Question about Hitachi 53UDX10B 53" Rear Projection Television
Cleaning the ridges of rear projection tv screen
I have an old Toshiba rear projection tv that does not have a screen cover on it. The ridges of the screen are full of dust and have dried on kool aid in them. Can anyone tell me what to use to clean out the ridges of the screen? thanks
  • 42 Answers
Mild Ivory soap and water on a shammy cloth
GO UP AND DOWN ONLY
do not put solution on screen put it on the cloth and the wipe
make the cloth damp not soaked
Good luck
Posted on Feb 08, 2009
How to clean inside a toshiba theater view rear projection tv?
you can remove the screen but there is a easier way, from rear with cover removed use a swiffer cleaner to get at the webs etc. Gently.
Nov 27, 2012 | Toshiba TP50H50 50" Rear Projection...
INNER SCREEN NEEDS CLEANING
Here is a picture that shows you how to remove the front screen to get access to the mirror as well.
Aug 15, 2008 | Toshiba 51H84 51" Rear Projection...
How can i clean the screen
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user\'s manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV\'s can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can\'t tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it\'s extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions. GA_googleCreateDomIframe(\'google_ads_div_TL-IMU-Article\' ,\'TL-IMU-Article\');
Jun 09, 2010 | Mitsubishi WD-65732 65" Projection HDTV
How to clean a toshiba tv screen model # 50a62
snap off the fron cover its pretty tight so kind of pull hard dont worry it wont break its just snaped on tightly, after uncrew 3 screws under the screen lift up and pull out screen there will be 2 wires attached to screen, unplug them to set screen to side. dust off the projectors with dry rag, then clean mirror with windex or any window cleaning product. u are done cleaning front of Toshiba, put everything back together, then unscrew the bottom back and vaccum any dust balls u will see inside T.V. u r now done! let me know how it went.
Jan 29, 2010 | Toshiba 50A62 50" Rear Projection...
Good morning, I need to clean inside of my Toshiba 50A60 model tv screen, I do you remove screen?
Yes I Had The Same problem , if your handy with fixing things this will
work.
Step 1- unplug the TV from wall socket
Step 2- disconnect all devices like VCR's DVD Players from the TV
Step 3- remove the speaker covers from the TV
Step 4 - There are 14 screws on front cover, remove these with a
Philips driver, set cover aside
clean with soft brush and wash with water
Step 5- Gently raise the cover straight up to release it from its supports
Once cleared from supports , remove the cover.
Tips- Make sure you don't scratch any of the screens or CRTs
You can clean the mirror with any glass cleaner, make sure to wipe it
clean , water and vinegar does a good job to eliminate streaks.
Use a soft duster to clean the dust from the circut boards
Tip - Remember take it easy when cleaning
When your finished cleaning, just reverse the steps
It Worked for Me
Sep 30, 2009 | Toshiba 50A60 50" Rear Projection...
Need to remove screen cover
you have to remove the back of the tv to clean the inside screen.
Apr 29, 2009 | Toshiba 57H82 57" Rear Projection...
Front screen
HOW TO CLEAN TV SCREEN;
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
How do i clean my screen
Oct 29, 2007 | RCA P52926 52" Rear Projection Television
Screen
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
Oct 25, 2007 | Hitachi 51G500 51" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
114 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
