Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
Minn Kota Trolling Motor will not run
Minn Kota Turbo 35 (27lb. thrust) motor won't run with hot battery and clean connections. Has not been used in a while, used to work great. Any suggestions for trubleshooting? Thanks!
  • axe2singer Feb 20, 2009
    have same problem
  • 76 Answers
Hi!
For starters, here is a schematic:
Endura 30
Check to see if there is appropriate voltage getting to the switch (with an ohm meter).
You can (please do this carefully) disconnect the battery positive and negative as well as the motor red and motor black wires and connect the Batt positive to the motor red and the Batt negative to the motor black. If the motor runs, the switch is faulty. If it doesn't then I suspect the motor needs looking at.
Best of luck!
Mike
Posted on Sep 26, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
    Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
    Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Burning out fuses on trolling motor at battery
    not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
    Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
    http://www.northlandmarine.com/MinnKotaQuickRef.htm
    You need your serial number of the trolling motor, length of shaft, and thrust poundage.
    or you could call Minn Kota direct and give them the same information at 800-227-6433.
    Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Install
    Click the link below, You do need to know your serial number thrust of motor and length of shaft as well how far away from trolling motor you will install your battery. This link is on Minn Kota Motors website under FAQ you can discuss with a service rep at Minn Kota please call 800-227-6433, but you will still need the information I asked earlier to come up with the answer.
    http://www.minnkotamotors.com/_ui/sramk08/tpl/sramk_nohero_banner_faq-item.aspx?id=145&__taxonomyid=977
    Apr 13, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Hook up for one battery operation for minn kota trolling motor
    I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
    Apr 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    How does the minn kota 65 all terrain run on 24
    You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
    Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
    What size batteries needed for minn kota 24 volt 74lb thrust
    I use Red Hot Mama batteries. These have held up for longer than any other brands that I have used. These are deep cycle marine wet ones.
    Nov 12, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
    2,669 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
