Question about Clarion DA-1030 Humidifier
Clarion da1030 steamed carpet to white?
I used our humidifer last night for our little one and went into double check on her and noticed a pool of water around the unit. I put a towel down to soak it up and today when I removed the towel there were white marks on the carpet, like it had been bleached? Gray carpet with oure white bloches??
  • 257 Answers
Hi, I really hate to give bad news it affects my ratings! The hot water didn't bleach the carpet, more like washed the color out. The dye in the carpet was no match for boiling hot water and the result was washed out spots. You can try to find some commercial dyes to fix the spots or replace the affected area. Sorry!
Posted on Feb 06, 2009
Humidifier making noise.not steaming
This is an indication that the power supply has issues. You would have to take it apart to check and see what is wrong.
Mar 10, 2015 | Air Innovations Ultrasonic Digital...
How do i know if my humidifier is working? it doesnt produce the white mist
Check your humidistat and it should click close to what you have it set on. Also if your humidifier is not working you can rub your sock feet on the carpet and touch a door knob and get a little shock.
Jan 05, 2010 | Holmes Products Humidifiers
I have had my Hello Kitty Humidifier about a year and a half. I have been very pleased, but yesterday it stopped working. It puts out steam, but not enough to make it out the top. It kind of bubbles down...
sounds like the fan in the bottom does not have enough space. make sure the humidifer is on a flat hard surface. If its on carpet or other soft surface the fan can't push air out and the vapor won't come out.
Dec 02, 2009 | Crane Hello Kitty Humidifier
My mother's Kenmore HW305 humidifier is putting out hot steam. Is that normal or is this a cool mist humidifier?
Yes it is doing what it is supposed to do, just remember to clean it regularly, it is both a fine mist and steam, I would recommend having an fan source close to it to keep the humidification moving in the home, hope that helps.
Jan 20, 2009 | Humidifiers
Clarion da1030 heating element doesn't work
buy a new one the cost to repair the oldone isnt worth the headache buy new
Jan 18, 2009 | Clarion DA-1030 Humidifier
Not working correctly
Does your humidifier use an ultrasonic transducer for vaporizing the water?
May 08, 2017 | Crane Penguin 1 Gallon Humidifier
Thick Cloud of Steam
I would say that the beauty of steam is that it has to get through the 100 degree temperature to leave the aqueous state - i.e. to move from a liquid to a gas.
The benefit of that is that any organizums in the water should be killed as a result of that process. Its possible that it smelt musty or old stagnant water smells but to be honest there is little change of harm to the little ones.
Best wishes
Aug 08, 2008 | Vicks Ultrasonic V5100 Humidifier
Only light moisture even at high setting
Link to Manual:
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
Filters can get dirty pretty quick with the use of tap water. I attached the manual for you so that you can clean it.
Personally, i replace my humidifier filter at least once every 2 months.
Good Luck.
Mar 15, 2008 | Crane Frog EE-3191 1 Gallon Humidifier
Humidifer white dust no filter
Try usubg distilled water (or water with less minerals in it).
Feb 07, 2008 | Vicks Ultrasonic V5100 Humidifier
Clarion DA-1030 Humidifier Logo
101 people viewed this question
Top Clarion Humidifiers Experts
Paul Carew
Dennis
Are you a Clarion Humidifier Expert? Answer questions, earn points and help others
