Question about Canon PowerShot A720 IS Digital Camera
Batttery icon shows low battery even though new batteries are ins
The camera cut off after the icon flashes and the camera doesn't operate. I put new batteries in and had the same results. They are lithium good quality batteries
  • 2 more comments
  • pudynn Feb 14, 2009
    I have the same problem! Does anyone have any ideas what is causing this?
  • cdp7227 Feb 16, 2009
    I'll put in freshly charged batteries and it will barely turn on - immediately turning off again. I bought new batteries (non-chargeable) thinking that my rechargeables may be shot and I still have the same problem.
    I got advice to change a setting, but how can I do this when the camera won't even stay on long enough to get to the settings?
  • Anonymous May 02, 2009
    after inserting new batteries with 12 hours charge it will indicate low battery
  • Anonymous Mar 28, 2014
    BATTERIES ARE NEW BUT THE CAMERA STILL SAYS BATTERY IS LOW
  • 4 Answers
I am not sure if this will address your problem but it is worth trying.
Make sure the record/playback mode switch is not in an intermediate position. Push it firmly all the way up. Also ensure that the mode button is not between clickstops. Then try to operate the camera
If that does not help, try the following. Take all the batteries out, including the lithium battery which keeps the clock going. Also take the SD memory card out. Leave the camera sit overnight.
Obtain new batteries - conventional alkaline AAs and a lithium type CR1220.
Next day, clean all the contacts for the AA batteries with a cotton-bud and contact cleaner or isopropyl alcohol. Let dry. Then insert the new lithium battery. Next insert the new AAs and try to turn the camera on.
If it works, insert the SD card. If it does not work then there is probably an internal problem and it should be serviced.
Posted on Feb 16, 2009
    Sergeant:
    Champion:
  • 373 Answers
Check on canon.com
Posted on Feb 06, 2009
Camera says battery empty
When you finished chargin the batteries, was it fully charged? Are you using the AC cable that was provided to you witht the device? if your camera showed that it was fully charge but discharge even though you dont use the camera,I would recommend you to replace the batteries on the device....
Jan 17, 2008 | Olympus FE-210 Digital Camera
For christmas i was given a Bush HD pocket camcorder 9909, i've just put new batteries in but the camera shuts down because of low battery even though they're new batteries. It is rather...
You need to fully charge your battery pack. When you buy new rechargeable batteries it has low or none charge at all.
Thanks for using fixya!
May 31, 2011 | Computers & Internet
I have just bought a Nikon D70 body off Ebay (therefore didn't get a userguide) I am trying to charge up my battery which appears to work fine (the light shows up on the charger). When I put the battery in...
This is most likely to be a battery problem. Rechargeable batteries don't last forever. Lithium batteries in particular can fail early if they are allowed to become totally discharged.
The best way to check is to buy a new battery, then try to charge it. If it charges and the camera works, problem solved.
If it doesn't charge, then you will need a new charger. The battery will not be wasted though, as it is always handy to have a spare.
Nov 04, 2010 | Nikon D70s Body Only Digital Camera
Goes through batteries very quickly....often reading "low battery".
run a pencil eraser over the battery contacts on the camera, it works most of the time
Sep 07, 2009 | Samsung Digimax 530 Digital Camera
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
When putting in new batteries the "change battery" sign comes on
try new Alkaline batteries or fully charged NiMH batteries, you may need to clean and adjust the springs in the battery compartment
this tips may give you more details
http://www.myfixtips.com/blog/digital-camera/why-my-camera-keeps-saying-%e2%80%98change-battery%e2%80%99-even-with-new-batteries-176.htm
May 14, 2009 | Canon PowerShot A520 Digital Camera
Advent mp 82 camer says replace battery even when new batteries are used
my camera worked, and as i was playing with the menues i changed the batter setting from alkaline to nimh, or the other way round now when i put in ni mh battteries fully charged, it say low battery, gotta try high power alakline now and hope it works
Jun 20, 2008 | Cameras
Low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
May 10, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Keeps saying low battery but has new batteries I have the same problem. New batteries but camera shows low battery and only stays on for 2-3 minutes.
Your camera is a power hog. Try using the new high power battteries. Ther are expensive but generally work in this situation. There could also be a problem with the camera, I can't rule that out.
BonDE
Apr 23, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Canon PowerShot A720 IS Digital Camera Logo
579 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
