Question about Maytag Dryers
4 wire cord for Maytag lde 410
OK I just got a used maytag lde 410 with a 3 cord plug, my condo has a 4 wire outlet.
So how do I wire the dryer up?
I got the 4 wire cord, just need to know which terminals to hook the wires to inside the dryer.
  • sandman2053 Feb 06, 2009
    Thanks, thats what I thought but wanted to get a second opinion. Didn't really want to burn the condo down. lol
  • 1,543 Answers
There is usually a metal strap or a wire from the enter terminal to the dryer cabinet. Remove and discard that. Attach the green (ground) wire the the cabinet. White (neutral) to the center terminal, and red to one of the other terminals and black to the other. (both are "hot" wires)
Posted on Feb 06, 2009
How do you change a 3 prong cord to 4 prong power cord on a maytag neptunre MDE4000ayw
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
L have a older maytag lde 410 the drum is hard to turn after the belt came off can you help us please
here is a descent website, Hope it helps Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Oct 19, 2010 | Maytag MDE8757AY Electric Dryer
Changing 3 prong to 4 prong outlet
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a maytag dryer is 1999 model which was connected straight to wall.The wire are inside a coil,there are red ,white and blue. Problem is i whant to change outlet from 3 holes to 4 holes.First I...
heatman101
Aug 23, 2010 | Maytag Dryers
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
4 power cord to a 3 power cord
You can take off the cord and put a three prong plug for the dryer it will come with 4 wire that connect to the dryer the one that is not coded is the ground wire. when you take off the one you have now it should have a ground connected to it. Or you can get a new receptical to match the one you have now but it would be more expensive. Hope this helped. If not let us know and thankyou for asking.
Mar 16, 2009 | Maytag Dryers
MAYTAG DRYER ELECTRICAL CONNECTION
If the dryer has a 4 wire cord and you need a 3 wire cord, you should have a jumper, or little metal strip, that came with the dryer. You will connect this jumper between the green ground screw that attaches to the frame and the screw where you white neutral wire lands on the terminal block.
If the dryer is 4 wire and you need it four wire, you simply connect the white to the neutral screw, the black to one of your hot screws, the red to your other hot screw and you green to the green screw connected to your frame. If there is a piece of metal, "jumper" connected from the neutral or white screw and the green screw in the frame you will need to remove this.
Write back if you need clarification.
MAKE SURE THE CIRCUIT IS OFF AND THE CORD UNPLUGGED FROM THE OUTLET BEFORE STARTING. TEST FOR VOLTAGE BEFORE DOING ANYTHING.
Feb 14, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
166 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
