Question about Microsoft Works 8.0 for PC
"out of memory" message then printing to screen and printer
Re: Microsoft Works 8.0. When printing to screen the message "out of memory" appears. When I click on OK the report appears. When printing to the printer the message "out of memory" appears. When I click on OK it will not print. I have copied all my Works files to a memory stick and deleted all but 5 of them from the hard drive on my computer. The problem persists. Solutions????? Thanks, Joe
  • joeworden Apr 04, 2009
    I learned how to change virtual memory range. However, it did not solve my problem. Any other suggestions. Would new software help?
    Thanks, Joe
  • 323 Answers
You would need to increase your virtual memory and restart your computer. Windows XP:
Right click my computer, go to properties
Select the advanced tab
Click advanced tab
Click change under virtual memory.
Set virtual memory 1500 to 4000
click set and apply, ok
If the memory is set higher, select a higher number.
This should resolve your issue.
Posted on Feb 07, 2009
I Purchased NEW THIS PRODUCT HP LASER JET PRO 400
default must be no password , here are the steps to reset the printer
NVRAM reset for the HP LaserJet 400 colorMFP M475dn (Confirmed functional) 1: Print configuration page before beginning reset
2: Disconnect all cables except for power
3: While printer is in ready state, note the position of "Ready" message on the screen (Probably bottom right)
4: Power off the printer via power button
5: Touch the location on the screen where "Ready" message appeared.
6: while touching the screen, power on the printer. Continue to hold the screen.
7: When "Memory Limit Reached" message appears, release the screen.
8: Printer will reboot, clean and calibrate
9: Return cables to their appropriate ports
10: Print configuration page to confirm settings are cleared. Restore settings desired manually.
Finally have access back!
Mar 08, 2017 | HP Computers & Internet
I am getting an error of: 49.4Co2 on my HP color laserJet 5550hdn. Have tied turning it off; unplugging butno luck. the error message continues to appear
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off and then back on.
3. Try printing a job from a different software application.
If the job prints, go back to the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
4. If the message persists with different software applications and print jobs, disconnect all
cables to the printer that connect it to the network or PC.
5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
7. Remove all EIO devices from the printer.
8. Turn the printer on.
9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
10. Replace a DIMM or EIO device if you determine that it causes the error.
11. Remember to reconnect all cables that connect the printer to the network or computer.
12. If the error persists, replace the firmware DIMM.
13. Replace the formatter and calibrate the printer.
Aug 29, 2011 | HP Color LaserJet 5550hdn Printer
When I try to print from Microsoft Works Database, this message appears: Out of Memory
Your print spooler services is not turn on. Go to control panel, and go to administrative tools, and click on services. Scroll through the services and click on print spooler and click on start.
Nov 23, 2009 | Microsoft Windows XP Professional for PC
HP Photosmart D7260 Ink System Failure Error 0xc18a0206
1. Disconnect the Universal Serial Bus2.gif (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Print a Self Test to verify product is functional.
9. Reconnect the USB cable, and try to print from the computer.
10. If the error is still there replace the unit
1. Get the unit into the “Support Menu” by following the steps below
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen2.gif)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure2.gif” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
14. If the error is still there, or reoccurs replace the unit.
Good Luck
Oct 20, 2009 | Office Equipment & Supplies
Dell AIO 942 Printer - updated driver from Microsoft
In this case you may try to change the print format of ur printer in order to do that please contact Dell at 1-800-WWW-DELL......
Good Luck........
Jun 05, 2009 | Dell 942 All-In-One InkJet Printer
Printer "out of memory"
The problem isn't your printer. The problem is with your Microsoft Works software. I know of six solutions that may work.
1) Download the latest service pack for .NET Framework 1.1. http://www.microsoft.com/downloads/details.aspx?FamilyId=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en
2) Go to this website and download the update. http://www.microsoft.com/downloads/details.aspx?FamilyID=65f5b806-e6a1-4f92-a656-e56eeda67e3d&displaylang=en
3) Uninstall printer completely (again). Unplug the printer from the computer. Reboot computer. Download the lastest driver from HP website. When installing the driver software, choose (type)a different directory,( ie. C:\MYHP\HP4180\ ). Plug Printer back to computer.
4) Go to this website. http://support.microsoft.com/kb/841220
5) Click START, click RUN, type SPOOL. Double click printer folder, clear (delete) any files in this folder.
6) Download the latest version of Microsoft Works 9.0.
Let me know if this works.
Feb 03, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
So which printer are you wanting help with?
Nov 23, 2008 | Office Equipment & Supplies
Microsoft Works 8.0 for PC Logo
1,467 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
