Question about Dual Electronics 6-24x50 AOE DUAL ILLUMINATE Rangefinder RIFLE SCOPE
Simmons scope that will not stay on target
I have a simmons 44 mag scope mounted on remington 7400 everything is tight on rifle i shoot adjust the scope i click and my bullet hits 2" toward the direction i wanted to go i go back 1 click and it goes back 3" to the other side i go back the other way and am completely off paper what can i do is the scope probably bad. i sent it off to simmons three years ago for the same problem and had not mounted back on the rifle and still having the same problem. i am wondering if its the rifle or the scope.
  • dennis May 11, 2010
    hi , have you tried eliminating some things , could you mount the scope in a heavy vice (not on the rifle ) and 100 yards away place a target so the scope zeros in on the center,zero in by adjusting target not scope,now with everything lined up , Tap the vice with a hammer to cause strong vibration and see if the scope moves off target , if you can get it to move then the internals of the scope are loose and youll be adjusting forever.Also have you tried the scope on another rifle?
  • 20 Answers
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
Posted on Aug 19, 2009
Sighting my rifle scope
Mount scope on rifle with the eye relief you are happy with
set up a target at 10 yards and fire 5 rounds of until you are grouping tightly ( no fliers ) you may want to use quite a few targets once you are happy with the grouping remove the adjustment covers on the scope
the top one is for moving the point of impact up or down
the side one is for left or right
depending on the point of impact you need to move it up or down to meet the cross hare once you get the point of impact on the same hight line as the aim point you can move the side adjuster to move the poi to meet the aim point
then move the target out to 20 yards and repeat the above again
then move the target out to a distance that you can put 90% of your shots inside 40mm or better and that is your max range for live animals
Dec 15, 2017 | Remington Optics
Tip
Simmons 3*9 22 MAG scope
I bought one SIMMONS 3*9 MAG 22 riffle scope from USA last month in $54 and fixed it on my .22 riffle with proper instruction. When I shooted 2-3 bullets, its + sign is moved from actual target.
I made the target and + again in sync and after shooting 3-4 bullets, its + changed the position. After consulting with some mechanic, he told me the SIMMONS telescope is manufactured in China and its acuracy is not upto the mark. He was advocating me to buy bushnell scope for my riffle.
Now I am confused and not able to identify how to fix this + movement problem in my scope.
Can anyone please help me on this ????
Your reply is very much anticipated.
Thanks !!
on Aug 12, 2008 | Simmons Outdoor Blazer Matte (4 x 32mm)...
44 magnum bullets for deer hunting rifle
Actually called 'ammunition'. On the barrel, near the muzzle, it will tell you the exact round as there are a number of 44 Mag rounds. Here are some of them for sale. There are images in the main link and one is called Buffalo Bore, Deer Grenade which is a hollow point round at 240 grains.
https://www.google.ca/search?q=44+magnum+ammunition&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=622&source=lnms&tbm=isch&sa=X&sqi=2&ved=0ahUKEwj-yOu-8sTPAhUHyj4KHYUQCP4Q_AUIBigB
44 Magnum Ammo ' Bulk .44 Mag Ammunition For Sale Cheap
www.luckygunner.com/handgun/44-magnum-ammo
  1. Cached
  2. Similar
44 Mag - 180 Grain JSP - Remington UMC - 500 Rounds. ... 44 Mag - 240 gr JHP - Blazer - 1000 Rounds. ... 44 Mag - 180 Grain JSP - Remington UMC - 50 Rounds.
44 Remington Magnum Ammo - Sportsman's Guide
www.sportsmansguide.com > Ammo & Shooting > Handgun Ammo
  1. Cached
  2. Similar
The Guide is your source for all things ammo. We have a great supply of .44 Remington Magnum Ammo at the best prices around! Check out our .44 Soft Point ...
Bulk .44 Mag Ammo Online at BulkAmmo.com - Ready to Ship!
www.bulkammo.com/handgun/bulk-.44-mag-ammo
  1. Cached
  2. Similar
Items 1 - 16 of 42 - 500 Rounds of .44 Mag Ammo by Remington - 180gr JSP. ... 1000 Rounds of .44 Mag Ammo by Blazer - 240gr JHP. ... 50 Rounds of .44 Mag Ammo by Remington UMC - 180gr JSP.
44 Remington Magnum- MidwayUSA
https://www.midwayusa.com/44-remington-magnum/br?cid=22546
  1. Cached
  2. Similar
Hornady LEVERevolution Ammunition 44 Remington Magnum 225 Grain Flex Tip ... Buffalo Bore Ammunition 44 Remington Magnum +P+ 340 Grain Lead Flat ...
https://www.midwayusa.com/44-remington-magnum/br?cid=21830
  1. Cached
  2. Similar
Magtech Sport Ammunition 44 Remington Magnum 240 Grain ... Buffalo Bore Ammunition 44 Remington Magnum +P+ 340 Grain Lead Flat Nose Gas Check ...
.44 Remington Magnum Ammo - .44 Rem Mag Bullets
https://www.cheaperthandirt.com/category/ammunition/.../44-remington-magnum.do
  1. Cached
  2. Similar
Look no further for your .44 Remington Magnum ammo! We have all the best brands for your firearm at the best prices, ready to ship right to your door!
44 Magnum & 44 Special : SFRC, your online ammo source!
www.theammosource.com/index.php?main_page=index&cPath=1_108_150
  1. Cached
  2. Similar
Products 1 - 10 of 19 - SFRC : 44 Magnum & 44 Special - Ammunition Firearms Firearms Accessories Reloading Supplies Scopes, Optics, Binos and Sights ...
.44 Magnum - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/.44_Magnum
  1. Cached
  2. Similar
The .44 Remington Magnum, or simply .44 Magnum (10.9×33mmR), and frequently .44 Mag, ... When loaded to its maximum and with heavy, deeply penetrating bullets, the .44 Magnum cartridge is suitable for short-range hunting of all North ... Bullet diameter‎: ‎429 in (10.9 mm) Rim diameter‎: ‎514 in (13.1 mm) Case length‎: ‎1.285 in (32.6 mm) Base diameter‎: ‎457 in (11.6 mm)
44 Mag - Hornady
www.hornady.com/store/44-Mag-c-354
  1. Cached
  2. Similar
... web browser. Home » Ammunition » Handgun » Choose by Caliber » 44 Mag ... 44 Mag 200 gr XTP® See details ... 44 Mag 225 gr FTX® LEVERevolution® ...
44 magnum ammunition Google Search
Oct 06, 2016 | Optics
My 22 mag 4x32 rifle scope not stay on zero inspite of tight mounting .
I don't know what you have done already, but, remember there are two areas to tighten. The scope rings to the scope mounts and the rings themselves around the scope.
you have hopefully forgootten one step.
If not, take it to your local Gun store and I'll bet they won't charge you much if anything for looking at it.
Apr 06, 2011 | Simmons Optics
I have an omark 44 drilled and tapped for scope have fitted a nighteater 8-32x44FC scope which runs out of elevation adjustment at 600 meters target,i want to shoot to 800 meters target,what can i do.
all you can do to raze the point of aim is to jack up the eye end of the scope with 35mm film strips or some thin shims,,,three strips of film will pick up the point of aim by miles
Nov 30, 2010 | Weaver 1" Rifle Scope Mount Rings 49719...
Keep having to resight scope
Sounds like they are right. The cross hair adjustment mechanism may be defective. I'd call bushnell and see what they can do for you.
Bushnell Corporation
9200 Cody
Overland Park, KS 66214-1734 Kansas City area - (913) 752-3400
Consumers - (800) 423-3537
Dealers - (800) 221-9035
Fax - (913) 752-3550
Apr 08, 2010 | Bushnell ® Elite® 3200 3 - 9x40 mm...
Simmons aetec, put on muzzleloader to boresight and adjustments work in reverse.
It's a common misconception to think that you're moving the bullet impact on target, when in fact you're moving the scope's reticle to look where the rifle is shooting.... So if your shooting left of your target.. you want to move the crosshairs to the right.
Hope this helps, mark the Gunsmith
Please leave feedback, Thanks!
Jan 09, 2010 | Optics
Need a manual for a simmons rifle scope model # 1022
When you click on "customer service" on the simmonsoptics.com website, it takes you to the Bushnell customer service web page.
The number for customer service that is given is:
1-888-276-5945
The customer service rep. told me to "go to the Simmons web page".
Which, of course, takes me back to the Bushnell web page. It's a circular race track.......
In my opinion, Simmons/Bushnell has lousy customer service.
I bought a 2nd hand Simmons 3-9X50 scope (model #800479) that needed the screw on caps for the reticle adjustment screws. A small request, I thought.....one that should be easily remedied by calling Simmons/Bushnell customer support.
No dice. Customer support told me to spend $15 to send them the scope, and then they "will have to look around and find something that will fit."
Oh really??? Doesn't Simmons/Bushnell already KNOW the sizes of the parts they have?
Just send me the damn caps. They will cost Simmon/Bushnell no more than a buck apiece.
Then I asked for a user manual for said scope. No dice. The customer support lady told me to find the manual on the Simmons web page.
The Simmons web page doesn't provide user manuals online.
Their customer support needs a lot of improvement.
May 09, 2009 | MAG Simmons 22Mag Rifle Scope 4X 32...
Simmons Prohunter Model 517710 won't shoot a group
You SHOULD send it back. There is something loose inside the scope. Even the worst Simmons scope will get you to 2"-3" group. Also, when you replace it, you might want to consider their (or Nikons) shotgun scopes. They are built to with stand the power of the higher centerfire calibers and magnum shotgun shells.
Jan 23, 2009 | Master Heaters Simmons Master ProHunter...
Dual Electronics 6-24x50 AOE DUAL ILLUMINATE Rangefinder RIFLE SCOPE Logo
619 people viewed this question
Top Dual Electronics Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Dual Electronics Optic Expert? Answer questions, earn points and help others
