Question about Epson Stylus Pro 9800 InkJet Printer
Service required error 0001002d
I have service required error 0001002d pls some one help me
  • 2 more comments
  • donjr_1 Feb 16, 2009
    My Epson 9800 priter has a service call err of 0001002D and it wont do anything? Help
  • hafizamad May 11, 2010
    0001002d
  • Anonymous Mar 19, 2014
    printer not responding
  • 16 Answers
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Posted on May 27, 2009
Service call error 00010040
Common Error Codes
00000101 The CR Motor reached it's end of life. 00010000 PF Encoder Check Error. 00010005 CR Motor is out of step. 00010014 Pressurising failure. 00010027 Pressure pump micro air-leak error. 00010040 Printing position error. 0001002D The cleaning unit reached it's end of life. 0001003F The Pressure Motor reached it's end of life.
Servicing Levels
Three levels of servicing are available and detailed below:
  1. Basic 0040 or 0001002D maintenance procedure: This will return your printer from either the 0040 or 0001002D error to a working state by replacing only the relevant maintenance items.
  2. Advanced 0040 / 0001002D maintenance procedure: As well as replacing the parts relating to the maintenance error additional adjustments such as bidirectional/unidirectional alignment, 980mm feed adjustment, firmware updating and a general clean will be performed.
  3. Overhaul: All maintenance items as well as the PF, CR motor and belt, cutter cap, pressure assembly and cutter solenoid will be replaced. A check for any design defects such as a defective cutter cap and a defective pressure lever will be performed and any parts will be replaced if necessary. All head and feed alignments will be performed as well as any required software updates and sensor verifications. A thorough clean will also be performed on the carriage area and the print head. When the procedures are complete a survey will be performed to better understand your requirements and any recommendations will be brought forward.
info.gifIt is recommended that if you have recently come into ownership of a second user Epson Stylus Pro 9800 then you should assume that the counter values or service life levels are incorrect and choose the most thorough procedure detailed above. The reason for this is an increasing number of printers being "reset" without the actual parts being replaced or inexperienced owners trying to repair or replace parts incorrectly. In one such case a part was removed and replaced incorrectly causing a serious ink leak which was luckily caught early due to the undertaking of an thorough maintenance procedure, but unfortunately extensive damage had already been caused to the chassis and maintenance tank area.
I copied the error code and put it in the search bar in a web browser and came up with the answer. In the future just google the codes and see what comes up. Also you can download a Field Repair Guide PDF and a Manual PDF from Epson's website too.
Jan 25, 2013 | Epson Stylus Pro 9800 InkJet Printer
Error code 0001002D is displayed and can not clear
Thank you for the inquiry.
This usually is a Epson Large Format printer error. You will need to replace parts to clear.
blank.gif headerline.jpg header.jpg epson_loyality.gif blank.gif menu_background_l.gif home_off.gifseparator.gifcoveragearea_off.gifseparator.gifservices_off.gifseparator.gifprinters_off.gifseparator.giftechnical_off.gifseparator.gifsearch_off.gifseparator.gifenquiries_off.gifseparator_r.gif menu_background_r.gif blank.gif 0001002D Cleaning unit EOL
Just like any other mechanical equipment, a printer requires attention to keep it running smoothly. So, just like when the check engine light illuminates on your cars dashboard so does your printer, but instead of a spanner the error 0001002D will appear on your control panel LCD which is informing you that a maintenance procedure is due to be performed. This will normally involve replacing the parts which keep the print head clean, hence the error "cleaning unit END OF LIFE" and the waste pads. This procedure can be undertaken here at Large Format Repairs for the Epson Stylus Pro 3800 right upto the beast that is the Stylus Pro 11880.
worn_flushing_box.jpg worn_cap_assembly.jpg Worn flushing box Worn cap assembly worn_head_wiper.jpg worn_carriage_waste_pad.jpg Worn head wiper Worn carriage waste pad
Jun 03, 2011 | Office Equipment & Supplies
Says: fault error:116-325 whats this mean pls?
fault error:116 325 A failure of the Controller Fan has been detected. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
Hope this helps. Thanks
Mar 06, 2011 | Office Equipment & Supplies
Pson styllus pro 7800 service call error 0001002d.. help
this error 0001002D means Cleaning Unit end of life
The only fix for this problem is you have to call Epson and state them that you are facing this problem. They will provide you the codes to unlock this error. Its a universal solution that only Epson can provide you these unlock codes and you cant find in any websites.So contact them and get your problem fixed soon.
techbelkin
Dec 28, 2010 | Epson Stylus Pro 7800 InkJet Printer
Error req 0001002d
Thank you !!
Jun 09, 2010 | Epson Stylus Pro 9800 InkJet Printer
Epson styllus pro 7800 service call error 0001002d.. help
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm
Please rate the answer........
May 07, 2010 | Epson Stylus Pro 7800 InkJet Printer
000100200 error
Remove the printer in printers and faxes and reinstall it with your original install cd
Nov 01, 2008 | Epson Stylus Pro 9800 InkJet Printer
Error code of ricoh af1053SC 321.322. 326
To my knowledge below error codes refer to:
1. 321 - No Laser Writing Signal (F-Gate)
Error-1 Transfer Belt Signal Error
2. 322 - 1st Laser Synchronization Signal Error
3. 326 - 2nd Laser Synchronization Error
G Gate 2 Error
This would be a possible Laser failure or the transfer belt and would require service confirmation and possibly replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 04, 2008 | Office Equipment & Supplies
Epson Stylus Pro 9800 InkJet Printer Logo
4,541 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
