Question about Amana PTH153B50AE Air Conditioner
No heat I have an Amana heating and a/c unit model # pth153b50ae. It was blowing heat all winter then just stopped. It now blows cold air and is either bringing in cold air from outside or is blowing a/c. It does not change no matter where the control knobs are set. I checked the fuse and actually changed it but no difference. The only way I can turn it off is either unplug it or take the cover off and switch of the little micro switch. I'm thinking the board is gone. Any help would be appreciated. Also could use a manual.
  • 1 more comment
  • doublechin Mar 05, 2009
    I have the same prob. The status light blinks every 5 seconds.
  • richard_w900 Mar 25, 2009
    Yes, I removed the circuit board and one of the relays had burned a hole in the board. Still under warranty. Amana sent me a new design board which I installed myself. Works fine now.
  • Kent Guidry
    Kent Guidry May 11, 2010
    Please look on your board and tell me if you see any blinking lights?
    Problem Solver:
  • 8 Answers
Check to see if unit has a contactor,they arc and weld together,keeping your unit on
Posted on Mar 25, 2009
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital...
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital temperature on the climate control is not correct. When it states that it is below 30 degrees on the ext and it is warm outside the air wont be cold. Once it starts going above 30 degrees the air gets colder. Today the blower stop working all together. Was told it maybe the climate control unit was bad. You can hear the door opening/shutting when you switch the temp from cold to hot. But there was no heat blowing out whatsoever in the winter time. Could you please give me your opinion on whether or not it is the climate control unit or something else?
Jul 11, 2011 | 2000 Pontiac Grand Prix
I have a AMANA PTh153B50AE (PTAC unit). The air conditioner works fine. It is when I turn on my heater and it does not get warm. It just blows cold air. I have looked at the board and it appears that...
I have the same problem, and I found the manual reset inside the unit. Turn the power off, and unplug the unit. Remove the outer cover of the unit ( inside cover ) , and remove the 2 screws holding the " wire mesh " in the front of the cover. Pull the wire mesh up and out of the way, then carefully pull out the heating element.
On the heating element, where the wires are connected, there is a manual reset button... Push the button in, till it resets...
My reset was on the upper left connection of the wires... just looks like a small push button, but the reset is recessed a bit.
Replace all covers and plug back in.. working fine..
Nov 12, 2010 | Amana PTH153B50AE Air Conditioner
My Amana package system fan only blows cold air
a fuse blows for a reason. dry bearings will increase amp draw, a non rotating fan rotor will blow a fuse. burnt windings will almost instantly blow a fuse. just changing the fuse may not solve your problem. find the problem and fix it THEN replace the fuse.
Oct 20, 2009 | Amana PTH153B50AE Air Conditioner
No heat
1.check heatar of unit.
2.wireing of heater.
heater not workink.
thermostate also check
Feb 21, 2008 | Amana PTH153B50AJ Heat Pump Air...
Cold air
is it a heat pump or straight electric heat??
Sep 30, 2007 | Amana AAC051FRB Air Conditioner
Amana PTH153B50AE heat problem
u must check if the unit outside is working when u turn on your air conditioner.
Mar 05, 2007 | Mitsubishi MS12TN Air Conditioner
Heating & Cooling Logo
275 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
