Question about Goldstar MV-1526 Microwave Oven
Does not cook - time counts down extremely fast
Worked in morning when I heated my cup coffee, didn't work when got home. When we enter cook time, the time flashes by very fast, no matter how much time we enter. No cook action. Everything else works; interior light, exterior light, exahust fan, clock.
  • Goldstar Master
  • 9,086 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Then let us know if the hard reset does not fix it.
and please reply back with your brand and model number so we can help you.
Posted on Feb 15, 2009
I made popcorn last night and my microwave worked perfectly. This morning it will not heat a cup of coffee. What's up with that? What can I do to fix it. It is part of a matching set. Kitchenaid micro over...
When unplugging it for half a minute or so (this should reset all settings) won't help, it must be defect. When you are convinced you did press the right buttons and you are in the correct program you don't need to unplug. But for that you have to be sure it is not switched to oven. In 30 seconds it won't be warm enough to heat your coffee
Mar 10, 2015 | KitchenAid Microwave Ovens
How do you use the kitchen timer and cook at the same time?
If you have the kitchen timer set for instance for 10 minutes and it is counting down, and then you want to reheat you coffee for 2 minutes. You would hit either time cook or reheat button and enter 2 minutes ten hit start. The microwave will heat your coffee and show the 2 minute countdown for that. When done it will revert back to what is left on the 10 minute kitchen timer without missing a beat on most microwaves.
Feb 26, 2015 | Microwave Ovens
My GE model JVM1790SK Microwave randomly died yesterday. I had just finished cooking something, started it again, and while the timer started counting, the over did not start. Any idea what this cou
Had you noticed that it was getting weaker? Taking longer to heat a cup of water/coffee? If so then the magnatron was getting weak and gave up the ghost. They are expensive, probably cheaper to get another oven. the other likely failure component is the capacitor. Careful they contain power even when unplugged. Caps are not that $$. good luck
Jan 03, 2015 | GE JVM1790SK Convection/Microwave Oven
My microwave is cooking without me wanting it to
The fact that pressing CANCEL did nothing leads me to believe the controller may have failed but a failed door interlock could be a contributing factor.
Jan 08, 2014 | Kenmore Microwave Ovens
The microwave looks like it is working but no matter what I do there is no heat. I put in a cup of coffee and hit the minute button. It turned on and goes around but the coffee is cold. So I tried...
HELLO.
Below is the solution on how to make our microwave heat food.
1 Remove oven racks and place them in soapy water to soak.
2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thanks.
    Sep 20, 2011 | Microwave Ovens
    I have a Simply Perfect For The Home brand Microwave Oven that I bought from the U.S. Military post here in Schweinfurt, Germany for $50 I live on the economy in my own apartment. The microwave is a 120...
    Just as a NOTE: When I bought my Panasonic microwave from AAFES, before I took it home, they sent it through their maintenance department to adjust the internal voltage. Power for the US is 60 HZ. Power in Europe is 50 HZ. Long Technical Explanation shortened: there's more energy (Heat) in 50 Hz than 60HZ especially when used in anything that uses high power. AAFES adjusted the internal power down to compensate and keep from blowing up the unit. Look for a fuse inside. Replace it, then ask AAFES to reconfigure the product for lower power or 50Hz.
    Also as a note, many, dare I say most, clocks from the US count the HZ to count time. So if your US clock, say on your coffeepot timer, looses time overseas; it's probably losing 4 hours a day (do the math: 50 hz/60hz=83.333_%. 83.3_%*24 hr=20 hrs or 4 hours lost). So, if your time is set for 7AM coffee start, when you get that cup of coffee at 7:10AM, set your clock forward to 11:10 AM; or at 7PM, make sure it actually says 9PM. It will loose enough time by the next 7AM to be correct.
    Aug 11, 2011 | Microwave Ovens
    Heating the cup more than coffee
    make sure the stirrer motor located under the outer cover that distributes the microwaves is turning otherwise you will get hot and cold spots in the oven cavity
    Apr 30, 2010 | GE JVM1870 Microwave Oven
    GE Microwave, inexpensive model, I place a cup of coffee to warm on the turntable, enter a time, it ends and beeps, I open the door, the coffee cup handle is positioned away. I've gone through many...
    Hello BillJohn! I've found that, after many countless hours of precise trial and error testing, that the optimum placement of the cup and a predetermined time entered on the keypad will yield the desired results you're seeking.
    By placing the cup on the outer edge of the turntable, with the handle facing to the right side, when looking straight at the cup of water, you would then close the door until it latches and enter in a time of 2:38 onto the timer, (that's 2 minutes and 38 seconds) with a termperature setting of either low or medium, (not the default high).
    This will provide you with a warmed up cup of joe, with the handle facing in such a manner that you should be able to grasp it in either your left or right paw without much trouble. However, this will only work approximately 82.5% of the time, the rest of the 17.5% the cup will end up at the 3 or 4 o'clock position (when the handle will be facing the back of the micro).
    Otherwise, you'll be destined to have to grasp the cup with your hand and manually rotate it until the handle can be grabbed easily for extraction from the microwave. Of course, it goes without saying that that cup could be quite warm after the timer beeps and signals that the heating/cooking process has been completed.
    Please remember that this highly sofisticated kitchen appliance was once only available to the ultra rich, back when the first Amana Radarranges were available for sale. These microwaves once had the unbelievable pricing at around $1200, all so some ultra rich person could reheat their leftover quails eggs and caviar, (along with that peruvian cop of coffee that their butler let go cold).
    So be thankful that modern manufacturing technics have been able to harness the atom vibrations that allow for rapid heating and cooking for under $100 these days! Why just today, Home Depot was offering a dal for a small microwave for $19.00 on their Black Friday deals! I would have purchased it, but after seeing your issues with these new fangled devices, I decided that having to rotate my cup after reheating it, was just too much to do, even for the odd 17.5% of the time it happens!
    Enjoy that warm cup of Joe and please keep an ongoing log of your actual results of how many times the cup and handle end up in the unaccessible position of 3 and 4 o'clock for the next 30 days.
    I'm seeking more real-world data before I publish my statistics on this unusual cup/handle ending position phenomena.
    Hope you find this Very Helpful and best regards!
    Nov 27, 2009 | GE Microwave Ovens
    Goldstar MV-1526 Microwave Oven Logo
    230 people viewed this question
    Top Goldstar Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    SHARCNET-USA
    SHARCNET-USA
    Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
