Question about Apple iPod 4th Generation MP3 Player
Reset I tried reset my ipod 4th gen clink wheel on itunes.. to default setting... after reset all I got was apple logo then a picture of a electric recepticle and a plug. I've tried to reset, charge battery, replaced battery. nothing.. just a picture of plung and recepticle. I reinstalled itunes and still can get computer to reconize the ipod
  • 903 Answers
Http://www.apple.com/support/ipod/five_rs/nano4gen/
go here and click on the 'begin' icon on the right hand side of the screen. it will take you through various steps to get your ipod up and running again
I hope this helps
Posted on Feb 06, 2009
Tip
IPod Nano/Video/Touch Resetting
One day your using your iPod and all of a sudden, boom. It turns off and refuses to work or read by your computer.
You might get the apple logo, but thats where it ends. In this case, theres a few things that can probably bring you device back and kicking.
iPod Nano/Video(Classic)
6th Gen Nano
Press and hold the Sleep/Wake button and Volume Down button simultaneously for at least eight seconds or until the Apple logo appears. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
4th and 5th Gen Nano/Classic/Video (CLICK WHEEL VERSION)
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
In case the reset does not work, the alternative is to connect the device in disk mode and restoring it.
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears. zero77cool.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
This will enable a black/white display. Restore it using iTunes.
If the above doesnt work, then Im afraid its time to repair your device.
Note: images and part of help copyright © 2011 Apple Inc. All rights reserved
on Mar 13, 2011 | Electronics - Others
My ipod touch [4th generation] screen is stuck on the usb cord pointing toward the itunes logo
The solution is: 1. Turn of your iPod. 2. While holding down the 'Home' button, connect to iTunes WARNING: Doing this will return your iPod back to original 'out of the box' settings and you will lose everything. On the bright side, you get a 'fresh' start and it will auto update to the most recent software version.
ipod touch 4 gen
Aug 19, 2012 | Apple iPod touch 4th Generation MP3 Player
What do i do if my ipod nano 4th gen froze
Hi
Try and reset the ipod by--
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Hope this helps...
Daniel
Sep 03, 2010 | Audio Players & Recorders
My ipod nano has frozen
  1. Toggle the Hold switch. To do this, slide the switch toHold (an orange bar appears) and then slide it back (orange bar ishidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • Ifthe Apple logo appears on the display, connect the iPod to a computerand verify that it appears in iTunes and can play music. If the iPodappears in iTunes and can play music, no further troubleshooting isneeded.
    • If the Apple logo does not appear or the iPodis not seen in iTunes, connect the iPod to a power source by eitherplugging it into an Apple iPod USB Power Adapter or directly into acomputer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer is not set to sleep, standby, or hibernate.
  4. Afterthe iPod has charged for at least 20 minutes and while it is stillconnected to the power source, toggle the Hold switch again as in step1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, the iPod should be serviced.
Jul 28, 2009 | Apple iPod nano 3rd Generation
Ipod nano volume control
Try
Jan 26, 2009 | Apple iPod nano 4th Generation
Ipod Nano 4th Gen Freezes
Restore the IPod to Factory settings you can do it through your ipod by going in settings or you can do it through itunes.
Nov 27, 2008 | Apple iPod nano
Ipod freeze how do I restart
This method is to restart your ipod without erasing any of your saved things.
1. Check that your hold switch is off by sliding the switch away from the headphone jack. The hold switch is located in the top corner of the iPod. If you see orange, then the iPod is locked. To unlock the iPod, slide the switch in the opposite position.
2. Press and hold the following combination of buttons buttons simultaneously for approximately 10 seconds to reset the iPod.
For iPod 1G to 3G (scroll & touch wheel iPods): "Menu" and "Play/Pause"
For iPod 4G+ (includes Photo, Nano, Video, and Mini): "Menu" and "Select Center Button"
For iPhone & iPod Touch: "Menu" and "Sleep Button"
For Shuffle: Turn it off. Turn it on. Done.
If you have an iPod Mini or 4th gen iPod or higher, then you need to press the Menu and Select buttons. The Select button is the center button in the middle of the wheel. For older iPods (1G - 3G) you'll need to press the Menu and Play buttons to restart.
Upon reset, your will see the iPod/iPhone name and the Apple logo. When this happens, you can let go - the iPhone/iPod is rebooting. If your battery is very low, you may have to attach your iPod/iPhone to a power source.
3. The iPod name and the Apple logo will briefly appear upon a successful restart before advancing to the Main Menu.
4. If you have your iPod/iPhone connected to your computer and iTunes open, then your iPod/iPhone should mount and show up under "Devices" in the left iTunes sidebar.
May 05, 2008 | Audio Players & Recorders
Ipod Nano Second Generation
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Aug 24, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Apple iPod 4th Generation MP3 Player Logo
158 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
