Certified toolbar has takenover my home page and I can not remove it
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. and you might have other web search toolbars interfering
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list will be internet options or Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browser below that will be change search defaults click on settings you will see all search Providers Toolbar extensions and Accelerators you have have if don't need any of them you can disable or remove them
also b> http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Then delete cookies Here is a very simple guide on how to delete cookies manually from your computer.
Click on "tools" in your browser. This is usually located in the upper right corner of your browser. Click on Internet options. This will appear in the drop down box and is usually at the bottom. Under the "General" tab look for "Browsing History." Under this heading you can click "Delete" to have the computer delete all cookies for you automatically however to delete the cookies manually click on the "Settings" tab Click on the "View Files" tab under the "Temporary Internet Files and History Settings" box that pops up. When you do a second box will pop up with a list of cookie containing files. This may take a few seconds to load so be patient while waiting for the cookie files to load. Highlight any cookie file that you would like to delete. You can highlight more than one at a time by holding down the 'Ctrl" button on your keypad Delete the files that are highlighted by clicking on the "delete this item" located to the left in the same box. As soon as you do you will see the selected files disappear. When you are done just "X" off; this completes your task of manually deleting cookies. You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted. b>
