Question about Brother Sewing Machines
Trouble with sensor
Hi everyone my machine keeps saying that it has come unthreaded when it hasnt this happens ever few stitches iv tried everything good clean out change thread ,change needle could anyone help please its driving me mad ,thanks sue
  • scottrobinso Feb 06, 2009
    hi thanks for that advise ill have look but not really sure were it is i have been emailing the mechanic from were i brought it from but he couldnt tell me much it is a brother innovis 700 embroidery machine ,thanks sue
  • Anonymous Apr 08, 2009
    I have a brothers 1000 and am having the same probles.
    Where is this sensor located?
    New Friend:
  • 186 Answers
The upper thread sensor on most Brother's is activated by the check spring. Either your check spring has broken or is stuck. You may be able to fix this if you can get to it. A drop of oil may be all you need. I may be able to give more specific advise if you tell me what model it is.
Posted on Feb 06, 2009
I have a PE 150 Brother Embroidery Machine and it will run just a few stiches and then I get the message check for broken thread. White thread was working fine and then when I changed color it would stop every few stiches , now it won't run with any color.
Help
Posted on Jan 09, 2010
When stitching on my Juki 1541 the top stitching is perfect but the stitching from the bobbin is loose. how to fix, I did try sighing the screw on the bobbing , did not work please help!!!!!!!
When the bobbin stitching is off the problem is usually with the top thread. Unthread and rethread the machine making sure it is threaded correctly and is securely in the tension disk. If you still have trouble try using a new needle.
Jun 01, 2017 | Juki Sewing Machines
Instructions on changing thread tensions on a Mylock134
Probably the best thing would be to consult the owner's manual.
BEFORE you thread the serger, RAISE the presser foot so the threads will seat properly and the thread will slide easily. Be sure to thread each thread in the proper ORDER! (Usually upper looper is first, lower looper second and the thread tail should always end up laying OVER the top of the upper looper before passing under the presser foot.)
It is also helpful to use different colors of thread so it is easier to tell which thread's tension needs adjustment.
Sergers require varying tension settings depending on the type of stitch and the appearance you prefer. To achieve the standard stitch setting on most sergers, start out with all the thread tension settings at the midway mark between the high and low numbers. Then test and adjust from there.
Verify with the owner's manual that you are threading everything correctly and not missing any steps. If any thread happens to break or come unthreaded, it is usually best to unthread EVERYTHING and start over from the beginning. (Sergers are very finicky, so if you are frustrated trying to get things to work, the last thing you will usually try is unthreading and rethreading from the beginning.)
The Secret to taming your Serger
Adjusting the Thread Tension on Your Serger PREVIEW BurdaStyle
Dec 06, 2015 | Sewing Machines
Right needle keeps unthreading when sewing. Have checked tension, threading and changed needles. Still doing it.
Unable to discern whether this is a sewing machine or serger. Whatever it is, be sure to pull at least 6 inches of thread beyond the needle's eye before taking the first stitch. You can also try gently holding the thread tails while you take the first few stitches.
Nov 11, 2015 | Sewing Machines
Tension Problems
have to ask --are you sure that it is a tension problem
could be a needle /hook timing problem because if that is off it will also miss stitches
it can be off from worn parts and bushes
Mar 27, 2017 | Sewing Machines
My thread uptake lever keeps coming unthreaded. It causes stitches to be skipped and eventually the thread breaks. I have adjusted the tension, it doesn't help.
take up lever--try putting some tape on it to see if that will stop the thread from coming off.
also change the needle--make sure is the correct one for the fabric
Apr 14, 2012 | New Home Sewing Machines
Have a Husqvarna 870 Quilt sewing machine. Ever since I got it two years ago I have had trouble with the thread take-up lever becoming unthreaded as a stitch. Sometimes this will happen after only a few...
you can put a piece of tape on it to keep the thread from coming off
or as one service tech showed me, take a pair of pliers & put a small cloth over the thread take up
lever & take the pliers & gently mash down the take up lever closed or as much as need to keep
Aug 08, 2011 | Husqvarna Sewing Machines
It keep coming unthreaded at the need when i start sewing
You must hold the top thread at the start of every row of stitching, if you dont then the tension will pull the thread backwards.
May 16, 2010 | Sewing Machines
My needle keeps coming unthreaded. HELP please
1) Open the needle plate and bobbin case and make sure the tangled threads are removed.
2) Open the manual; read and follow every step.
3) Thread the machine with the presser foot up - this is often overlooked and causes loopy stitches that pull right out.
4) Make sure the bobbin in inserted so the bobbin thread is feeding from the bobbin spool in the correct direction and through the proper guides.
5) Take hold of the needle thread and lower, then raise the needle to pull the bobbin thread up through the needle plate. Take both threads under the presser foot and to the back of the machine.
6) When you come to the end of the stitching, make sure the take up lever is at it's highest position. This will keep the thread from coming out of the needle when you begin to sew.
I hope this will help and you will soon be sewing.
Mar 10, 2010 | Sewing Machines
NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Most machines need to have the thread extend to the back of the machine in order not to come unthreaded.
May 20, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing machine either breaks thread or comes unthreaded every time i try to sew.
Your threading is not right, totally remove your thread and rethread according to the manual directions and dvd. If, you still have problems call Singer at 1-800-4singer
Sep 29, 2008 | Singer 3116 Simple
Sewing Machines Logo
164 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
