02, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Cleaning
    Use DeBruce Polish, a true multi-surface cleaner, non-toxic, odor-less and non-abrasive. Also works great on Stainless steel.
    Nov 08, 2008 | Cooktops
    After cleaning- the cooktop did shortcircuit- after resetting the
    since it is a glass top. there must be a crack on the surface. the cleaning liquid short out the elements. and it will stay that way till th liquid dry.
    use a hair dryer to heat up the surface and see if you can see the crack. it may be a hairline crack.
    once it is dry, it should turn on, unless there something else having a problem.
    pleae rate the asnwer if it help in any way
    thank you
    Oct 16, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Cleaning glass cooktop surface
    I used Mr. Clean multi-surface and the green, back side of the sponge. Turned on a light to show visible stains better, and scrubbed away. It didn't scratch the glass and got it out quick. Hope this helps.
    Jul 20, 2008 | Jenn-Air JED8430 Electric Cooktop
    Neff 23 in. T1252 Electric Cooktop Logo
    483 people viewed this question
    Top Neff Cooktops Experts
    Jim London
    Jim London
    Samyfam
    Samyfam
    Are you a Neff Cooktop Expert? Answer questions, earn points and help others
