Question about Aprilaire 700 Humidifier
Aprilaire 760 keeps running.
Last year my humidifier worked fine but when this winter season started I have found that my humidifier will not shut off. It used to only start a minute before the blower for the furnace started but now the fan on the blower runs constantly. If I turn the knob on the control it will stop running bu then when it restarts it will not shut off.
  • bcamacho6497 May 11, 2010
    I will like to know what type of furnace you have and the type of humidity control and if possible how is wired
  • Mark Allen May 27, 2012
    How do I know if the solenoid valve is on?
  • 189 Answers
The humidifier should not turn on untill the furnace blower starts. Since the fan stays on. does the solenoid valve also stay on? If they both stay on you probably have a bad humidistat. If only the blower stays on then the circuit bourd in the humidifier is defective.
Good luck
HVAC Teacher
Posted on Mar 09, 2009
Is this a newly installed unit it sounds as if there's a wiring issue. Could you show a picture of the wiring terminals. If this is not a new install try turning of your furnace fan.
Nov 02, 2014 | Aprilaire 700 Humidifier
How do I know my aprilair 760 humidifier is working?
A simple check you can perform on your aprilaire 760 is the following:
1) locate the two brown wires coming out of the 760 (these wires will be wired to tell the 760 to turn on when the hvac bower is on and the humidistat is calling for moisture).
2) temprarily disconnect the two brown wires from the external wiring and then short the wires together. All you're doing here is bypassing the your thermostat and bower-on indicator.
With the 70 unit plugged in to the wall outlet and the two brown wires connected together, both the fan and the solenoid valve (water inlet valve) should both be activated.
Dec 13, 2009 | Aprilaire 700 Humidifier
After one season the model 700 doesn't turn on
clogged solonoid? clean filter and orifice
Dec 13, 2008 | Aprilaire 700 Humidifier
Water does not stop.
soliniod may be stuck. you will need a volt meter to test
AprilAire 760 not running after installing new circuit board
I called the service company that put in my new furnace (FAmily Heating and Cooling in Detroit, very highly recommend these people)
Anyway they sent out a second service tech who determined that I would be better off having the humidifier wired to go on whenever the furnace fan was running instead of using the humidifier signal from the circuit board on the furnace. After he changed the wiring the unit runs fine. It is pretty likely that the circuit board was bad also.
Nov 27, 2008 | Aprilaire 700 Humidifier
Lots of water run-off from Aprilaire 760 Humidifier
HI would check the filter in side might need changing or cleaning clean out wter tray in side, it could be just a blocked filter , hope this helps
Jan 03, 2008 | Aprilaire 700 Humidifier
Aprilaire 760 Humidifier water continues to run
You need to determine whether the problem is in the solenoid or in the furnace electronics. You could put a voltmeter on the solenoid connection to see if the furnace is still holding the solenoid open after the blower stops. This will tell you whether it is the solenoid or not.
Feb 18, 2007 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
569 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
