Question about Denon AVR-1802 Receiver
A/V needs new insides... which parts and numbers
I had a Denon 1802 AV receiver and it went intoprotection mode a week ago. I went all over the web looking for fixes.All of your posts on problems like this were the most helpful. I waswondering if you could guide me a little.
I have taken the unitapart and isolated the faulty IC using a DMM. It is the one closest tothe back of the unit and has D2390 stamped on it. On the PCB board thenumbers read 2SD2389 and Q101SL. I looked all over for a service manualwith no luck but I don't think I'll need it.
I was wondering where to go from here...
Where to puchase a new IC?
I have decent soldering skills and don't think that'll be an issue.
Is there anything else to check for?
Any help and information is appreciated!
Thanks,
Mark
  • 4,234 Answers
First of all the part is a transistor not an IC. There should be at least 4 of these on the back, two of which will be marked D2390. The other should be marked Bxxxx. If the leads of the one you removed read 0 ohms, then it is shorted and must be replaced. You should also replace the 2SB compliment as well.
Before replacing them, completely remove all 4 and mark their locations. Turn on the unit and see if the protection message goes away. Hopefully it will. If it does, carefully measure using the DC voltage setting on the meter the 3 pads for each of the two transistors on the bad side. The readings should be something like 0,+/-40, and +/- 0.6V. If not, please post the readings here and we'll move onto the next step. Otherwise, replace the trnasistors with new ones and you should be OK.
Dan
Posted on Feb 07, 2009
Is it worth repairing a sherwood model 6030R Receiver and can you even get new parts for it???
Given that the Sherwood is a basic stereo/Dolby Pro Logic receiver, and that we have had sources where digital audio (coax and optical) are the standard for Dolby Digital and DTS for well over 15 years, and that HDMI is established now as the de facto standard for AV connections on many home AV products.... perhaps it's time to retire the Sherwood and look for something new.
Entry level price points for new, fully spec'd, AV receivers capable of dealing with HD audio, DD, DTS, Dolby ProLogiic- and ProLogic II have never been cheaper.
Sherwood is still a good brand. It has been joined by Yamaha ( RX-V377BL); Sony (STRDH750); Denon (AVR-S500BT) and Pioneer (VSX-524-K) at the entry-level price point of $249. In real terms these are probably a fraction of what you paid for the Sherwood all those years ago.
Another option is used equipment. There are some really good pre-HDMI AV receivers from Denon, Yahama and Pioneer available in the used market.
Sep 10, 2014 | Sherwood Audio Players & Recorders
AVR-1802 5.1 Channels Receiver: My Denon AVR-1802 LED is flashing rapidly. I have...
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
May 16, 2010 | Denon AVR-1802 Receiver
I am trying to use my Denon AVR-1802 to connect my cable box to my TV. The problem is that I don't have any speakers connected to the 1802, I just want to route the cable box's video and audio to the TV...
connect your analog output from the cablebox to the receiver md/tape in. then connect your tv audio input to the md/tape out of the receiver. or you could just pass it straight from the box to the tv, bypassing the receiver altogether.
Nov 03, 2009 | Denon AVR-1802 Receiver
Denon avr 1802 died after lightning strike
I hate to be the bearer f bad news but it has been my experience , anything hit by lightening stays hit permanantly ..
You may find a few components on the quick scan of the circuit burnt or damaged , but you can guarantee that other components have been fried also .. It does enough damage to any electrical system when you get a 300v spike on the mains .. so imagine what approx 1/2 a million volts will do to a 12 volt radio ?? dont waste your money call your insuarnce company and claim for it ?. ... Regards vortash
May 02, 2009 | Denon AVR-1802 Receiver
My Denon AVR-1802 is permanently stuck in tone defeat. The display actually shows that the tone defeat can be turned off and on, but the tone controls, ie. bass and treble do not alter the sound in any...
Is this only when using external inputs? The manual says the Tone Control will not function in Direct Mode. Try Stereo and various DSP surround modes to see if the Tone Control works.
Apr 21, 2009 | Denon AVR-1802 Receiver
Denon AVR-1802
Providing we are talking a standard tall pin Ic ie not a flat surface mounted variety you shouldnt have too much trouble with the soldering as long as you have a steady hand .. remember not to leave the iron on the joint too long or the print will lift and keep the tip clean to aid heat flow to the solder .. here are a couple of web adresses that might help you get the components you require and good luck oh by the way dont forget static precautions , touching an Ic alone without gorunding yourself first with a static strap can blow some sensative ic's http://www.rscomponents.com and http://www.maplins.com also http://www.radioshack.com
hope this helps and again good luck . .... Reagards ..Vortash
Jan 17, 2009 | Denon AVR-1802 Receiver
Digital audio cuts out.
I have same DD 5.1 tiny "bursts" problem with satellite HD channel. It is probably problem with Crystal DSP (German site): http://forum.digitalfernsehen.de/forum/showthread.php?t=89328&page=3
"Denon bietet Lösung für EX-Flag-Problem bei den Modellen AVR-1602 und AVR-1802 an
07.08.2002(cr)
Dass die Denon AV-Receiver AVR-1802 und AVR-1602 die mit einem DD 5.1EX-Flag versehenen Tonspur von "Atlantis" und dem "Herrn der Ringe"nicht abspielen können, ist ein spezifisches Problem von einerbestimmten Revision des in diesen Geräten verbauten Crystal DSPs.Dieser Chip wird u.a auch in einigen Kenwood- und Onkyo-Modelleneingesetzt.Da es von diesem Crystal Chip unterschiedliche verbauteRevisionen gibt, von denen aber nur eine bestimmte betroffen ist,werden die beiden Filme auf dem größten Teil der verkauften AV-Receiverohne Schwierigkeiten laufen.
Denon bietet nun für alle betroffenen Kunden, die ihr Gerät beimdeutschen autorisierten Fachhandel erworben haben, eine kostenloseModifikation an. Das Gerät muss beim entsprechenden Fachhändlerabgegeben werden mit dem Hinweis auf das Herr-der-Ringe- bzw.Atlantis-Problem.
Momentan steht nur eine begrenzte Anzahl an DSPs zur Verfügung - Denonhofft, dass kurzfristig ein größeres Kontingent eintrifft.
Denon bittet daher die Kunden freundlich um Verständnis, dass nichtalle betroffenen Geräte auf einmal und sofort umgerüstet werden können."
May 23, 2008 | Denon AVR-1802 Receiver
Hi from the Philippines
as far as DSP surround processing is at question, yamaha will do best but when you ask for audio performance, output clarity and performance.... Denon or HK.
Feb 17, 2008 | Yamaha RX-V661 Receiver
Denon AVR-1802
might hav eto buy new control modual parts store hi end parts store order one for u
Jan 25, 2008 | Denon AVR-1802 Receiver
Denon AVR-1802 Receiver Logo
127 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
