Question about Adobe Photoshop Elements 2.0 for PC
Photoshop Elements 7 on Vista-64 freezes when saving files
It doesn't always freeze, but does every 3rd or 4th attempt. After that the computer must be shut down via power switch. It worked fine for the first two weeks or so.
Many thanks!
  • namegreb Feb 06, 2009
    Looks like I had too long a subject line and some info was cut off.
    Photoshop Elements 7 freezes when saving files.
    This is on a new Toshiba laptop with 3GB RAM and Vista-64 bit.
  • namegreb Feb 07, 2009
    Thanks for your suggestion.
    It looks like deleting the preferences file might work. For other folks who might need this info, try this:
    1. Got C:\users\{username}\AppData\roaming\adobe\Photoshop Elements\7.0
    2. In the 7.0 folder, find and rename the editor folder to "editor-old"
    I'll follow up when we determine if this actually continues to solve the problem.
    Sergeant:
    Champion:
  • 289 Answers
Hi..the solution to this problem is by re-installing
the software again.once u re-install the software
everything will work correctly without any type
of problems.This is the best solution to this
problem.It will solve the issue.
try it out..
rate me..
Posted on Feb 07, 2009
  • Hariharanath V Feb 09, 2009
    hi..install it again,it will work properly.
    try this out..
    thanks..
  • 744 Answers
Hi see to that its a full version software bcoz trial version may cause some problem in saving ur files.. better try to download this software in website called filehippo.com... Its a complete version and it will be available in that site.. Try to download and start to work.. Freeze problem wont occur for next time...
thank u.. rate me!!!
  • 15,935 Answers
CLICK HERE for official ADOBE fixes to your freezing problem. Seems as if you have enough of the requirements to run properly.
Posted on Feb 06, 2009
  • 728 Answers
Make sure that your Photoshop software was made to work with your computer's operating system, because if it is not, it will give you a whole bunch of problems. Also, check how much hard drive space you have available because if you do not have enough, it will not allow you to save and it will freeze.
    Master:
  • 848 Answers
Hi
troubleshooting system errors in photoshop can be found from the link
http://kb.adobe.com/selfservice/viewContent.do?externalId=kb405398
  • 6,784 Answers
Ok, you may need to update your vista to sp2.also, i would check my mem. you will need at least 1 gig of untouched free mem to run this correctly.oh, make sure you clean your registry before you reinstall this software. sometimes registry errors can cause these lock up along with old versions and lagging memory. Hope that helps ya:)
    Sergeant:
  • 326 Answers
A couple more generic troubleshooting steps to try:
- Reinstall in “simplified mode” with all background services, including anti-virus, disabled. (Seehttp://www.adobe.com/go/kb402603.)
- Run PSE as administrator (different than running in an account with administrator privileges or with UAC turned off).
- Try disconnecting all your USB devices except mouse and keyboard, rebooting, and seeing if you still get the problem. If you don’t, then reconnect the devices one by one until the problem occurs. That will at least identify the device causing the problem.
Note that Adobe officially doesn’t support PSE 6 on Vista 64:
http://www.adobe.com/go/kb403403
I haven’t seen any mention yet of support for PSE 7 on Vista 64. Their policy is more than a little deceptive, since the marketing literature and system requirements make no mention of excluding Vista 64. The PSE 6 Readme and a tech note refer to PSE 6 on Vista 64 without mentioning lack of support.
    President:
  • 1,902 Answers
Have you tried to make sure that all the updates are updated? Also Vista and Photoshop 7 do not get along that well so they can be kind of funny. I would try to make sure everything is updated first
  • 679 Answers
You need to upgrade your RAM memory.
  • rockfixya
    rockfixya Feb 06, 2009
    In all of these, in the step that has you uninstall and reinstall in simplified mode, do this as well:
    1. After uninstalling, remove any remaining traces of PSE manually, (http://www.johnrellis.com/psedbtool/phot... )
    2. When using “msconfig” to disable background services for running in simplified mode, be sure to disable any Microsoft Intellipoint services (Intellipoint is software for Microsoft pointing devices that isn’t essential, and it often conflicts with PSE).
    3. Then after installing in simplified mode, try running PSE in simplified mode after reinstalling. There might be a conflict with a third-party device driver or service.
    If you call Adobe’s technical support and they can’t quickly identify your problem, they will most likely take you through these same steps. Note that they have a reputation for sometimes being way too quick to suggest reformatting your hard drive and reinstalling Windows.
  • rockfixya
    yes.... do all above steps.
    Brigadier General:
  • 3,614 Answers
HI THERE,
better try to completyly uninstall the application and reinstall it again.
let me know
    Sergeant:
  • 250 Answers
Reload the software again.and delete all the unwanted files from the operating system.increase the memory(RAM)
Folder Corrupt and Trying to Install Adobe Photoshop Elements 9
First variant you may use if your .psd file was seriously damaged
https://www.repairtoolbox.com/photoshoprepair.html Photoshop Repair Toolbox
Second solutions are showed as knowledge bases about Adobe Photoshop
http://www.techrepublic.com/forums/questions/repairing-damaged-adobe-photoshop-psd-files/
https://forums.adobe.com/message/6698481
Third one is a guide from Adobe
·Open "My Computer." In Windows XP, the icon is on the desktop. In Windows Vista or Windows 7, you must access this via the "Computer" option in the Start menu.
·Double-click the "C" drive, followed by the "Windows" folder inside. Locate the temporary Photoshop folder, which will look similar to this: "Photoshop Temp6382948398." Double-click the folder when you find it.
·Locate the file inside the temporary folder that matches the name of the corrupted file. Double-click it to open it in Photoshop.
· Click "Save As" in the "File" portion of the main menu bar. Save it in a different location and under a different name
Sep 16, 2015 | Adobe Photoshop CS for PC
S3842 uk FREEZES ON BOOT every time have to switch off. on 3rd or 4th attempt works fine. any new software that requires reboot - it does this without a problem. started 2 months ago with original Vista...
Upgrades are usually troublesome as they leave bits of the old OS in odd places. It is best to do a clean install.
Choose your OS, either Vista or Win7. XP will not work!
Always download the latest drivers for the OS you are using from hp.com or it will keep hanging and be unreliable.
Hope this helps.
Jan 22, 2011 | HP Pavilion Slimline S3123W Desktop PC -...
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
Locating a saved wmv slide show file. using vista on HP computer.
Click the "START" button in the lower left desktop. Type ".wmv" in the search window (lower left) and it should show you ALL the WMV files stored on your computer and their file location. Good Luck....
Dec 27, 2009 | Adobe Photoshop Elements 7
What does attempt to access invalid address mean in Adobe Photosh
Please turn your antivirus software to gaming mode and problem will be sovled.
Nov 17, 2009 | Adobe Photoshop Elements 4.0 plus Premiere...
Freezing magix music studio 12 deluxe with vista 64 bit
I think the problem is..... Magix is compatible with XP 64 bit but not with Vista or 7 64 bit, not much 3rd party software is.
Sep 12, 2009 | Magix Music Studio 2005 Deluxe for PC
Adobe Photoshop Elements 7 Editor "stops working"
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:\Program Files (x86)\Adobe\Photoshop Elements 7.0\Locales\en_US\Plug-Ins\Import-Export
http://kb2.adobe.com/cps/408/kb408846.html
Jul 15, 2009 | Adobe Photoshop 6.0 for PC
Won't work with Vista 64 bit
Hello
I am running Windows Vista 64 bit also and finding out that there are a lot of programs that won't run on a 64 bit machine due to the fact they are not supported for 64 bit, listed below is info to your problem,
Photoshop Elements compatibility with Windows Vista This TechNote lists which versions of Adobe Photoshop Elements are compatible with Microsoft Windows Vista.
Photoshop Elements Version Compatible with Windows Vista (32-bit)? 6.0 Yes 5.0 Yes
Note: You must download the Photoshop Elements 5.0.2 update to ensure compatibility with Windows Vista.
4.0 No 3.0 No 2.0 No 1.0 No
Note: For the versions of Photoshop Elements that are compatible with Windows Vista, the 64-bit editions of Vista are not supported. Adobe Technical Support can assist you with the features of Photoshop Elements and with issues that also occur in supported operating systems. Technical Support cannot, however, assist you with issues that occur only on the 64-bit editions of Windows Vista. Instead, you can use the following support options on the Adobe website:
  • The User to User Forums, on which you can enter your problem or concern to see if another Adobe user can offer advice. Access this resource at www.adobeforums.com.
  • The Support Knowledgebase, which contains solutions for issues that occur on supported operating systems. Access this resource at www.adobe.com/support/photoshopelements.
dmg49
Apr 15, 2009 | Adobe Premiere® Elements 3.0 Full Version...
Can't install photoshop elements 7 on my vaio (vista)
If you had a prior version of Elements on your computer, make sure you have uninstalled it via Add/Remove Programs. This process doesn't remove everything, however. You also have to remove the database cache file manually. To do this, navigate to c:\Program files\Common files\Adobe\Adobe pcd\cache\ and delete the file named "cache.db" by dragging it to the recycle bin. After I did this, my install went fine.
Feb 25, 2009 | Adobe Photoshop 7.0 for PC
PhotoShop Elements 3.0
I already found a solution. I am not home at the money so I cannot tell you exactly what I did, but there was something under the system portion of Vista that I had to add PrintMaster to so that it would work. I am able to now use the program.
Thanks!
Apr 21, 2008 | Adobe Photoshop 7.0 for PC
Adobe Photoshop Elements 2.0 for PC Logo
188 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
