Question about Canon PIXMA iP6700D InkJet Photo Printer
Wire connection with my laptop
I do not know where to put the wire from my laptop.
i put the rectangular one in my laptop but i do not find the square hole in the printer. can you please tell me how to do . thanks
  • 191 Answers
The square plug and socket on the rear of the printer usually but some printer at front side, the socket find the position at a little deep down the cover.
Posted on Feb 06, 2009
  • 2,229 Answers
Sounds like you are trying to set up a printer. If you have a USB cable, which it sounds like you do, you've put one end in the USB port in your laptop. The other end, which is square with two beveled corners, goes in the corresponding hole in the back of your printer. If the only connection you have in the printer is the older centronics connection (about 2" wide) and there is no other connection, your printer is too old to hook up this way. New printer time, as depending on the age of your laptop, it probably does not have a parallel port to hook up a printer like that.
How to calculate square feet
Calculate Square Footage is by measuring the length and width of your area then multiply those two numbers together, the unit of the results will be (ft2).
square-calculator-yfpx1catvhdedlle0bekpo0l-4-0.png You can use this calculator to figure out the price as well in different currencies
Oct 30, 2017 | Office Equipment & Supplies
I just need to know the four side dementions of a 1/2 acrelot the top and the bottom and both side demenstions .not the high or depth of the land just a flat peice of ground
An acre is 43,560 square feet, so a half acre is 21,780 square feet. If the lot is rectangular, you multiply the length of the long side (in feet) times the length of the short side (in feet). For instance if the lot is 200 feet x 110 feet, the area is 22,000 square feet, just a little over a half acre. If the lot is not rectangular, then you need to have a good knowledge of geometry to calculate the area.
Jun 04, 2017 | Cars & Trucks
I need a wiring diagram for connection of a 3-wire plug to my home panel - Square D, 240V, 200amp service panel.
We need to know what you are connecting. IF you are putting in a 220 outlet for stove, dryer etc. Are you in a mobile home?
Feb 20, 2016 | Square Electrical Supplies
Gateway 450ROG Thermal Paste
It is usually applied to the metal where any device with a connection is bolted to a heat sink----used to quickly transfer heat from the part to the metal it is bolted to in all cases---if replacing a chip etc remove all old grease first.
Jun 14, 2012 | Gateway 450ROG Notebook
What kind of usb cable is needed? the opening at the back of the printer looks square, rather than the usual rectangular usb
All printers use the same USB cable, the one on the printer is square and the rectangular plug goes to your computer.
Jan 28, 2010 | HP Officejet 5610 All-In-One InkJet...
I am trying to hook up my lap top to my xbox 360 i have a regular phone cord all plugged in and its not showing up anywhere
I think I know your problem, there are two types of "phone" cord one is a square plug called a RJ-11, and a Ethernet cord or "bigger phone cord" is more rectangular in size and is called a RJ-45
The xbox 360 takes the RJ-45 cable, now if you have the right cable, connect one end into the 360 and the other in the laptop. Turn on the xbox and the laptop. Now (depending on which OS) find the network connections under the control panel and make sure the connection is good. Then if your going to use your laptop as a wireless adapter all you have to do is select both the wireless and wired connections, right click and find bridge connections. Networking gets very complicated, trust me I've spent hours trying to figure something out. I did the easiest way possible. If my explanation isn't good enough I have some sites that might help but are more technical and require more knowledge of networking, but possible to do.
Site 1
Site 2 (the better one of the two)
If your still having trouble, go to and look in the support section. Or if your really having problems call Microsoft at 1-800-4MYXBOX.
I hope you get your xbox connected with your PC, and it's so worth it when you get it hooked up. Good Luck!
Dec 22, 2009 | Microsoft Xbox 360 Console
Braun electric water heater lid came off along with spring parts, all intact. How do I re-assemble it? Manual? Schematic available?
This is the solution for the BLACK Braun electic water heater, so you must adjust the color to fit if yours is another color.
First take the 3 pieces that go inside the top. Two look like a "Z", and the other is the square, white doo-dad. Take the square piece and slip it into the slot with lid open. YOU CANT PUT IT IN FLAT UNLESS THE LID IS OPEN! Make sure that you can put it in FLAT. Once it is in flat, take it back out. Now you have the 2 "Z" pieces. Fiddle around with these pieces until you learn how to put them in together so they will fit together. This may take several tries. There is a piece that acts like a pivot. Now take all 3 pieces out. The trick is not to put the 2 "Z" pieces in together. You have to figure out what Z-piece to put in first. Then put the rectangular white piece in, and then the other Z-piece. This all must be done with the lid OPEN, otherwise the rectangular piece will not lie flat. Make sure the little spring inside this rectangular piece it put in properly - it should be against the little black doo-dad on the lid. If everything is sitting happily together, you should be able to snap the other black part onto the lid, and close it successfully.
May 16, 2009 | Braun WK200 AquaExpress Electric Water...
Printer 6540
First of all u need to assemble the printer and need to ensure that the printer has a steady green light on Power..
If any light blinks it means there is some problem with the printer..
To connect the printer with your Laptop u need an USB cable which has a rectangular connector at one end wich will be connected to the Laptop's USB Slot and the other end of that cable will have almost square connector wich will be connected to the printer...
Before connecting the printer U need to install the Software on the Laptop and connect the printer when system prompts..
remember the printer should be powered on while connecting to the system..
Nov 01, 2008 | HP DeskJet 6540 InkJet Printer
How can igo by hooking up a canon printer to the computer
Do you have a USB to Peripheral cable? It should look like the photo and have one square end and one rectangular end.  The rectangular end goes into one of the computer's USB ports, marked by the usb symbol (a large circle branching into a small circle, triangle, and square) which can be viewed on the rectangular end of your USB to Peripheral cable.
The square end goes into the printer, marked by the same symbol.
Aug 13, 2008 | Canon Office Equipment & Supplies
I bought a lexmark z645 it dos`nt have the cable wire that hooks the printer to the computer
You need to buy a standard usb cable to connect your printer. Once you got it connect the square shaped end to the printer and the rectangular one to the computer.
Feb 15, 2008 | Computers & Internet
Canon PIXMA  iP6700D InkJet Photo Printer Logo
48 people viewed this question
old marine
old marine
