Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat
The fuse is good but it won't heat ne thing
    Problem Solver:
  • 17 Answers
THE MAG TUBE HAS TO BE REPLCED
Posted on Feb 08, 2009
My whirpool microwave model wmh2175xvb1 Won't Heat
The problem is caused by the magnetron,"heart of the microwave oven" or the inverter board, if 7 years or less.
Apr 16, 2012 | Microwave Ovens
Prestige gs25 microwave won't heat
no the problem is more than your fuze! Micro waves have a high voltage output transformer inside that goes bad. You can fix it yourself but if your not good with electronics I would have someone else do the job!
Feb 07, 2012 | Microwave Ovens
I have a GE Profile Spacemaker 2.0, MOD Number: JVM2070SK02 Last week the thing stopped heating anything. Sounds fine, but won't heat. Any tips?
okay thats sounds like you have to take your microwave to a repair man.the HV capacitor can be open or the magnetron is bad these 2 components i mention are responsible for the heating of your microwave if they go bad..then your microwave wont heat.good luck.
Sep 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Hamilton Beach 900 watt microwave that will run but will not heat the food
maby it's the magnetron, i need more information, a good way to test the magnetron is to put a small HE-NE lamp in a glass filled with water (HE-NE lamps) are found in any radioshack (La source) store, if the lamp glowes orange it meens the magnetron is good, if it is not glowing then the magnetron is dead, (the magnetron is allmost the price of the oven) it could be a fuse but if you have to change the fuse replace it with the same type (normaly ceramic german type) NOT GLASS
Jan 04, 2011 | Hamilton Beach Microwave Ovens
MAKES LOUD NOISE DOESNT HEAT
many parts of coz not heating the microwave firts ismagnetron but you cannot try if is ok or not by using a clamp meter or actualtesting,but the ohter parts can be test,but firts thing dont touch by your handany part of microwave.mostly the problem of not heating is HV FUSE with redwire and white like tube,if you open the tube plastic you will see small wireinside if is good or defective, if wire is continue is good,if wire is brokenor split it is defective,but the other parts is not to recomended to test ifyou are no basic idea for testing coz of the high voltage of microwave.otherthan that if the HV FUSE is ok the second common problem of microwave ismagnetron and easy to replace,carefully to remove the part by using a plieswith insulation for your protection in High voltage.
Dec 17, 2010 | Whirlpool MH3185XP Microwave Oven
Which fuse to connect with the main supply for ne
You will need at least a 20AMP BREAKER.
2100 Watts. at 115V = 18.2 Amps.. therefore your breaker MUST be more than that, to allow for inrush current in the event the oven is left on high when connected.
Feb 05, 2010 | Panasonic Pro II NE2180 2100 Watts...
Where is the fuse and reset button for the Panasonic NE1064TC located. Can anyone help with this. Thanks,
On our Panasonic microwave there are two fuses, a regular cylindrical current fuse and a one-time "thermal fuse." If you remove the case which in our unit is held on by a handful of screws on the back of the unit, both fuses are visible if you stand at the rear of the unit and look on the left hand side. The thermal fuse is the gadget attached to the top of the magnetron heat sink. It is typically in the white wire. The current fuse is located in the black wire. I hope this helps!
Mar 27, 2009 | Panasonic NE-1054 1000 Watts Microwave...
MY microwave just stopped heating things
therrmal resistor bad . Mine quite working and I found one of two resistors bad. Seemes to be a common problem.
Feb 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
56 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
