Question about GE Kitchen Ranges
Surface unit indicator light is always on
Even when the burners are off the light is on... I think it could be a fuse issue... but not even sure where to check.. Other then that the unit works perfect. Any help would be appreciated.. Coffy I do not have a flat top range, but the surface indicator light stays on all the time. I end up turning the range off at the breaker because I am fearful that they may turn on or cause a fire, if there is a short somewhere. Any suggestions? Thanks.
  • 1,543 Answers
One set of contacts in a surface unit switch is "welded" together, causing the burner indicator (pilot) light to remain on even when all burners are shut off.
With power disconnected to the range, remove the back cover behind the switches and pull one of the wires going from a surface unit switch to the indicator lamp. Make sure the bare wire is not touching anything and reconnect power. If the light goes out (and still goes on when the other burners are turned on) you found the bad switch. If light still on, repeat the procedure with another one of the burner switches (reconnecting the first) until you find which switch is the bad one. (most often it is the burner you use the most, generally the right front burner) If you post your full model number and tell me which switch it is, I can look up the part number for you.
Posted on Feb 06, 2009
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
Aug 08, 2014 | Kenmore 36 in.42741 / 42742 / 42744 /...
Surface unit light stays lit. even when burners are turned off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on heatman101
Aug 04, 2011 | Kenmore Kitchen Ranges
Right front hot srface indicator light is always on even if the stove has been off for days.
If the switch or sensor to the burner in question has a short in it, this can happen. Normally this does not cause a problem with the functionality of the unit nor operation. To call someone out to open the oven at this time could be costly for the hunt for the short could take time. The light is powered from the burner sensor under the cooking surface.
I hope this helps..
Jul 15, 2011 | GE Ovens
Frigidaire Oven surface light stays ''on'' even when cooktop off
I unplugged the stove, un plugged all the burners cleaned them, put them back on plugged the stove back in and the light went out, something to do with unplugging it I think. reset it or something.
May 10, 2010 | Frigidaire FEF326 Electric Kitchen Range
Surface unit control problem
The burner element that is staying ON is also the same one causing the surface light to stay on.
The switch that controls the element is bad.
Unplug the range. Open the switch control console and replace the defective switch.
Make sure the range is unplugged because of high voltage in the console.
Jan 30, 2010 | GE JSP26 Electric Kitchen Range
ifthe "hot surface" indicater light is on, its as ighn that the coresponding element is bad( actually only a safety switch within the sensor, but the entire element needs replacing).. hopefully on oyour unit there a 4 indicators one for each burner(helps to see which burner is bad)
Feb 23, 2009 | Magic Chef CER1115AA Electric Kitchen...
GE Spectra JBP30B0B4WH surface unit light stays on
If it's the light that indicated the element is on, replace the switch. If it's the light that indicated the element is hot, replace the element.
Jun 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
Cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Mar 08, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
Coffy, if you are talking about the hot surface indicator lights, they are controlled by the limiter on the burner itself. When the burner heats up the limiter closes and sends power to the light (hot surface). When the burner cools the limiter is supposed to open cutting power to the hot surface indicator light. They may be stuck closed. If you are talking about the lights on the back panel, that is controlled by the infinate switch itself. Catriver
Oct 09, 2007 | Kenmore 96012 / 96014 / 96019 Electric...
Kitchen Ranges Logo
562 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
