Question about Dell 2300MP Multimedia Projector
Line on the left side of the picture
I have a white line on the left side of the projected picture. I have tried to adjust it out but nothng seems to work. Please help
  • bob_mitchell Feb 07, 2009
    It is a dell 2300MP
Which module it is
Posted on Feb 07, 2009
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    Cna not get red adjusted on the right side of screen
    need to replace the convergence Ics STK392-110 there are two of them. Also check the six 2.2 ohm 2watt resistors
    Mar 28, 2009 | Panasonic PT-47WX53 47" Rear Projection...
    Convergence issue
    try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
    good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
    Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
    PT47WX52F Convergence problem, 3-d look, green worse
    So you are able to adjust? the crosshairs move left and right up and down. you might have to get a tech to adust it in service mode.
    Feb 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
    Sony kp-65wv600 blue arch line on left side
    in the menu does it have a convergence menu? try doing that.
    Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
    Convergence Problem
    sounds like 1 of the convergence chips are gone theres 2 of them and better off replacing both as the other would just go a month down the line there might also be a resister or 2 gone, the price for that kind of job is around 150 +vat.
    hope this helps
    Feb 10, 2008 | Panasonic PT-47WX51 47" Rear Projection...
    Sony 52"
    i have a sony kp-53v80 i have a double vision or red lines on the left side of the screen. a repair guy fix it once by using the remote and puting in a code that brought up a white grid and it showed the red was out of line and he moved it back in line and it only took a few seconds to fix ... how do i get to that grid using the remote
    Dec 28, 2007 | Sony KP-53V80 53" Rear Projection...
    How to adjust picture on projection tv
    i have a 52" rca projection , and the screen looks like this ") (" on the sides can i do something to straiten it back out?
    Aug 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
    Dell 2300MP Multimedia Projector Logo
    108 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
