Question about JVC HD-61Z886 61" Rear Projection HDTV
My speakers just started making crackling noises.
I have never had this problem before. Everything else works great. Crackling coming from both sides. I made sure they were connected well and not vibrating because of loose speakers. HELP!
  • 373 Answers
Try and se if there is dust build up and blow it off
Posted on Feb 06, 2009
Spr-69 crackling
It may be a bad voice coil. It would make that type noise. If the cone isn't cracked its the coil.
Jan 25, 2014 | Alpine Type-R SPR-69 Car speaker - 100...
Itube fatman mk1 volume dial making a crackling noise
Try spraying switch cleaner into the volume control and working it from side to side. It sounds like it may be worn, dirty or corroded.
Oct 31, 2012 | Cars & Trucks
Amp crackling noise
Sounds like you could have a blown amp/speaker or you've got a short in your speaker lead. Typically, when there's not enough resistance on a wire is when you start getting the crackling noises.
Aug 06, 2012 | Televison & Video
My speakers will start to make a crackling sort of noise then stop. Sometimes the radio will not play at all. Sometimes the speakes make this crackling noise then they stop making the noise and play ok for...
Are your speakers factory? Sometimes the wires start corroding from moistures or from not being covered well. If you can or know someone who can, you may try checking the wires to the speakers/radio. If they are corroding, they may be shorting out.
Jun 30, 2010 | 2005 Kia Amanti
I have a wharfedale svp15 passive loudspeaker. The subwoofer has started crackling and popping at low volumes and has no deep bass. At high volumes it sounds great as usual and can't tell if the crackling...
Information I find online says it an Active Subwoofer, so that introduces its own amp as a possible source of the symptom. If there is another version of this model that's passive, all the more reason to believe the amp is the problem because passive speakers don't spontaneously emit sounds.
If there was a physical reason for the crackling I would think more power would make it worse or blow it up.
A poor sub signal cable connection might explain low current anomalies if random noises are entering the signal path.
Make sure the signal, speaker and power cables are not aligned parallel and close to each other.
Feb 26, 2010 | Audio Players & Recorders
Crackling noise
if you so a test on your speakers you will find the one speaker is doing the same you must take the unit back because the speaker is faltie
Jan 19, 2008 | Creative Labs I-Trigue 3600 Computer...
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Crackling Sound from Speakers
check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
Oct 23, 2007 | LG 50PX4DR 50 in. Plasma TV
Small black device within RCA RP5420
That black disc is the "backup" alarm if you lose power.... The battery then takes over and "buzzs" throught that little speaker too wake you... even tho there is no power... Mine buzzes too... cut that little speaker outta there.!
Oct 23, 2007 | RCA RP5420 Clock Radio
JVC HD-61Z886 61" Rear Projection HDTV Logo
169 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
