Question about QSC MX1500A 2-Channel Amplifier
CS-800 buzz in channel a
I have a buzz about half volume and up on channel a of my cs-800. Easy fix or should I trade it ? ALSO.... I have a cs-800 x1 crossover amp that I want to use as a regular power amp to run monitors thru. How can I get the 2 channels to work as a regular amp, do I need to bridge it, and if so how ? Where do inputs go ? patches ? I'm lost...
Thanks
  • 4,234 Answers
First a couple of questions:
1) Is the level of buzz controlled by the volume control? Based upon your initial post I would think yes.
2)When you say you want to use the other amp as a regular amp, do you mean to drive a single speaker or more?
Dan
Posted on Feb 07, 2009
Where is a manual for a mitsubishi CS-31205 tv?
The manual for Mitsubishi TV model CS-31205 can be found by clicking the link below (Although the link says "CS 31305" , other models such as CS-31205, CS- 31309, and CS-31304, will use this guide as well)
Download Mitsubishi CS 31305 Owner Manual
Available for download (and offline viewing) in PDF format with a very short registration, or bookmark in your browser, and utilize online.
Or click below to visit the very useful website (the library is large, yet easy to use).
ManualsLib Makes it easy to find manuals online
(*just read this 2 year old question today- hope the OP found resolution)
May 25, 2012 | Mitsubishi CS-31205 TV
I want to no wat this parts number is Q4025p for a peavey cs 800
2 Channel Peavey CS-800 Amp (800 Watts) ... Peavey CS-800x 800 Watt PA Stereo power Amplifier. The Part in question Q4025P is an alternistor. Two SCRs back to back that may have shorted out if it is not working.
Apr 11, 2012 | Peavey Audio Players & Recorders
Pevey CS-800 old fuse not present. What is the correct fuse type for replacement. The fuse holder is on the back of Amp. Thanks.
One of the latest versions has a 15Amp fuse at 115V.
If your CS-800 is connected to 220V, you have to use 7,5Amp (8Amp is OK).
regards,
Gerard
Sep 26, 2009 | Sony STR-DE595 5-Channel Amplifier
Pioneer cs-g404
My experience with them is that they would work as they don't change much from model to model year. You may call the customer support and they will most likely help you
try CS @ 800-421-1404 or try the parts hotline to investigate
(800) 228-7221
Mar 15, 2009 | Pioneer CS-G204 Speaker
I NEED TO HOOK UP MY CS 4000 AMPS
If you are trying to use 3 amps to drive a single cabinet, it can not be done. Bridging amplifiers requires a specific circuit design for that application. There is no way to hook up multiple amps to a single speaker.
Dan
Mar 04, 2009 | Peavey CS 1400 Amplifier
Please explain the working of this code
It's a Java http server (webserver) that serves random "prices" if they match a search string.
Well here is an explaination:
private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};
These are search strings
private static Random rnd = new Random();
This generates a random number
private static Charset cs = Charset.forName("UTF-8");
This is the charset that the http server uses
ServerSocketChannel server = ServerSocketChannel.open();
Create a new server
server.socket().bind(new InetSocketAddress(8055));
Bind the http server to port 8055
The rest is handling the request and processing it
But here:
if(Arrays.binarySearch(symbols, symbol) >= 0)
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;
else
response = "Price not available";
channel.write(cs.encode("HTTP/1.0 200 OK "));
channel.write(cs.encode("Content-type: text/plain "));
channel.write(cs.encode(response));
channel.close();
It sees if the string input matchs: DELL INTC MSFT ORCL SUNW.
(private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};)
If so, it gives a price based on a random number.
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;)
Or else
It says "price not available"
then it gives a html header to end the error message.
Hope I helped you :)
Gook luck
Nov 26, 2008 | Computers & Internet
Mitsubishi Diamond Series CS-27609 problem...image looks "fisheye"
2 years later and I may have a solution for you
I has a similar problem and I didn't quite fix it but made it less noticeable.
Press menu and then the code 2-3-5-7, this enters a service menu. Press Audio/Video to go between the options to get to options 40-50 to adjust geometry. Be sure to write what setting there on before you change it (even if they're wrong) just in case.
Its just trial and error from there, and hope I can still help.
Oct 27, 2007 | Mitsubishi CS-27609 27" TV
Cs 1000
try the following:- go to (radio shack) near to you and obtain a good brand contact cleaner and apply spray over volume control while you are moving it forward and backward.-also try to unplug it from walloutlet and reinsert it again.-also confirm the cabels to speaker in good condition and no short circuit in it and nothing touch eash other.
Sep 25, 2007 | Audio Players & Recorders
Open Questions:
See all QSC MX1500A 2-Channel Amplifier Questions
QSC MX1500A 2-Channel Amplifier Logo
182 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
