Question about Hyundai ImageQuest HQL320WR 32 in. HD-Ready LCD Television
VGA stopped workig, I keep getting "no signal"
My computer is connected to the VGA connector but I keep getting "no signal". It used to work before. I tried to connect another computer but got the same problem. I use the same resolution as before. Seems there is a HW problem with the VGA connector. How can I fix it?
The board model inside the TV is LTV1280B, any body know where can I buy a replacement and how much it should cost?
  • AYBRB2U Mar 29, 2009
    I used a 10 foot M-M vga cable to connect my laptop with 1280X 768 resolution at 60 Mhz refresh rate to the LCD and pressed the hot key. I tried again with another laptop, different brand, the laptop recognized the new accessory, but still a No signal coming from the TV after having it on PC mode. It has never worked for me.
Firmware
You can use the DVI port and use DVI-VGA adapter.
Dec 28, 2013 | Dell Computers & Internet
Monitor stopped working - says No signal
Hi Paul,
This problem is often the result of a loose video cable connection on the computer or an incorrect video signal selection. Most monitors use a cable with "VGA" connector on the end that mates to the computer video port. Other modern computers make use of an HDMI (like the ones used to connect a TV to a BluRay Disk player) or DVI connector instead - either way if it is loose you will get the same "No Signal" message on screen. Make sure these connectors are making good contact with the port on the computer by seating them fully (or better yet - remove and reinsert). In the case of the VGA connector, most have two screws to hold them in the port - you should make sure both are threaded all the way in. You do not need to crank them down, finger-tight is more than enough.
Many newer - flat screen types in particular - do not have the video cable permanently attached. Instead, they use the same cord and connector arrangement found on the computer. It is possible that the connector has become loosened on the monitor end - especially if the monitor is moved / adjusted frequently. You should check the connections at the rear of the monitor just as you checked at the computer, too.
When satisfied that the connections at the computer and monitor are good, check the monitor again. If the message is still present, the monitor may be able to select between an analog input and a digital input via a menu item accessible from the monitor. Check your monitor manual for instructions to change inputs if unsure. If you are using the "standard VGA cable" (the one with the two screws) you should select the analog input. If you're using an HDMI cable, you should select the digital input. If you're using an DVI connector the input may be either analog or digital. When making a change, wait 5 to 10 seconds between toggling between the analog / digital selections to allow the monitor to sync the signal for proper display.
If you're still unable to display the desktop, it is possible that that someone has changed the BIOS options to select a different video card (if more than one is installed) or that the cable is defective.
I hope this helps and good luck!
Dec 17, 2012 | Computers & Internet
Why will HP a6700f onboard VGA connector will not provide a signal ?
have you tried when in the vga card to go to control panel/display and look at change display settings and connect to a projector?
Mar 07, 2017 | HP Computers & Internet
I have a HP m7570n. How do I use a flat screen tv as a monitor
This depends on the TV's available inputs. The Pavilion m7570n has only a VGA output in the standard configuration.
Thus if the TV has a VGA port, turn off the computer and the TV. Then connect a standard VGA (RGB or D-sub 15-pin) m/m cable between the computer and the TV. To use the TV speakers, connect a 3.5 mm audio patch cable between the computers Line-out (green speaker port) to the VGA audio in. Turn on the TV and set the input to VGA (with the Source or Input button on the remote or the TV). Then turn on the computer. Windows XP should find the correct resolution to work with the TV. (If you turn on the TV after turning on the computer, you may get an unsupported signal. Press Ctrl-Alt-Del twice to restart the computer.) If it doesn't work, you may need to connect a different monitor and set the computer to a low resolution before connecting the TV and the computer.
If the TV only has composite or component video inputs, you will need a VGA to video converter (http://www.svideo.com/pctocomponent.html for example). A VGA to component cable will not work; those are for projectors that read an RGB input. TVs interpret YPbPr.
If you have added a video graphics card, you may have an HDMI and/or DVI port(s) on the card. In that case, check the specs of the TV. Some TVs will support HDMI or DVI-HDMI inputs from a computer. Others will not (since computer video signals are not the same as the signal from a set-top box). If you use a DVI-HDMI connector, make sure to use the HDMI port labeled for DVI and connect the audio cable as with the VGA connection. If you use an HDMI connection, you may need to set the sound properties to that of the HDMI port. (Find the control panel item for sound (under Hardware) and then select Manage Audio Devices. Set the Playback properties. If it doesn't work, use an audio patch cable.) Some TVs have RCA audio inputs for the HDMI-DVI connector. In that case, you will need a female 3.5 mm to RCA M/M adapter (if you use a 3.5 mm patch cable). There is a similar device if you want to use an RCA audio cable. You may need to enable the video ports on the graphics card before swapping monitors.
Some video cards have a TV out. In that case, connect the appropriate connector (should come with the video card). Then connect to the component, composite or S-video input on the TV.
Again turn off the TV and the computer before making any connections.
You will probably need to provide your own cables for must of these connection options.
I hope this helps.
May 12, 2011 | HP Pavilion m7570n (EX331AA) PC Desktop
VGA connection works, DVI does not
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Jan 24, 2010 | XFX GeForce4 Mx440 (64 MB) Graphic Card
Have hooked up Magnavox 19" tv as computer screen but don't have sound.
If the computer was connected to the Magnavox using the VGA connector you will not hear sound through the Magnavox, as the VGA connector is a video signal only. Unless you use the HDMI connector, which carries both video and audio, you may not have sound. Verify the back of the Magnavox to see if there are any audio inputs from the PC that may work alongside the VGA connection. Most televisions with a VGA connector do not have this feature as the VGA is strictly for video signal and not sound.
Sep 26, 2009 | Compaq Presario 5000 PC Desktop
Montor black with power light red no signal input
did you try to check the VGA connector maybe cause a damage or not properly connected due encounter block screen or no signal or question mark sign like this (?) color yellow
or use other VGA connector try to do it
Jul 04, 2009 | Computers & Internet
Mitsubishi diamond pro says "no signal"?
You have tried the monitor on more than one known good computer, yes?
I believe about 4" inside this monitor in the back the vga cable or connector connects to a board with an in-line connector. Can you see if this connector (internal to the monitor) in connected?
Good luck...
Mar 02, 2009 | Mitsubishi Diamond Plus 100E Monitor
DVI no input signal......VGA input active.
Are you running an additional Video card? Or are you using the built in one.
You might try cleaning the connector / plugs with acetone from finger polish remover or de=natured alcohol.
Never jam anything on a computer.
If its an add on card, remove it and reboot. Shut down and reinstall card and reboot.
keep me posted please,
Feb 22, 2009 | HP dx2300 Monitor Personal computer Intel...
CHECK SIGNAL CABLE
Typically this happens when the resolution of the display is out of range of the monitor. Normally this is when the resolution is too high. Have you changed the resolution settings? Also, not to be crass, but if there a video card in the system, be sure that you are connected to the correct VGA connector. With an extra card in the system, the onboard VGA connector is not used.
Keep us posted,
Dan
Jan 23, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Hyundai ImageQuest HQL320WR 32 in. HD-Ready LCD Television Logo
150 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
