Cars & Trucks Master
- Posted on Feb 10, 2013
Re: I had heat before i change the thermostat what...
You may have trapped air in the coolant system. Take off the radiator cap, turn heater control to high heat, and run the engine till it is fully warmed up and the thermostat has opened. Then shut off car and replace radiator cap after topping up coolant. Heater may work now. Good luck.
When the engine is fully warmed up, feel both your heater hoses: if both are hot, the coolant is circulating through your heater core, so that's not the problem with the heater.
