Question about Sony Handycam DCR-DVD308 DVD Camcorder
DCR-DVD308 Camcorder problem
For the DCR-DVD308 camcorder. When I press the record button it says no disc. I do have the recommened disc in the camera. I am frustrated. Please help me.
There sas a tiny screw probably from the manufacturers that was sitting on the DVD mechanism witch prevented the DVD to sit properly. So I removed the loose screw. Now works wonderfully.
I checked everything on the camera and doesn't have any screws missing. Thanks. Grace
Posted on Feb 07, 2009
Movie recordng disabled
This is a disc error, have you tried other discs in the device? If you have information on the disc, you will need to try and recover from the RAW format that it is on. Did you try using a different type of disc when you got this error? Please answer my questions so I can better help you fix this problem
Jun 26, 2008 | Sony Handycam DCR-SR80 HD Camcorder
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
Movie recording disabled
Most probably it is an issue with the disc. If the disc is corrupted, it will display the error message to prevent spoiling the lens head of the Camcorder. Please use a different disc and it should resolve the issue. If the issue persists with different discs, it may require service.. However, I suggest that you reset the Camcorder by pressing the Reset button behind the LCD panel on the Camcorder) Please make sure that you have turned ON the Camcorder while pressing the reset button.
Feb 01, 2011 | Sony Handycam DCR-DVD108 DVD Camcorder
My sony handycam carl zeiss says movie recording disabled. What do I do to enable it?
Most probably it is an issue with the disc. If the disc is corrupted, it will display the error message to prevent spoiling the lens of the Camcorder. Please use a different disc and it should resolve the issue. If the issue persists with different discs, it may require service..
However, I suggest that you reset the Camcorder by pressing the Reset button behind the LCD panel (Near to the USB port) on the Camcorder) Please make sure that you have turned ON the Camcorder while pressing the reset button.
Jan 18, 2011 | Sony Handycam DCR-DVD108 DVD Camcorder
No sound on playback
Try playing any other recorded disc in the Camcorder to check you're able to hear sound from it.
Next, press and hold the Reset button on the Camcorder for 30 seconds then turn it off then back ON.
Then, try playing the disc in the Camcorder.
Good luck!!!!!!!!!!!!!!!!!!!!!!!!
Sep 21, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
Disc not supported
does your disc burner support both +/- dvd if not it will only burn either dvd+r or dvd-r look at the disc drive bay for compatibility
Aug 13, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Jun 28, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
Video on memory stick
You can use either or but the quality on the memory stick is different as well as the amount you can record based on the size of the memory stick.
Oct 21, 2008 | Sony Handycam DCR-DVD308 DVD Camcorder
Sony Handycam  DCR-DVD308 DVD Camcorder Logo
215 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
