Question about Samsung CLX 3160fn All-In-One Printer
CLX-3175FN Draws 14 Amps when printing
My new CLX-3175FN draws 14 Amps when printing thereby causing lights in the room to dim and flicker. This happens only while printing and not while scanning. The room has the standard 15 amps limit (per Maryland law). The printer specs state 8 amps. Is this normal? Called Samsung - the lady did not understand the problem and said that power usage had nothing to do with the printer?!! Her supervisor never returned my call.
  • Anonymous Mar 12, 2009
    Same problem here. 5 year old house. I never thought to look at the spec's. Maybe I can return the printer as a potential electrical/fire hazard.
    Need a new black cartridge soon.
    I wonder if the high amp draw would have killed my usb ports? I now have the printer connected thru my router. Anytime I plug anything into one of the 7 usb ports, the computer crashes. I ended up disabling the ports that are built into the computer and installing a usb card.
dana_eng
  • 41 Answers
SOURCE: Samsung CLX-3175FN Scanning Error
I think the laser part should be unplug in Data cable and power then plug again ..
Posted on Jan 17, 2009
  • 220 Answers
SOURCE: Samsung CLX-3175FN Problem. The printer (and
main board faulty.
Posted on Jun 29, 2009
DosHog
  • 168 Answers
SOURCE: Constant Paper jams on CLX-3175FN
The fact that there appears to be no actual jam tells me that it is not picking up paper out of the tray. Try some alcohol on the pickup rollers, rubbing well. If that helps, replace these rollers.
Posted on Aug 13, 2009
  • 5 Answers
SOURCE: samsung clx-3175fn printer
Direct wireless is not applicable to this model. If you have a wi-fi network set-up, you'll have to use a cable to connect the unit directly to your router then configure the printer to be a part of your network. After that, you should be able to do wireless print.
Posted on Aug 16, 2009
  • 113 Answers
SOURCE: Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
Posted on Apr 19, 2010
When using the vacume it shuts off and the light blinks......what could this be from??
there are to many outlets on that circuit.so when you use a vacume it dims the ligts .the electrick motor draws alot of amps.be carefull this can cause a electricle fire because of the strain on that circuit
Mar 21, 2013 | Televison & Video
Why can't I just print in black and white even though I am out of the Cyan toner for the Samsung CLX-3175FN
Dear user,
You have to select monochrome print settings first. go to properties of your printer and choose the tab where you get to select between B&W and color.
Aug 22, 2012 | Samsung CLX-3175FN Color Laser All-in-One...
Clx 3175fn says "toner low" and won't print. but I
If is attempting to print the documents remove the cartridges and check to make sure they were properly installed. Make sure that the tape was removed that covers the ink and that the cartridges "click" into place when installed.
Mar 01, 2011 | Samsung Office Equipment & Supplies
I have a piece of woodworking machinery that operates with a motor requiring 14 amps.This circuit has a 20 amp circuit breaker that keeps cutting out even though this machine is the only thing drawing...
The 20 amps circuit breaker is there for a purpose, and changing the breaker to a higher one will warm up the wire it is connected on and will cause probably-fire!Cause the wire it is hooked on usually is #14 or #16 on most garages(I wonder why,connected to it are your water heater,washers and dryers and garage door openner).If your City gives you clearance to hook a number 12 gauge wire(or higher) for the purpose of using high amps machines then you can add at least 40 amps circuit breakers.
Oct 30, 2010 | Electrical Supplies
Samsung CLX-3175FN printer instructions - How do you set black and white printing to default
3175fn is acolor printer. if you want to set only grey or black only print. you have to go to printers & fax. select the printer right click properties and go to color and set as gery or black only print.
May 07, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Oct 02, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Brand new Samsung multi-function CLX-3175FN prints a shadow or "ghost" image in color.
Have you done a print head alignment? If yes, and that did not fix it, take it back before you warranty runs out. Most modern day electronic devices work perfect but when they don't they also do it perfectly.
The only things you can do is print head alignment and making sure when you installed those nice new print cartridges that they are pushed in all the way. To try and test anything else will cost money and since this is a brand new device it is best returned.
Aug 09, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung CLX 3160fn All-In-One Printer Logo
99 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
