Question about APC Electrical Supplies
Motion sensor light stay on
I have fitted a motion sensor light (replacing a very old unit) . the new light satys on all the time. there is a sepearte on/off switch in the house which served the old unit . this switched on and supplies power to th unit what is likely to be the problem please
  • 257 Answers
Hi, You don't say what the make or model is, so I will give you the best advice I can. Most motion sensor lights today have a switch or two on them for "on", "test" and then some time like 3 minutes, or 5 minutes. The switch is tiny so it or they are easy to overlook. The "on" position will keep the light on all of the time. The test position does different things on different models but you will want one of the time settings. If this doesn't work for you get back to me with a little more info and we'll keep on it. Good Luck!
Posted on Feb 06, 2009
Brinks motion activated security light model 7160w. Only stays on for about 15 seconds. Setting is on 10 minutes. Can someone help?
Sounds like the motion sensor is not picking up motion. Or, does it actually sense motion and only stay on for a short time each time? Try moving the setting, if this is the case and see if you see ANY change. If not, then replace the motion sensor.
Oct 24, 2014 | Home Security
Lights flash on and off
Very common issue with motion sensing lights. You can either replace the light sensor which is available at most hardware stores or you can disable the motion sensing feature and just have an on-off light. To disable the sensor, (turn off the power!) unscrew and remove the light sensor (it is the reposition-able box under the light.) It depends on the particular light, but you usually just match up the wire coming into the light from the house and the wire from the bulbs and connect them with a wire-nut.
Jan 07, 2014 | Heath Zenith SL-5318-WH Dual Brite Motion...
Motion sensor light lights up during the day
Is this new installation, or old motion sensor that has malfunctioned? Add comment.
Motion sensor has adjustment dials.
Motion sensor that lights in day has probably gone bad.
Occupancy switch and motion sensor wire the same:
http://waterheatertimer.org/How-to-wire-occupancy-switch.html
Gene
h
Aug 10, 2013 | Hardware & Accessories
My journeyman motion light just quit working for no reason. The bubls are good. As mention it was working fine then just stop working. What could be the problem?
The motion sensor unit shorted to due to rainwater infiltration, if its like the last half-dozen motion sensor units I opened up. Take the unit down, open up the sensor unit head, and if its got moisture inside, you know why it quit. If not moisture, then they sometimes do what all electronic devices eventually do, they fail due to 1 of the components reaching its failure - every sensor has an MTBF
(mean time between failure).
Jan 05, 2011 | Heath Zenith Journeyman 270 Degree Motion...
Hi I have a dusk to dawn motion light. It is the brushed nickel model. The problem I'm having is it is staying on all the time. The unit is only 4 months old. It was working at one time, then just quit....
Some of these fixtures have a function built in that turns the light on solid if the power is cycled rapidly several times. If you have had power glitches and this unit has that function, it might be locked on.
Pull the circuit breaker for the light for a couple minutes then try re-powering it to reset the function.
Jun 08, 2010 | Heath Zenith Journeyman 270 Degree Motion...
Brake pad wear warning light on after new pads fitted without pad wear sensors
why doese the pad wear sensor light stay on after fitting new pads and sensor
Jun 06, 2009 | 1998 Volkswagen Golf
My unit stays on 24/7, on bright, it's a heath/zenith dual bright
how old is unit. did it enter manual override? Turn off power for 2 minutes and turn back on. any better.
Jan 14, 2009 | Desa International 240 Deg. White Twin 150...
My motion sensor stopped working--the lights are full on all day.
Good Morning -
Make sure the bulb is point in the right direction and don't use an incadescent? bulb like a 60 watt bulb.
make sure you use floodlightor spot light bulbs so theydon't shine on the sensor.
Have a Great Day!!
Dec 09, 2008 | Electrical Supplies
Electrical Supplies Logo
380 people viewed this question
Top APC Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an APC Electrical Supply Expert? Answer questions, earn points and help others
