Question about Panasonic Audio Players & Recorders
PRESS POWER AND UNIT JUST SAY WAIT
after turn on the display indicates please wait....and wait what wrong saht720
    Genius:
  • 1,175 Answers
Unplug unit from AC..Wait 5 minutes , plug into AC + try to turn on.
If nothing , make sure ALL your speaker wires are plugged in and try again.
Let me know...Thanks
Posted on Feb 08, 2009
My new frigidaire freezer digital display flashes off please help
Hello - Typically "OF" indicates that the freezer is turn off. To activate freezer, press UP three times until display shows "1" then press UP to desired setting. If it will not allow you to change setting and freezer continues to be off, try resetting the freezer by unplugging it or flipping the breaker off. Wait approximately ten minutes and turn it on. If "OF" continues to display, the unit could possibly have a communication problem with the electronic control assembly. Contact a professional to move forward accurately.
Nov 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
When machine is turned on from the off position it does not go into rinse mode message comes up to hot please wait and yet the machine has been turned off for at least 20hrs
the power on sequence for the XP9000 is
1) Internal diagnostic
2) if no cold water, display notice and wait for water level in cold water tank
2) if water heating block is not hot, display notice and wait for block temperature
3) display "Rinse Press Hot Water" notice and wait for button press
4) rinse
5) display "Select Beverage" and wait for button press, ground coffee flap, or other input switch state change.etc...
in short... its doing what its supposed to.
Please consider reading the manual supplied wih your XP9000 or downloading the manual if you don't have it.
Nov 10, 2011 | Krups Super Automatic XP 9000 Espresso...
Weller WD1. At power on screen says "OFF". The 3 preset temperatures are still displayed. Tested with a working lead and soldering tip, OK.
Just press UP/DOWN at the same time quickly. If you hold them down you will get to the menu but just pressing them and releasing them will turn the station back on.
May 31, 2011 | Weller TC201T: Soldering Iron For Wtcpt,...
I have a franke flair coffee machine when you switch it on it reads on the panel please wait and will not complete the switch on. Any help thanks
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck Mikey@espressomachineexperts.com
Dec 22, 2010 | Franke Saphira Espresso & Coffee Maker
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
My printer model is Hp C5383 all-in-one & the printer is flashing the message "ink system failure Oxc19a0023" on the screen. What can I do? Pls help me.
You may try this step to to fix this problem
Solution 1
  • Turn the unit off,.
  • Unplug the power cord and wait 30 seconds before reconnecting the power.
  • Turn on the printer
Solution 2:
  • Press and hold "left arrow" key
  • Press the "setup" key and release both keys
  • Press and release the "OK" button
  • Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
  • Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
  • Press and release the "OK" button.
  • Display should say "Hardware failure status: Clear. Press OK to clear".
  • Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
  • Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Do not print at this stage.
  • Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
  • Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  • Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
  • If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
  • To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
  • If the error is still there, or reoccurs the printer is already defective.
Solution 3:
  • Press the On button to turn the printer off.
  • Unplug the power cord from the back of the printer.
  • Remove all the ink cartridges.
  • Wait two minutes.
  • Plug the power cord into the back of the printer.
  • Press the On button to turn the printer on.
  • Install the ink cartridges when prompted.
Solution 4:
  • Without turning off the product, disconnect the USB cable from the rear of the product.
  • Remove the cartridges from the product.
  • Wait for the 'Insert Cartridges ' message to display on the control panel.
  • Disconnect the power cord from the back of the product.
  • Wait 60 seconds.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  • Reinsert the cartridges, and then close any open doors on the product.
  • If you receive a prompt to print a calibration page, do so.
  • Reconnect the USB cable to the rear of the product, and then try printing again.
Nov 12, 2010 | HP Photosmart C6380 All-In-One InkJet...
Canon Printer MX328 displaying message "Printer Error has Occured 5200". What does this indicate
Please reset the printer
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
Oct 26, 2010 | Canon PIXMA MX300 All-in-One Printer
HP Photosmart C6280 printer won't print and displays Ink System Failure message and Error #0xc18a0001.
Hi there
0xc18a0001.
Try the following steps to remove HP Printer Error Code 0xc18a0001.
I have put 3 ways for you to try.
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Or try 2
Turn the printer and wait until you receive the error message.
* Simultaneously press the keys "9" and "#" printer.
* While holding the button down, unplug the power cord from the unit.
* Wait a few seconds.
* Still holding the button down, reconnect the cable and turn on the printer.
* Release the buttons.
Or try 3
* Turn the printer and wait until you receive the error message.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Unregistered, registering a new base, faillure....
IF YOUR HANDSET WAS WORKING AND THEN STOPPED WITH "UNREGISTERED":
If lowercase unregistered is in main display and a reg. appears under the left soft key:
Press the left soft key below REG. and then press and HOLD the button on the top of the base station until the two indicator lights on top of the base station turn off. Wait until handset signals with beeps and registered. You are done
THIS IS FOR FRESH OUT OF THE BOX REGISTRATION OF UNREGISTERED HANDSET
Press REG Register shall be highlighted.
Scroll to Register. Press Select.
Enter the system PIN (Default: 0000). Use
CLEAR to correct typing errors.
Press ENTER to confirm.
• Your handset starts searching for the base.
Press and HOLD the round button on top of the base unit until the two
indications turn off.
• If registration is successful, the signal icon
Jun 22, 2008 | Philips VOIP8411B/37 IP Phone
How to unlocked region code
XD-DV480 Multi-Region: Converting the player to an alternative region:
  • Supply power to the unit and power on from standby mode via the remote
  • Wait until No Disc is indicated on the fascia
  • Now press Pause followed by 3, 4, 2, 2, 9 and then 2
  • The display should now read CODE
  • Now press 0, 0 for region free or 0 then 1 for region one, 2 for region two, and so on (Note: RCE discs will require specific region set)
If the above modification fails to work then the alternative method below may work:-
  • Connect the DVD player
  • Use the Remote Control to turn power on
  • Wait until No Disc appears
  • Press Pause and type the following code, 8, 9, 2, 6, the display will show "CODE__"
  • Within 5 seconds press 00 for all regions
  • Press Pause and Power
This should work for you.
May 07, 2007 | Aiwa XD-DV480 DVD Player
467 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
