Question about Legacy 2 Channel 1600 Watt Bridgeable MOSFET Amplifier - LA1468 Car Audio Amplifier
Legacy 1800 watt amplifier
I'm trying to figure out if i can upgrade my amp to put out more power. This amplifier looks identical to my 3000 watt i previously had wonder if changing transistors would do the trick. Or if it's more intensive.
  • Perry Babin May 11, 2010
    If it were that simple, the manufacturers would do it. They can get more money for a higher power amp.
    When an amp is designed, there isn't simply one weak part. All parts are designed to work together and to work reliably into the lowest rated ohm load for the amp. If you modify one section of the amp to produce more power, the other sections wouldn't be able to handle the added stress and would fail. Sometimes amps are modded to produce more power for competition where they will only be used for a few seconds at a time and it doesn't matter if the amp fails. For normal day-day operation, modification for higher power output isn't practical.
  • 55 Answers
HI ...NO, YOU CANT JUST CHANGE THE TRANSISTORS..YOU ARE RIGHT THERE IS MORE TO IT THAN THAT.......
Posted on Feb 22, 2009
What ar the specs for a legacy LA420 600 w amp
This Legacy LA 420 amplifier features 400 watts of power, two channels (bridgeable), a two-way crossover, Mosfet power, 2 ohms stable, and THD less than 0.04%. The amplifier measures 10" x 9.5" x 2.75".
Oct 12, 2016 | Legacy Car Audio & Video
My friend just got a KOLE AUDIO QX1-30000.. he's wantin to know if its a 3,000 watt amp or what because it says QX1-30000 on it??
This is the specs on it:
  • RMS Power Rating:
    • 4 ohms: 1100 watts x 1 chan.
    • 2 ohms: 1800 watts x 1 chan.
    • 1 ohm: 2300 watts x 1 chan.
  • Max power output: 3000 watts x 1 chan.
Jul 01, 2015 | Kole audio Car Audio & Video
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Amp wont turn on
have you checked the remote wire is supply power? try jumping the main power wire t the remote wire to see if it turn on. Also check that your ground wire is securely making contact.
Apr 20, 2009 | Kenwood KAC-8152D Car Audio Amplifier
The fuse from the amp to the battery keeps burning
maybe it cannot accomodate too much power running on it...too much current, try another fuse with higher ampere rates
Jan 14, 2009 | Nitro BMW-486 Car Audio Amplifier
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Problem with LEGACY BLUE DIAMOND AMPLIFIERS LA1080
never attemp to bridge your amps specially this type of amps. this are too very complicated. you may blow your amp if you will attempt it again.
Jan 22, 2008 | Legacy BLUE 4 X 250W CAR AMP Car Audio...
What size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
Dec 13, 2007 | Legacy Audio American Legacy II LA490 Car...
Legacy amp 1200 watts
i have had the exact same problem with the exact same lagacy amp that you have posted, put your ground in a different spot or try double grounds in two different spots this should solve your problem here. good luck
Oct 06, 2006 | Legacy Audio LA770 Car Audio Amplifier
Legacy 2 Channel 1600 Watt Bridgeable MOSFET Amplifier - LA1468 Car Audio Amplifier Logo
108 people viewed this question
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
