Question about Canon PIXMA iP3000 InkJet Photo Printer
Black ink i just installed black ink in canon ip3000. the test came out ok. but documents come out blank. what am i doing wrong?
  • Jdub09 Feb 06, 2009
    I have the same problem! haha. I thought that I may have installed the cartridge wrong, but after buying a new one and printing out a million test pages, I still cannot get ANY black ink of of this printer. I think its time to move on if no one can solve this mystery...
    Scholar:
  • 60 Answers
Hi
Check out my reply to chengfrank43 in ip3000 section.- it may be of some help to you.
Posted on Feb 22, 2009
I've just replaced the black ink cartridge on my Canon Pixma IP3000 but it is not printing - absolutely blank. However the colour cartridges are printing fine. Any clues?
Assuming a windows computer ... go to the printers section, right click on the IP3000, click on propterties then the maintenance tab. Try cleaning or deep cleaning and then nozzle check.
Feb 01, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
My pixma 3000 prints blank pages . iot was working until i installed a new black cartridge
my canon pixma ip3000 prints blank, I have tried all the maintenance functions but still prints blank. pls help...
Jul 20, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
I dont know why but suddenly my printer cant print
You could buy a new printhead, but the problem could be in the purge assembly. If the printhead doesn't clean and prime you get blank prints. also if you leave the tape on the top of the cartridge covering the vent hole no ink can come out.
Aug 10, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Poor color printing quality
do you have the canon print management software installed? it's located in the maintenance tab on that software.
www.canon.com has that by model number
Jun 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
IP3000 inkjet new but garantie expired, no print in black
After one day in alcohol infusion and hot day washing i resumed my print head.
Thank you for your intervent.
Regards Tamburino
Apr 11, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Injectable ink....
opppppppps! the black cartridge is separate for that printer. you need to use the PG-40 ink cartridge for the black.
Nov 24, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon IP3000, problem printing black
Try to change the default printer and check ...
Also try printing from other documents see if you facing the same problem
What version of Works you using ?
Do you have the Dic for Works ?
Apr 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
97 people viewed this question
old marine
old marine
